Today's to do list:
1)Add 3 shoplights to the garage so I can see what I am doing.
2)Remove mostly fried 21LW1400 from WiSub.
3)Replace 21LW1400 with 18HP1060 taken from a NewSub.
4)Remove frame of busted 18HP1060, and good 18HP1060 from a pair of NewSubs
5)Place a Zv3 18 in each of the two vacated NewSubs.
6)Test and prepare for show tomorrow.
The DCR of the 21LW1400 started out factory at 5ohms, after a show a couple of weeks ago and some voice coil smelliness it is now 2.3. Oops, but what can you do. Wussy drivers don't last long in my rig.
One of the 18HP1060s got brutally kicked in the night before my grille order showed up. Oops, I had managed 5 outings with no issues, definition of irony.
After careful assessment at the last show, when running 800w to the 18HP1060, they stay linear and sound great. But when fed 1100w, they audibly mechanically compress because they run out of stroke. I have a D1 Zv3 and a D2 Zv3 that I will be trying tomorrow. The D1 will be a 2ohm load pulling 1600w out of a channel of a KLR-3200, and the D2 will be a 4ohm load pulling 1100w. We'll see which one survives the night, and wich one runs out of either amp or mechanical throw first. According to simulation I'll end up 10mm short of Xmax at 1600w, but will be 5mm more than the Faital is capable of. Tomorrow night will be the beta test to see which coil config works out the best. Simulations and other predictive data is cool, but real world testing is where it is at.
Don't worry, I'll have pics
