Just a few turns, probably not even a full one. I will not be at the apartment until after Thanksgiving so I have no way to test it now. Pretty sure the bottom and top went out of focus, the top right corner specifically. I had never adjusted these before since we do not have the proper tool for it. When trying to adjust it back with the regular lens adjustments, I knew something was wrong. Do you know what is the proper bit size for these screws?
By the way, another question:
When there are very bright white scenes, such as with a cloudy sky, the picture will get streaks or waves that flow top to bottom through the picture. The first thing to do is clearly to isolate the projector on a different power plug and see if this continues, but has anyone else seen this before?
Edited by UncleWill - 11/21/12 at 6:18am
