My English is not good. Translator translates.
Hello, I have two SonyG70, one does not function.
The other G70 already hangs in the cinema.
The SonyG70 had first Error 27 and one more Error.
(Button of the cable cover is on top on it OK)
The G70 has got afterwards the old software with G2 setting.
The original software has no manual G2 setting.
The trader had by this contribution in the link the idea with the Zeropower-SRAM exchange and hard Reset:
http:// www.avsforum.com/t/1193903/sony-g70-error-code-23-24-29-36
I have bought this:
http:// Www.ebay.de/itm/1-St-Zeropower-SRAM-M48Z128Y-70PM1-/360423969391
Another German trader CRT said of the old SRAM, is not mainly guilty in the mistake code:confused:
Can the old ZeropowerSRAM release / indicate an Error?
Is one necessary with new ZeropowerSRAM, hard Reset?
Can a Hard Reset release other mistakes?
Is hard Reset 10 seconds of Reset button on the board properly press
Before the turning on already press???
1.
I have inserted the new ZeroPowerRAM.
2.
I have pressed the Reset counter the board and have switched on the G70 (main switch)
= First Error88
= G70 switched off and anew Reset.
= G70 switched on and no Error.
= The G70 has got high voltage and has remained switched on.
= The green tube has easily shone???
= No menu Function no test picture.
3.
The G70 has high voltage, however, no menu Picture and the green tube Shining on the whole surface???
= I have operated the brightness counter
= G70 is switched off with Error36
4.
Topically I have Error36 only with operate of the On key.
= the G70 switches off itself after 1 second with Error36.
Is it to be tested sensibly the V-Board E-Board and Y board?
Is it able to do yours the old Error 27 now is only invisible because error 36 is quicker?
Can I damage functioning Boards?
Greetings
Sebastian from Dortmund
I have bought this:
1.
2.
= First Error88
3.
4.
Greetings
