For those of you who are using some type of wood - Baltic birch, cabinet ply, other ply, etc. I have a few questions. I'm relatively new to the wood finishing process and could use some help. With all the work and effort that goes into box designing, cutting, routing, clamping, and preparation, I really want my boxes to look their best.
Besides sanding edges, how are you getting them invisible?
How many are using a sanding sealer and/or a type of primer? What type of product are you using? Spray or brush/rolled on?
What type(s) of paint are recommended? Spray or roll on? Sanding between coats? What grit? For those rolling on, are roll marks visible? How are you dealing with them?
Thanks in advance,
Andrew
Thanks in advance,
Andrew
Apologies.
