Release date: November 20, 2012
Category: Latest Public Beta Release
Main Version: BDP10X-37-1114B
Loader Version: 6U0900 (BDP-103), 7B0600 (BDP-105)
Sub Version: MCU103-05-0916 (BDP-103), MCU105-04-1113 (BDP-105)
1. Added support for "Rhapsody" online music and "CinemaNow" movie/TV streaming services.
2. Added the "Blank HDMI 2" option in the Setup Menu -> Video Setup -> 3D Setting. This allows the player to force HDMI 2 to output a 2D blank screen when HDMI 1 outputs 3D video. Some customers reported that during 3D movie playback, when HDMI 1 was connected to a 3D display and HDMI 2 was connected to a non-3D receiver which in turn is connected to the same 3D display, there was no audio coming from the receiver. This issue has been resolved.
3. Resolved the incorrect aspect ratio (AR) during some user-created media. In the previous firmware the player may have unnecessarily pillarboxed or stretched the video of some user-created media files. This issue has been resolved.
4. Resolved an incompatibility with older Digital Coaxial or Optical receivers where streaming services (such as Netflix, YouTube) produced no audio.
5. Improved the user experience in the HOME menu and the Media Center (Photo, Music, or Movie) e.g., Added Thumbnail View mode for Movie and Music, and the customer can press RED COLOR button to quickly switch between File List mode and Thumbnail View mode.
6. Added "Sleep Timer" option in the Setup Menu -> Device Setup. This allows the player to turn itself off after a specific amount of time.
7. Added support for converting Side-by-Side and Top-Bottom formatted MKV into 3D. During the playback of a compatible MKV, press the 3D button on the remote once to turn on the "2D->3D" conversion then press the 3D button again to display the "3D Setting" menu. Select "Side-by-Side" or "Top-Bottom" to match the source to convert the image to 3D.
8. Added "CD Program Play" function for CD/SACD playback. During the disc playback, press the YELLOW COLOR button to bring the “Program Play” interface. Here you can use the LEFT/RIGHT ARROW button to set a desired playlist.
9. General disc compatibility improvement based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
Special notices:
a) In order to facilitate the user experience improvement in media navigation (item 6 above), the player will create an "OPPO_Media_Info" folder on the connected USB storage device and store media information there. You may find this folder on USB flash drives or external hard drives after using those on the OPPO player. Please do not delete the folder and its files.
b) SD DVD de-interlacing performance is not as good as that of the official firmware release BDP10X-33-1018. If you watch DVD often, we recommend that you skip this beta test version and wait for the next official release, which will fix this problem.
c) You can revert back to the
previous Official release via a USB thumb drive.
