AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 42
post #1231 of 5603
Originally Posted by wmcclain View Post
No cue sheet support.
Files must be named in strict alpha numeric order for sorting:
01-something
02-
03-
10-
11-
etc...
NOT
1-
10-
2-
etc.
-Bill
Thanks Bill. I will rename them and do so on all the files I download from that source.
Cathy
post #1232 of 5603
Originally Posted by nycjazz View Post
Originally Posted by Bob Pariseau View Post
For regular CDs:
If you are using the Dedicated Stereo Outputs (with Stereo Signal = DOWN MIX STEREO), then there will be no output on the Analog Subwoofer jack, so the question is moot. The Dedicated L/R are treated as Large in this case.
If you are using LF/RF from the multi-channel set (or Dedicated L/R with Stereo Signal = FRONT LEFT / RIGHT), and LF/RF are set to Small, then bass will be steered to the Analog Subwoofer output according to the Crossover frequency you select, and that Subwoofer output will need +15dB boost -- typically achieved by raising the volume knob on the Sub in a direct-connect setup.
--Bob
Thanks Bob, I am using the lattter configuration. Do you recommend bringing up the trim in the 105 for the sub to +10 and then adjust for the extra 5?
The reason for the attenuation is so that LOUD signals can be carried without clipping the input at the other end of the cable. If you raise the sub volume trim in the player you risk running afoul of that. Whether it will ACTUALLY be a problem depends on the headroom of the input at the other end of the cable -- i.e., the max voltage it can accept before clipping.
That's why the Rule of Thumb is to provide all of the boost external to the player. In the case of direct connection to the line level input of your Subwoofer, that would mean raising the volume knob on the Subwoofer.
If you run the Analog Subwoofer signal through an AVR -- even when set to Analog direct pass-through -- you will likely find that the AVR is providing +10dB of boost already by default. Some AVRs (Denon for example) have a setting to change that to +15dB of boost. In any case, if the AVR is already providing some of the boost then you need less increase in the volume knob on the Subwoofer itself.
You can check your levels by using the 5.1 LPCM test track from AIX Audio Calibration Blu-ray and an SPL meter. If you are running a true 2.1 system, you will need to temporarily change Center and the Side Surrounds to Large in the OPPO to keep them from being down-mixed during the test. It does not matter that nothing is cabled to those outputs. So you would have Sub ON, LF/RF Small, and Center/LS/RS Large and then check the levels for just LF/RF and Sub. If the levels are correct for that 5.1 test, then the OPPO will also insure they remain correct when you play 2.0 content and thus only bass steered from LF/RF is going out on the Sub output.
Set main Volume on the OPPO so that LF/RF produce 75dB SPL (for example), and then, leaving that OPPO volume unchanged, adjust the volume knob on the sub until it too achieves 75dB SPL. Repeat several times until there is no longer need to change the Sub's volume knob as the sub volume setting also affects a portion of the LF/RF output.
--Bob
post #1233 of 5603
Wow! Now it looks like the beast actually plays OGG vorbis audio in DMR mode! The mistake was on the server: wrong mime-type in configuration. I have fixed it (actually FLAC was wrong as well in the Serviio DLNA server configuration, that is how I noticed; in Twonky it is only the OGG mime-type) and it plays now. I have all transcoding turned off, so it must be the Oppo playing ths OGGs directly, I suppose.
post #1234 of 5603
Oppo BDP 105 initial unboxing
So, I picked up my BDP 105 a week ago Thursday and installed it in my system a week ago today. When unboxing this player, it sort of reminded my of my Cambridge Audio 840C unboxing. Nice cover, decent cords included, and nice robust packaging. I’ve never had another Oppo product, but reading the myriad good press and user reviews, I really wanted to give one a try. Was really thinking about buying the 95 but found out that the 105 would be coming to the market in 3-6 months (when I was finally deciding to take the plunge). So, not being an early adopter on most things, just waited till now for the release of the newest player. I’m glad I did.
I was very pleasantly surprised at the quality of everything in the box. The player itself weighs 17.68 lbs. (old backpacking gear habit). Very nice looking IMO with the centered drive and attractive front; a bit of understated elegance. All the accessories came in a nice black box including a power cord, HDMI cable with filters (never seen one with filters), remote, batteries, and a wireless dongle with a remote wireless base. I had read there was an extension for an MHL device like a Roku stick so you could relocate that in the event you have doors on your rack system, but that did not come in the box. Maybe that’s the remote wireless base I mentioned above. -I’ll need that for my installation if I get a Roku stick. Anyway, very nice, complete package. See below for a couple of photos.
I am working on a couple quick write-ups for both use as a Blu-ray player and as a Redbook CD player. I’ll post them later.
12/21/82012 - As an afterthought, I thought I’d mention that the cords that came with the player are quite robust. Here is what is written on the jacket of the cable.
1 – HDMI Cable: HighSpeed HDMI Cable with Internet E256295 SIJ AWW Style 20276 80*C 30V VW-1 HDMI Freeport
1-Power Cord: (VL) E140081 SJT 3 X 14 AWG 105*C 300V VW-1 NS CSA SJT 3X 2.08MM (14 AWG) 105*C 300V LL 86908 FT2
Edited by Pokey77 - 12/21/12 at 3:39pm
post #1235 of 5603
Originally Posted by audionuts View Post
I did tested the xlr out directly to my amp and though the sound was natural and liveable. Althought, it was not as good as my dedicated 2channel preamp but far from horible.
The Dac of the player is a major key component of how the 105 sounds. xlr or rca analog should not sound much different in quality. If you find no use of its analog out then I would recommend you to return it for the 103 or try something else. Just my 2cts.
I have no problem with the 105, just that one case when I hooked it up directly to the amps for an experiment to see how it would compare to my pre-amp. Will post below the solution from the person who hit the nail on the head.
Originally Posted by jimshowalter View Post
The users who are unhappy about Oppo's volume control are complaining about the range of amplifier input sensitivities supported by the Oppo. It can drive some amps quite well, others maybe not so well. Similar complaints have been registered for the headphone amp in the Oppo. In both cases, the discussion is basically whether the Oppo is a true general-purpose preamp and headphone amp (ignoring electrostatic headphones). Perhaps it is not, and perhaps Oppo will respond to that conclusion in a future release (whether of the 105, or of its successor). For users who are lucky to have amps and/or headphones that fall in the sweet spot of the 105's drive capabilities, they are very happy.
There's no reason to think that. Adding a preamp between the Oppo's outputs and a power amp's inputs adds more opportunity for signal distortion (but it also though adds the possibility of better matching the input sensitivity and impedance of the amps, if they happen to fall out of the sweet spot of the Oppo; and it adds the possibility of controlling volume entirely in the analog domain).
Ironically many of the users posting here who have directly connected their Oppo to power amps have done so over XLR, and many of them have said the sound is the best they've heard. It sounds like your system has something not correct about it.
Again, Oppo Europe says otherwise.
I assumed that as in the past that some components didn't play well together when building a system. Since I beleived that this was just a player, that it might be the case here.
Originally Posted by jcm2128 View Post
FYI.... I connected the 105 directly to a Parasound two channel amp using XLR and the results were fantastic (better than through my RCA input on my Marantz SR7005 AVR and back out via RCA to the Parasound).
I had no issues with volume control. The sound reaches low listening volumes at around 15 - 20, moderate at 20 - 30, and loud 30+ with my speakers (93 db sensitivity).
Thanks for the info and link. My solution is posted in the next reply.
Originally Posted by darkphader View Post
Maybe with your amp, but here it sounds just great. Is it possible your XLR's are wired poorly? Did you try setting the XLR Terminal Polarity to Inversion on the Oppo?
Thank you! You hit the nail on the head by changing polarity.
Originally Posted by dmusoke View Post
Assuming the input impedance of his amplifier is 5K or greater, the most likely cause of his problem, i believe, is the input sensitivity spec of his amp. If its low, i.e 1V for the XLR like my power amp, then the slightest change in volume from the 4X higher gain Oppo will clip or distort in the amplifier's input hence the distortion Oldav is hearing, similar to what Edwardkim was experiencing as well.
Thanks dmusoke, but it was the XLR cables.
Bob, thank you for your detaied write up. I have printed it out for future reference.
Thanks everyone for their replys. I hope no one got the wrong impression that i felt something was amiss with the 105, in fact it's just the opposite. I bought the 105 for several reasons, I needed a 3D bluray player, I was wanting the USB along with Ethernet streaming. My CD player was long in the tooth and it was a good time to make some consolidations of equipment. I still have numerous sources and therefore need a pre-amp that can handle all those sources with the most transparency. Everything runs through it and I am very satisfied with how it functions and the output.
I was surprised that I needed to reverse the polarity on the XLR outputs as these are Purist Audio XLR cables that were connected to my CD player with no problem after two pre-amps. When I hooked up the Oppo to the pre-amp everything still played and sounded as it should. Go figure! The Krell amps loved the direct connect when properly configured. When I re-attached the Oppo to the pre-amp with the polarity changed, it sounded the same as before, very pleasant. Now I haven't had time to compare the direct connect vs the pre-amp, but I hope you understand when the polarity was reversed and directly connected to the amps it sounded (to me) horrible.
Thanks again.
Gary
post #1236 of 5603
See the FAQ for supported file types.
Note that OGG works as its own audio file, and as a codec in OGM containers, but not in MKV.
No 5.1 for OGG.
-Bill
post #1237 of 5603
The advantage of NTFS is that individual files within the file system can be larger than is the case with FAT.
And NTFS volumes can be much bigger:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/choosing_between_ntfs_fat_and_fat32.mspx?mfr=true
post #1238 of 5603
--Bob
Bob, I got a couple of novice questions for you:
If I set the main volume on the Oppo so that LF/RF produce 75dB SPL and then, adjust the volume knob on the sub until it too achieves 75dB SPL, how can I have +15dB of boost? Did you mean that I use the volume knob on the sub until it is adjusted to 90dB (+15dB higher than LF/RF)?
Should I adjust the volume knob on the sub to give me +10dB for SACD and +15dB for the rest of the stuff (2.1 CD, BD and Cable box)? Or should they all have a +15dB boost?
post #1239 of 5603
Hi All
Here is a picture of the 105 & AV7005 using the analog connectors. I am using the dedicated stereo outputs for the front left & right inputs of the AV7005.
If I am correct this way I can use two seperate sub's and still have it work in direct mode on the AV7005 using my FLAC files on my PC streaming with DNLA.
This would be the second best way instead of the 105 dedicated stereo outputs going straight to the power amp.
Everyone agree on this?
post #1240 of 5603
When I switch the audio input on my Classe SSP800 between analog and HDMI I lose the video signal from the Oppo 105 (I use the same HDMI input for video for both) and I can't get it back unless I power off both the Classe and the OPPO.
Anyone else have this problem?
I'm still finding the analog sound too bright and thin, but hopefully awaiting break in improvement.
post #1241 of 5603
Oppo BDP 105 – As a Blu-ray player
I have been using my 105 for the past week now. It’s really nice to use a player that responds very quickly to commands; more DVD-player-like. And it sure doesn’t hurt that it loads a Blu-ray like a DVD as well. Can’t believe how fast I can get started now. Before I used to put a Blu-ray in and walk down the hall to the kitchen to get a snack and by the time I got back it would be at the menu. Now, I can’t hardly get out of the room before it has booted up.
I have watched a number of Blu-rays and DVDs since I installed the player. The first disc I remember watching was Disc 3 of Season 1 of the TV show “Hell on Wheels”. I couldn’t believe how well the up-scaling worked on that disc. It made the DVD output look very Blu-rayish. Sound quality was pretty stunning as well. This was just out of the box and after playing “Iron Man”, which is what I inaugurated the player with. The player has about 30 hours on it now and I’m using various CDs to burn it in.
My current player is a Marantz BD7003. I am running the sound via coax to the DAC section of a Cambridge Audio 840C. This has been a great combo and I’ve been using it for about 3.5 years now. A Vidikron VL-52 monitor does the display duties and McIntosh/Martin Logan do the sound. My system is two-channel and that is why the BDP 105 really appealed to me. I have been wondering for some time if the BDP 105 could significantly better my current player. Now I can finally find out.
The following comments are based on my viewing of Prometheus. I had asked a guy at my dealership what some of the best new Blu-ray titles were for PQ/SQ and this is one that he mentioned. After watching it, I can say that I think it is pretty stunning in both respects. So this disc worked great for me to evaluate the performance of the 105 vs. my current setup.
Note: I watched the movie for the first time last night but didn’t feel like staying up to compare the two players.
I decided to watch the Marantz player first today. I looked at the Menu, Chapters 1 and 8, and the Credits section of the Blu-ray to evaluate both PQ and SQ. I inserted the disc and it took approximately 1 minute and 15 seconds to get to the first text on the screen. So, when I finally got to the menu, I noticed that the menu looked dark and of lower resolution. Not very attractive based on my memory from the night before. The images of the actors were not very well resolved either. I moved on to the movie and some of the scenes looked quite amazing. But many of them were not very convincing having color smearing and imaging that lacked fine resolution. Facial coloring and rendering were not as good as I had remembered on the 105 the previous night either. The text on the credits looked pretty good but the music at the end did not have a natural organic feel and sounded a little veiled. I do note that the last scene with the monster and the huge echo it made as the scene faded out sounded pretty good though.
So with the review sections of the movie done I moved on to the BDP 105. The only changes required for this were that I move the HDMI cord from the Marantz to the Oppo and to switch the sound input on the McIntosh from CD1 to Video to do sound duties for the Oppo. I also used the same copy of the Blu-ray movie and both the Marantz and the Oppo use the same model of the top of the line Blue Jeans interconnect, one for each. Both players are set to 0 on all picture settings and I let the Vidikron handle all the color settings; it is professionally calibrated. I have essentially no variables so as to hear and see what it is the two players do without influence from calibration, media, or interconnects. I have not updated the firmware since viewing movies and playing CDs all work correctly.
So, on to the 105. The Oppo fired up the disc to first text in just 15-20 seconds and was to the menu pretty quickly after that. The first thing I noticed was the menu looked so much better. With the Marantz, the menu looked dark and poorly made (engineered); one dimensional, like an image hovering over a black background. But on the Oppo, it could be seen that the menu image was actually the interior of a globe or universe. The front image contained blue lines running to vectors and behind that the inner surface of a globe could clearly be seen; very 3D-like and convincing. And the shots of the actors on the menu were much more convincing as well. As I moved on to the movie, it was quite evident how the player performed at a much higher resolution. For example, the clouds around the spaceship in the opening scene looked much more wispy and life-like and the scene just felt more real. I also found that the player was very good at resolving partial/low light and dark or slightly dark scenes very well. When the character David was walking from one area to another within Prometheus (the spaceship) and the lighting was changing from partial, to full light, to dark, the player was able to render those lighting conditions very convincingly. Facial coloring and likeness are something hard to get right but the Oppo did a significantly better job than the Marantz. There are many more examples I could try to describe that would show the Oppo’s strong points, but I’m not much of a reviewer as you’ve probably already noted.
After watching this one movie, it is just plain obvious that the 105 is equal to but mostly quite superior to the Marantz in picture quality. Based on my impressions this week, I had felt that the Oppo was pretty good and certainly at least somewhat better than the Marantz. But I didn’t know what I was missing out on until I did this comparison this morning. Picture quality is quite stunning.
I know I haven’t mentioned sound quality, so here is a summary of my findings. -There’s really no contest here. The Oppo has a very low noise floor and that allows it to be highly resolving and to provide a holographic sound quality that just feels real. No veiling of the sound was noted. Just life-like sounds of water, rushing wind, the human voice, music; all of it was produced in a very pleasing way with no rolling off of the upper-end. I wrote in my notes that all these sounds were “clear, analog, awesome”. Ambient noise and sounds also had that transparent real quality about them as well, thus my “analog” comment. The scene at the end where the monster makes the huge echoing sound as the scene fades out sounded significantly better than on the Marantz. It has amazing decay and a very holographic presentation. One thing I did notice is that while the bass is very well defined and controlled on the Oppo, it is not as full and lower-reaching as the Marantz playing through the Cambridge 840C. But it is fairly close and I will have to wait to see how it sounds once the player gets some hours on it. All this for me adds up to a higher level of enjoyment and I can’t wait to use the player tonight.
Based on my comparison of the two players today, it is an easy decision to let the Marantz go. It is just not in the same league as the Oppo. And this shouldn’t be too hard to understand with the Marantz being a last generation player. So, for me, my apprehension and questions have finally been answered. The Oppo BPD 105 is certainly the best Blu-ray player that has been in my system and it truly performs at a much higher level compared to my current player. I decided to write this up because I know some of you, like me, have questions related to the picture- and sound-quality of this player. I hope this helps. -Now I still have to delve into the DAC section and play around with all of the possibilities available there.
post #1242 of 5603
--Bob
When LF/RF output +75dB SPL (which is a function of the Volume setting in the player), and the Sub ALSO outputs +75dB SPL (adjusted using it's own volume knob) then you are good. That means the necessary boost for the Sub has been implemented. Otherwise the Sub would be producing a different level of output.
TECHNICAL NOTE: Due to a room response effect called Room Gain, the Sub's bass output gets a little bit of a boost. 2-4dB is normal. And so it is not uncommon for the most pleasant Sub volume setting to be just a few dB hotter than the main speakers.
If any of the speakers are set to Small in the OPPO then the Sub needs +15dB of boost for everything except for one case. The one case is if you choose to use SACD Output DSD for SACD playback. In that case there is no Crossover processing possible (no audio processing of any sort), and so all speakers are treated AS IF they had been set to Large.
And when all speakers are Large in the OPPO then the Sub needs +10dB boost.
If you want to set some speakers Small, and don't want to have to worry about the special case, then simply use SACD Output PCM instead. If you are going to set all speakers Large anyway, then the DSD case is no different -- +10dB Sub boost for everything.
--Bob
post #1243 of 5603
Bob,
Thanks again for all the information.
post #1244 of 5603
As mentioned, I was able to get a two channel Parasound Halo amp working fine with direct XLR from the 105. I am considering an Emotiva for the other three but was concerned about compatibilty. I checked the specs for each:
Parasound
Input sensitivity:
1 V for 28.28 V, THX Reference Level
Input impedance:
33 k Ω
Emotiva
Input impedance:
unbalanced: 23.5 kohms
balanced: 33 kohms
gain (which I thick is the same as Input sensitivity) is 33 db
So it seems like it may work, but I would need the unbalanced on the Emotiva while using the balanced on the Parasound. I am fine with adjusting the trim within the oppo to fine tune the SPL (I have a SPL meter).
I looked at the Test Report for the 3-Channel Emotiva and it was tested at 1.025V at its input to produce rated power output into 8 and 4 ohms so it should fit your purposes just right.
post #1245 of 5603
Thanks again.
Gary
post #1246 of 5603
Thanks for the nice and detailed review Pokey77 smile.gif...
post #1247 of 5603
Has anyone tried the Sennheiser HD650 headphones with the Oppo BDP=105 headphone output? I would imagine that it delivers sufficient power but just want to check ;-)
Cheers.
Tony
post #1248 of 5603
I am at 200+ hours of burn in and this player continues to sound better and better. Primarily using as my front end in my 2 channel music system but it does some double duty feeding blu-ray's to my living room LCD (I have a separate Home Theater with an Oppo BDP-93). I have already sold most of my prior CD front end (Rega Planet>MSB Full Nelson Link Dac III/MSB Power Base/Nordost Silver Shadow Coaxial) which sounded very good but not close to the Oppo in imaging, soundstage and smoothness. Never mind it was limited to only Redbook CD's. And that isn't even talking about it's added video capabilities which are first rate.
The Oppo is slightly bright at this point but my room is a major challenge (hardwood floors, many windows, cathedral ceilings, open on one side). It certainly improved on the Rega in taming this.
What makes this player special is the vast multitude of things it can do as everyone here knows: I am using the built in headphone amp. Streaming my FLAC's via my network using DB Poweramps Asset DLNA server. Streaming Pandora/Netfix. Have my cable box utilizing the HDMI In to take advantage of the Sabre DAC's. And of course playing CD/SACD/DVD-A & Blu-ray audio. And I just ordered the Roku stick which will utilize the MHL connector and add Amazon functionality.
I love this player and it isn't going anywhere but here are my only complaints so far:
1) Headphone Amp - agree with everyone's assessment's on the headphone amp. Utilizing my HiFiMan HE-500's the sound is amazing but nowhere near enough of it. This problem is more acute with Blu-Ray's. Unless Oppo can find a way to add more output volume in firmware upgrades I am definitely going to need a headphone amp which is an added expense
2) Streaming - no ability to build playlists from your FLAC/high res collection. I have also not been successful getting it to shuffle yet either. Either way improvements in the ability of this player to manage a hi res library would be very welcome. This may force me to adding a PC front end to utilize the Asynchronous USB Dac
3) The C13 power connector does not give the best connection for my power cord which utilizes a C15 (Shunyata Sidewinder VTX).
4) Lack of control/responsiveness from both the player & the remote - Oppo has already replaced the remote once but I am still experiencing issues which I am discussing with them. Very often the controls on the remote and the player do not work. It forces me to power down the system to get those back. Yesterday this happened when I was playing a Blu-Ray and went to the setup screen.
I am hoping I don't have to send this back and this can be fixed in a firmware update. Has anyone else experienced this?
This is a killer media center player for $1200. With a couple of fixes/enhancements it would be a near perfect solution for most people
post #1249 of 5603
Happy to report that the Chris Botti blu-ray was a marvelous experience last night. Video was great but the sound, oh the sound. Fabulous clarity, lots of air, and a wonderful smooth sound.
post #1250 of 5603
It's actually a C14 power inlet on the player - C13 and C15 are the plugs on the cables. A C15 plug should be fully compatible with a C14 inlet as the only difference is the ridge on the bottom of the C15 connector (and C16 inlet) which would prevent a C13 plug from being used in a C16 inlet. The only functional difference is the C13/C14 pair is rated for 70 °C versus 120 °C for a C15/C16 pair. C13/C14 connectors are FAR more common on consumer electronics products as there's really no need for the extra heat rating of the C15/C16 connectors which are typically used for things like electric kettles (for boiling water) and other similar appliances that are supposed to get hot. In all my years using consumer electronics gear, including a number of products from high end companies such as Krell, Proceed, Mark Levinson, Lexicon, etc., I have never owned a product with a C16 power inlet, so I'd be pointing my complaint at the power cable using a C15 connector instead of the FAR more common C13 connector, though there really shouldn't be any fit issues anyway unless the presence of the ridge makes for a slightly looser fit because there's a bit less contact area between the plug and socket.
I don't recall anyone else reporting any issues like this with the 103 or 105. I'd suggest you continue working with Oppo on this.
post #1251 of 5603
GSR - You are correct on the inlet and in line with a response I received from Oppo:
The player was designed to be used with IEC C13 power cables. The inlet is IEC C14, so it should work with IEC C13 or C15 cables.
However the C15 Shunyata hangs halfway out of the C14 inlet and does not give we a warm a fuzzy regarding a solid connection. As a matter of fact I am planning to cable tie the cord to the rack since I have had an instance where it dropped power. I may swap this out for a Wireworld Aurora I have
post #1252 of 5603
Is there any way to connect the 105 to a Power Control port in my receiver?
Josh
post #1253 of 5603
Also, are there any instruction on how to use the 105's remote to control my receiver, or is that not possible?
Josh
post #1254 of 5603
Originally Posted by edwardkim View Post
Read this article which states that industry standard for line level is 0.775V
- http://www.rothwellaudioproducts.co.uk/html/hi-fi_plus_review.html
There are many others articles available via Google which very much state the same - please, help yourself ...
I have an Oppo 95 going direct to Acoustic Energy Pro Sat via balanced XLR. As the voltage output was higher than expected input levels, wrote to my manufacturer. Acoustic Energy support recommended attenuators in this situation.
I went with the Rothwell XLR attenuators. High frequencies seemed to shine better.
post #1255 of 5603
Do yourself a favor and get a RF repeater and an RF universal remote.
IR is for the birds.
post #1256 of 5603
Josh
That's not possible. Use any of the various brands of programmable remotes.
--Bob
post #1257 of 5603
Josh
The 105 does not have a Trigger input to control coming out of standby if that's what you mean. You may be able to use HDMI CEC from the receiver to power on the 105. Look for discussion in your receiver manual regarding remote control of devices over HDMI cables. In the OPPO manual, see the discussion for HDMI CEC.
--Bob
post #1258 of 5603
I've had several instances where the player locked up and needed a power on restart. I haven't yet attempted to document exactly what instances they were and then try to recreate them.
Using IR-same here. Infrequent and haven't bothered to document the circumstances, but cold reboot required.
Thank you very much
Fury
post #1259 of 5603
Cheers.
Tony
I use HD650 cans. The volume is certainly adequate for playing stereo content. If you play multi-channel content, the attenuation that comes with the down-mix to stereo may or may be a problem for you depending on how loud you want to blast your ears. It's not a problem for me.
--Bob
*edited to correct model number*
Edited by Bob Pariseau - 12/16/12 at 9:43am
post #1260 of 5603
There are two "standard" ways to wire XLR. That's why the OPPO includes the setting to select which to use.
--Bob
