PowerDVD Ultra 12 to stream
post #1 of 3
I have the PowerDVD Ultra 12 whcih streams to network deviceds.
My Network enabled Blu Ray player sees the PowerDVD and can see my video files
however it only is playing the SD .mpg and not my AVCHD files that I have - even though it sees them on the BR player and can play them just fine via PowerDVD Ultra on my PC.
any ideas?
post #2 of 3
PowerDVD Ultra is a pile of crap, don't waste your time with it.
Install the free Serviio on the PC and that will stream all your media to the BD player and transcode it too in real time if it cannot play it.
(if you really want to know, Cyberlink still adhere to the original DLNA specification which only mandates .mpg or wmv video as supported formats, thats why it wont see anything else)
post #3 of 3
than
thanks, that s/w looks perfect
however after installing and setting up the library - it doesn't show up on my BluRay Player
any idea?
thx
