AVS › AVS Forum › Audio › DIY Speakers and Subs › Low sheen black paint for subs ( professional looking )
post #1 of 6
What paint would be good to achieve a (professional looking) Low Sheen black finish on my mdf subs ??
post #2 of 6
I know a couple of people have used Rustoleum flat black and had success. Not the rattle can, though.
post #3 of 6
What kind of performance characteristics are you looking for?
How do you plan to apply it (brush, roller, spray, etc)?
How much use will the coating get (is it an end table, or sub in dedicated theater, etc)?
When you say low sheen do you want it to be as flat as possible or can some sheen(eg-shel/satin) be tolerable?
I feel like I just responded to someone who just said "I have $2000 what can I buy with this?" Sorry in advance for nerding out on paint biggrin.gif
post #4 of 6
Dedicated HT Subs ,
Yes I can rent a sprayer ,
Low sheen not completely flat
post #5 of 6
post #6 of 6
http://www.avsforum.com/t/1334710/3-4pis-are-being-imagined-in-my-head/60
scroll down...
Are you reffering to the black baffles ?? if yes ,i think i would like just a tad more sheen to the black.
