Hi,
I was wondering if other folks ever encounter recordings with a zero length?
I'm using a Mac Mini Core2Duo 2.4 GHz with two Elgato Hybrids. The Hybrids are from 2007 and 2008.
After getting the zero length recording last night, I tried opening (file->open next live tv window) both tuners and one of them wouldn't open. I assume that's the tuner EyeTV chose and produced the zero length recording with. The problem tuner gave the message “Device could not be initialized”. I unplugged it and replugged it and it was fine.
On a prior day, I was doing some testing and got that “Device could not be initialized” multiple times. This occurred with the computer on the whole time while I was playing with the deinterlacing options.
Could this mean one of the tuners is getting ready to fail?
Is the HDHomeRun more reliable than USB based tuners? It seems to be cheaper.
Thanks for reading.
Thanks for reading.
