AVS › AVS Forum › Audio › Speakers › Polk Floor and Energy Surround Speakers
post #1 of 6
Hello,
Newbie in the home theater world, I am planning to buy the following and needed some advice
Polk Audio Monitor70 Series II Floorstanding Loudspeaker
Polk Audio CS1 Series II Center Channel Speaker
Polk Audio PSW Series PSW10 Black 10-inch Powered Subwoofer
Energy CR-10 Surround Speaker (Pair)
Receiver : Onkyo TX-NR717 Or Denon 2113C
Any advice on above config?
Room Size is 20x20 dedicated home theater room and pre-wired for speakers and wired for zone two speakers
Need advice on good quality Projector less than $1500 and a screen
Thanks a ton
RK
post #2 of 6
Get the larger CS2 center instead of the CS1.
Why not some Polk surrounds like the OWM3 or OWM5?
post #3 of 6
Thanks for the prompt reply didn't know Polk had low end Surround Speakers. I ail definitely look in to CS2 for the center channel.
What about the receiver?
RK
post #4 of 6
I would get the Denon because it has a better version of Audyssey than the NR717.
Denon 2113 uses Audyssey MultEQ XT, Onkyo uses Audyssey 2EQ.
http://www.audyssey.com/audio-technology/multeq#multeq-solutions
You should also check your local best buy to see if they have any of last years Denon's or other receivers on clearance.
For instance, around me they have the Denon 1912 for $199, Yamaha RX-A710 for $319 and Pioneer Elite VSX-51 for $399.
Edited by afrogt - 11/16/12 at 7:08am
post #5 of 6
newegg has the cs2 on sale now for $99.99
Enter code EMCJJJD23
Grab it while the grabbin is good.
post #6 of 6
Done I picked up the Channel, Right, Left and Subwoofer (12") Polk. Now I need to shop for Surround speakers. On receiver I think I will be going with Denon 2312CI
Next on the list is a projector and Screen any ideas?
BenQ or Epson?
Thanks a ton!
  Back to Forum: Speakers
