AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 67
post #1981 of 10070
Originally Posted by Pokey77 View Post
Another question. Preface: I have the wireless dongle set up and working fine. Have uploaded the newest firmware and everything seems to be working fine.
So, the question. Shouldn't I be able to see my music files on my computer over this wireless dongle? I thought I'd be able to see my files and play them on the Oppo. As you can tell, I'm not up on computer audio. So, be gentle. Thanks for the help.
And glad to see it is back on topic. Thanks Bob (and to any of you who can explain what I need to do or where I can read about it on the web or in the instruction manual).
I am guessing the wifi is configured properly in your home/wireless network? If you put a CD in the player does it connect to Gracenote and download the album art/details?
Cheers.
Tony
post #1982 of 10070
After lots of reading here and and checking the manual, I am close to pulling the trigger on a 105.
Thanks to all for the many useful postings, and in advance for advice and corrections if I might be getting things confused...
Here is my idea of setting up the 105 in my system:
System:
Replace with the 105: Pioneer 59AVI Universal player (used for redbook and SACD playback)
Replace with the 105: PS3 (used for bluray playback)
Keep : Lexicon MC12B (_not_ the HD version, so it only has analog RCA inputs - one set of 5.1 MCH and other sets for 2 channel.)
Keep : Lexicon LX7 amplifier
Keep: Lumagen + JVC RS2 for video.
I will be using the Lexicon for volume control and distance, level,and room EQ settings. (At least to start with..)
Connections:
MCH: 5.1 Analog outputs from the 105 to one of the Lexicon channels for blu-ray and SACD playback
Stereo: RCA outputs from the 105 to a second Lexicon channel for Redbook playback
Video: HDMI (1) from the 105 to the Lumagen.
Proposed Setup and Questions:
Stereo Outputs: Stereo (Intention is to allow the Lex to apply optional Logic 7 steering or use as 2-channel)
Audio Processing and Speaker settings (for MCH):
Mixdown:5.1
Speaker Sizes : all LARGE (so the Lex handles all subwoofer steering and crossover control)
Speaker Distances : 0 (?? Is this right, I haven't seen how to bypass the distance settings. Trying to be sure here that the Lex calculated distances apply).
Trim: 0 (so the Lex handles all Level control)
Output Volume: FIXED
MCH:
HDMI Audio: OFF
Questions are:
Is it correct to set the Speaker Distances to 0, or is there another way to bypass any distance delay?
If all speakers are set to large and the subwoofer is connected in 5.1, is it correct that only the LFE (.1) channel is presented on the subwoofer analog output?
Is it right to set the Stereo Outputs to 'Stereo' in this case, or is there some advantage to using LF/LE?
Am I missing something? This setup is a bit archaic, I know, but for now I'd like to keep the Lexicon in the heart of the system..
post #1983 of 10070
Cheers.
Tony
Yes, it works fine.
post #1984 of 10070
If you set the Speaker Distances to 0, then the player is doing no time delay for the speakers.
If you have the speakers set to LARGE then the player will only send LFE to the subwoofer.
You will leave it as Down-mixed Stereo to ensure that your speakers get all the Center, Surround, and Surround Back information which may be on the soundtrack.
post #1985 of 10070
You have to be running a DLNA or SMB server somewhere on your network. Do you have anything like that working?
-Bill
post #1986 of 10070
Yawn, boring....LOL
post #1987 of 10070
I have a Lumagen, and it is still in the rack, but since getting the 105 I've been driving our monitor directly. Why do you want to keep the Lumagen in the signal path? No offense intended against Lumagen--they've been a great company--but without it the HDMI handshake is virtually instantaneous, and the video processor in the Oppo is superb.
post #1988 of 10070
No offense, an excellent question.
The reason is that the Lumagen is doing gamma and color control for the RS2, which does not have its own CMS, and did not have the best out of the box color accuracy. I had it calibrated by Tom Huffman back when I lived on the East Coast.
Eventually the video path will be updated too, but that's another project! (And yes, sometimes the handshakes are tedious and glitchy looking with the Lumagen... It has been several years since I touched the settings or firmware on that box).
I will try the experiment though. It should be fun to see what the pj looks like with the Oppo direct-driving it.
post #1989 of 10070
Does anyone have experience using the three MAC compatible audio players HDTracks suggests:
1. Amarra
2. Decibel
3. Pure Music
Can these players be used to play FLAC files on a server (external HD) connected to the USB DACs on the 105?
I'm very interested in the USB DAC playback option on the 105, but not sure of the best way to take advantage of it.
post #1990 of 10070
-Bill
Bill, I've read about those accronyms here, but really have no idea what they mean. I'm using Windows 7 if that helps.
post #1991 of 10070
Perfect. Thanks!
post #1992 of 10070
have you tried foobar2000 for mac?
post #1993 of 10070
No, I'm just getting started in server based music files, and my 105 doesn't arrive until Wednesday. I've seen a few on here that use it, and it's on my list to try. Whatever I use, I want to make sure it's bit-perfect.
post #1994 of 10070
I searched every way i can think of, but apparently foobar only works on windows, and I'm not going to partition my drive and set up a dual OS or whatever I would have to do to make that work.
Anyone have any other suggestions?
I downloaded songbird, and it sounds pretty good via headphones on my MAC, but not sure how it will sound, or if it will control the files when on an external HD.
Pure Music looks like it could be the solution as it seamlessly integrates with iTunes and play FLAC natively. It's not cheap though at $130.
Edited by boyce89976 - 12/30/12 at 7:25am
post #1995 of 10070
Originally Posted by Real View Post
Thanks Steve, but there are more posts after this one. I am using Split A/V with HDMI 1 to the TV and HDMI 2 to the pre pro. A puzzle or a bug................
Ah - yes, you found out that the pre/pro needs to be also powered on. smile.gif
post #1996 of 10070
From the Home Menu on the 105, browse to the "Network" icon. There you should see your available servers running from your Network.
post #1997 of 10070
What is the best place to look for reviews (or customer feedback/ratings) of the different region-free kits and other mods for the BDP-105? Just searching on google, I've found a bunch of different mods, including those that you send your player in for modding, and I'd be interested in reading about the pros/cons of different mods. Thanks!
post #1998 of 10070
-Bill
The wikipedia has good overviews.
The FAQs in my signature have DLNA sections; the BDP-83 FAQ has "What is DLNA?" which I didn't copy into the -103 FAQ.
SMB is network file sharing. It is built in to Windows, but requires some incantations to get working.
-Bill
post #1999 of 10070
Check out the Getting Started With Computer Audio Part 1: Hardware information at Audiostream.com. This should give you some useful background information.
Hope this helps.
Cheers.
Tony
post #2000 of 10070
Pokey77,
I dont usually give advice here but I did a lot of experimenting to get my files to be accessed by the OPPO. Assuming you have wifi and DLNA working correctly, you will have to go about enabling file sharing. In my quest to do this on my Windows 7 laptop, I rightclicked everything starting with my attached hard drive and shared with EVERYONE. I even had to at times (I don't know why as I don't understand these things either) point to the file with my music and right click to share it EVERYONE again. This seems to work. I would hope that there will be a comprehensive FAQ just for OPPO eventually. There may even be one but I spent many days experimenting until I got it right. I hope I have contributed some as I get a lot of info myself by just listening to others.
Dave
post #2001 of 10070
stupid noob question,
could i use this as a preamp on my pc with powered speakers and powered sub while utilizing the usb dac?
post #2002 of 10070
You could but I wouldn't recommend it as you would be using the Oppo to send your PC either an analog or a digital signal which would then be using the soundcard/DACs in the PC to output to the speakers/sub.
Cheers.
Tony
post #2003 of 10070
A quick question.....i download tvmobili on my I-mac to access my itunes library on the Oppo. I was able to navigate all of my albums, but only some would play. If you selected a particular artist, the blue play icon would appear but just continue to move down the list and pick up only certain ones to play. I assume that it may have to do with the type of download it was in itunes? Thanks for any help!
post #2004 of 10070
Originally Posted by davehale View Post
Pokey77,
Dave
Be very careful doing that as you could potentially open up your computer/network to anyone. Best method is to share only a public folder where you put all your music. Check out instructions from Microsoft on file sharing essentials on Windows 7.
Hope this helps.
Cheers.
Tony
post #2005 of 10070
It is to do with the type of Codec. H/W a list of those supported/unsupported from the excellent FAQ.
Hope this helps.
Cheers.
Tony
post #2006 of 10070
The OPPO will not play Apple Lossless (ALAC) files, nor anything protected by DRM. If your server can transcode the files to some supported format you can get around that, but I don't know the details of tvmobili.
-Bill
post #2007 of 10070
Originally Posted by Bob Pariseau View Post
THERE IS A BUG AFFECTING THE "STEREO SIGNAL" SETTING IN THE 105 -- THERE IS ALSO A TEMPORARY WORKAROUND
So for my 5.1 Analog test configuration, I've taken to checking with the Test Tones on each power up, and doing the Workaround then and there if the problem is present.
Note that this problem only affects the analog audio outputs, and, since there is no similar stereo hardware or Setup setting on the 103, it is a 105-only problem.
In your case, you are suffering the opposite problem. You have DOWN MIX STEREO set but it appears to be operating as FRONT LEFT/RIGHT so that you ONLY hear the LF/RF content in the Dedicated Stereo Analog outputs.
I think the odds are excellent you've been bitten by the same problem, but I've not actually produced that case in my own testing so I can't be sure.
In any event, you should try the same Workaround -- change Stereo Signal to FRONT LEFT/RIGHT and then immediately back to DOWN MIX STEREO -- and see if that cures the issue, at least until it gets triggered again.
As I said, I've presented OPPO with a 100% reproducible case of this problem, and OPPO Engineering is on the case.
--Bob
Thanks, Bob.
I have been experiencing some issues also with the analog outputs. Your test tone idea sounds like a good way to verify some of the behavior. I tried it and everything seems OK for the moment on my setup except for the Stereo Downmix; when I listen to the dedicated stereo outputs set for Downmix, I hear all Back Channel and Center test tones coming from the L/R fronts as expected, but I hear nothing from the Sub test tone. However, when playing 5.1 sources, I'm fairly sure I'm getting full range from the Downmix, but I'm not sure about any LFE sound. Maybe this is normal - if the Downmix occurs before any bass steering (makes sense not to run it through the x-over filters, then recombine), but what about LFE (even though most 5.1 audio mixes do not use the LFE, but some do). Shouldn't I hear that SUB test tone in the Downmix outputs?
Steve
post #2008 of 10070
That could actually make for a really hi-end PC / Office sound system setup: PC using the USB DAC, and then you could also play discs or any other sources you wanted to. PC USB Out--->Oppo USB DAC IN--->Stereo/M.Ch. Power Amp--->Speakers (or straight to some decent powered speakers). And you could probably get PC HDMI--->Oppo--->PC Monitor as well.
If this thing would have been out a year ago, I'd have probably tried that in my office.
post #2009 of 10070
NewToHifi, are you saying that you want your computer to do digital conversion and then send analog out of computer to the oppo? If so then no. However i can't help but think that the oppo would definitely have a better digital to analog conversion than your computer. Could be wrong. ideally you would just send your signal via usb or network sharing to the oppo and have it do the conversion to get hifi sound. Then the oppo will allow you to connect your powered equipment.
post #2010 of 10070
Yes, this did it. So it is the handshake. Do you suppose this could be altered in a firmware update, or not?
At my age I do not have golden ears, so it does not really matter that much. But is there a consensus concerning whether there is any sonic difference to direct DSD processing or processing only after conversion to PCM (in the 105 or anything else)?
