AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Dubbing from HDD to DVD...(Hey Wajo!!)
post #1 of 7
I didn't see this mentioned, but kinda got the idea it can't be done.
When dubbing from the HDD to a DVD, is it possible to PAUSE the recording.
Example: I have 5 titles to dub from HDD to DVD. Instead of having 5 separate titles, I'd like to
have one recording of the 5 titles. I saw you could STOP the dubbing, but I didn't see anything
mentioned about whether we could pause or not. Would be nice...
post #2 of 7
Can't Pause when using the internal drives and dubbing menu.
You can play from Mag to external DVD player/recorder and Pause that recorder to get one long title. Best PQ is from HSD with internal drives, but I don't think you'll notice a quality diff. with ext. copying IF the original titles are from a digital/HD channel and Rec Mode was SP or HQ (test to be sure beforehand).
post #3 of 7
That's what I thought.
post #4 of 7
What you are asking, combining multiple titles into a single title for high speed dubbing to optical media, is trivial with a Panasonic HDD DVD recorder, but not with the Mag HDD recorders. Even with the Panasonic, some restrictions apply that would prevent a high speed copy (lossless) but if you followed the "rules" it could easily be donw with playlists.
Yeah, I know, it doesn't help you a bit. frown.gif I just thought I'd mention it. rolleyes.gif
post #5 of 7
Actually I didn't mention anything about an HSD. But in general you are correct, it doesn't help me a bit.
post #6 of 7
Sorry, I guess I wasn't completely clear on your request. As wajo has already said, the only way I can see of doing what you want is to play back each of the titles with your Mag while simultaneously recording the playback onto another machine, pausing THAT recorder between titles, thus making one title consisting of the original five. That probably doesn't help you much either unless you have access to another recorder.
A longer way around this would be to make a DVD with the five individual titles (HSD so no loss), then play that disk back on any old DVD player while recording it (again) on your Mag into a single title. You could then either pause the recording between titles, or edit the short title-change-over bits out of the recording making a single title consisting of the original five. There will be a loss of quality. Whether that's a significant loss of quality is of course, up to your eyes.
post #7 of 7
Yep. That's all true. I have other VCR's and another older mag. dvd recorder, but really didn't want to record...record...record if possible. I'll have to waste a few dvd's to see what the quality loss is I suppose. Thanks anyways.
  Back to Forum: DVD Recorders (Standard Def)
