Hi,
Me and a few friends in a HiFi forum in Sweden have created a Spotifylist whit music tracks containing lots of infrasonic bas. The rules where a set 0 dB level that the music normally plays at in the measurement setup, and information between 0-20 Hz has to be 50 dB above that to earn a place in the list. We also set up a rule that no more than 3 tracks from the same artist can be on the list.
We were surprised on hove many tracks we have found so far. Today the list contains 173 tracks!
The list is a open for anyone to add tracks, but I measure and delete all tracks that don’t fit the criteria’s.
Here is the list: <20 Hz bass-list
Here is an example of a normal track:
As you can see the bas level is around 0 dB.
Here is an example of a track that did make the cut:
As you can see +50 dB information between 0-20 Hz.
There are music from artist like Mick Jagger, David Bowie, Mike Oldfield, Tori Amos and Joni Mitchel on the list. No testtracks are alowed only "real music".
Edited by Alexi - 11/16/12 at 4:17am
