I am seeking advice on manual pull down screens, both on screen material and make/model. My concerns are waves developing in the fabric and picture quality (obviously).
Unfortunately, a tensioned screen probably isn't worth the upfront cost since I may move in a year and have a totally different setup. For the same reason, an electric screen probably isn't worth the cash outlay right now either. It's my understanding that I'd be spending at least $900 (or much more) to get something properly tensioned. Also, projecting on a fixed screen or wall won't work because of placement of doors and closets in the middle of said walls, etc (the joys of small apartment living).
I've read and searched through a bunch of threads on AVS and have come up with the following info:
a) Da-Lite Model C is better than Model B since the C has a larger diameter roller, so potentially less prone to waves developing
b) CSR feature may also help prevent waves from developing
c) some high power fabrics can help hide waviness of the screen
d) Deluxe Model B tensioning is not good and can cause problems
I currently use a 1.8 grey glass beaded screen and it's horrible. The problems are that it's way too dark, color accuracy is extremely poor and it has developed pretty noticeable waving. My plan was to just get matte white or a low gain high contrast white but if another material can substantially hide waviness, I might consider it as well.
My setup is for a 106" diagonal, 16:9 screen, which hangs 3" from the wall using L brackets. I have a Panasonic AE-4000U projector, mounted directly above the seating area. The throw and seating distance are both 11 feet. The projector is mounted at about the same height as the top edge of the screen. While sitting, my eyes are just above being level with the bottom of the screen. The room is not a dedicated home theater room and has white walls.
So my questions:
a) can anyone recommend a better manual non-tensioned pull-down screen than the Da-Lite Model C CSR? Would I be better with a Draper or something else?
b) which specific brands/models of material hide waviness?
Size of the casing is also important too since it hangs from L-brackets in a fairly cramped area underneath a structural beam and above a door way.
Thanks in advance.
So my questions:
Thanks in advance.
Boy have we come a long ways from the days of "dim" CRT projectors.
