Originally Posted by
Ethan Winer
DS-21
See Bill Waslo's excellent article, which I've reposted
here.
I understand what he's aiming for, but I disagree with over-toeing speakers because that exaggerates loudspeaker beaming and lobing.
No, it doesn't, assuming the speakers were competently designed in the first place. (And if there's a directivity shift in the midband, the problem is simply incompetent loudspeaker design.)
Ethan Winer
I'm mainly concerned with getting a flat response that doesn't change drastically with small amounts of head movement.
Using appropriate speakers set up using the Geddes/Waslo crossfiring approach (and multisubs), one can walk 5 paces in any direction without worrying about changes.
(Though in the same breath, the only speakers I've ever heard that really did change dramatically with small head movements were the big old Dunlavies.)
A hard center also helps immensely in that regard. (I never listen at home in stereo, it just sounds so...
lesser than even synthesized - DPL2 - multichannel.)
Ethan Winer
The best way to achieve a wide image - not unnaturally wide, only as wide as the producer and engineer intended - is to absorb all side-wall reflections.
That's a great way to suck the life out of a room, but isn't much good for anything else.
Our point of agreement here, I think, is that adding room mutilation products will actually have a sonic effect, unless say swapping amps (assuming both are adequate to the job) or wires, etc.
Ethan Winer
If one isn't allowed to put acoustic treatment in the living room there are ways to hide it, though of course that costs more.
That "allowed" bit assumes men don't care how their homes look. I think that's a stupid assumption.
