AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Need New TV - Ex Girlfriend Smashed Old One :(
post #1 of 9
Hey Everyone,
A couple years ago I purchased a 63" Samsung pn65c590 television that I was very happy with. I believe back then I paid around $2500 for the display. The television worked superb...that is until my ex-girlfriend hurdled a frame off the wall into the screen and cracked the screen :/
So now I say, bye bye ex girlfriend....hello new TV! lol
So really what I want is a new television ranging from 50"-63" that is either comparable in quality to the old television I had, and the price range I'm looking at is between $1000-$1500.
Also, I am open to suggestions as I am open to the possibility of LCD/LED or would go back the Plasma route if that's the best bang for my buck.
Any advice would be amazing!
Thanks everyone!
post #2 of 9
Here are a few choices that may fit your price range:
Samsung
PN60E6500
PN64E550 (not 100% sure on the price, but I think it should fit within there)
Panasonic:
55ST50 (possibly the 60" as well)
UT series (not sure on the cost or size that would fit your budget, but I am guessing they have a 55 and or 60+ that might fit your needs.
post #3 of 9
You may also want to look at LG. A 60" non 3D-non smart (pm6500 think) can be had for 900 bucks or so, the PM6700 which has 3d and smart apps is around 1399. A lot of folks wont even look at anything other than Panny or Samsung, but only you can decide what picture you like. Just putting it out there....
post #4 of 9
Don't mean to be too nosy but ... I got to know ...what did you do to p#ss her off that bad !
post #5 of 9
post #6 of 9
i have an lg also for three years and no problems with it . i would send her the bill though.
post #7 of 9
of course if she pays i would give her the smashed set as a trophy. hehehe.
post #8 of 9
Originally Posted by PCD View Post
http://www.youtube.com/watch?v=wse_hgca220&feature=player_detailpage#t=8s
post #9 of 9
Now that's a good one!
