AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Volume Turns All the Way Up When Pressed Once From The Remote
post #1 of 9
Recent issue with my Yamaha RX-V371 receiver. From the remote control, when I press the volume up button once, the volume turns all the way up by itself to the highest volume level (as if I was holding the button down). The same goes for if I am turning the volume down, it goes all the way down. Any suggestions?
post #2 of 9
If you're talking about the original yamaha remote, then change the batteries. Otherwise, post the make and model of your remote.
post #3 of 9
Replaced batteries didn't do the trick. Problem also happens with my Comcast remote which is programmed for my receiver. The Yamaha remote I have is RAV331 / WT926700.
post #4 of 9
Check for other remotes in the room, stuck in a cushion or under a book, sounds like IR interference, your single volume command is getting stuck in a feedback loop.
post #5 of 9
If two different remotes just started doing the same thing, then something is broken in your receiver or there is a new source of IR interference in the room, perhaps a new tv, a different backlight setting or new lighting. The problem isn't the remotes, nor is there any receiver setting you can change.
post #6 of 9
Just Christmas Lights recently - I wouldn't expect those to throw off any IR interference though. I'll problem solve tonight. Thanks
post #7 of 9
Perhaps a Christmas Light outdoor timer about 10 feet away (has sensors in it to turn on lights once it is dark outside)! Could that be the culprit?
post #8 of 9
Hmmm... don't think so. It would have to output light. A sensor shouldn't be a problem.
Try this. Get a piece of masking tape (painter's tape) and cover the IR sensor on the receiver. That cuts the amount of light without blocking it entirely, usually doing a good job of filtering out just IR noise.
post #9 of 9
Went home last night and it worked perfectly. Very strange..... didnt change anything at all.
  Back to Forum: Remote Control Area
