Yes, same for the 95,93 and 103. They all have low output impedance of under 200 ohms plus very fine volume controls within their respctive DACs...
Featured Stories
Topics Discussed
Related Forum Threads
- Oppo BDP-105 Last post on 5/2/13 at 3:07pm in Audio Gear
- Oppo BDP-105 SABRE32 DAC vs Denon 4520 built-in via Airplay Last post on 4/30/13 at 2:34pm in Receivers, Amps, and Processors
- OPPO BDP-103 OR OPPO BDP-105 Last post on 4/28/13 at 9:07am in Display Devices
- Can the Oppo BDP-105 be used as a "preamp" direction with an Odyssey Stratos Amplifier?... Last post on 4/14/13 at 7:11pm in Blu-ray Players
- Audio & video out of sync when going through Oppo BDP-105 Last post on 4/12/13 at 6:19pm in Blu-ray Players
Official OPPO BDP-105 Owner's Thread - Page 8
Gear mentioned in this thread:
- dmusoke
- Trader Feedback: 0
- offline
- 2,025 Posts. Joined 7/2009
- Select All Posts By This User
The Perils of Pauline's Blu-ray Player! -- Episode 1: "Secrets Reviewed!"
http://www.hometheaterhifi.com/universal-players/universal-players-reviews/oppo-bdp-105-universal-player.html
Do you like a good, cliff-hanger serial? Sure! Who doesn't!
Secrets of Home Theater has decided to publish their new review of the BDP-105 in INSTALLMENTS!
The start of the review is up now. Stay tuned for each new, exciting episode!
--Bob
Arrrggg!!! What a teaser
I'm on my sixth day using my 105 and I've been very pleased with its performance. I've run a lot of disc media through it and its done a stellar job. This is my third Oppo after the 980H and 83 and a steady stream of Blu-ray, HD-DVD, and DVD players over the years. The 105 is at the top of the heap except for one thing which I don't know whether can be rectified or not.
Using the headphone amp with my beloved LCD-2 and beloved Sennheiser 800 headphones I just can't get the volume to the level that I want for Blu-ray movies. I'm at 100 on the volume meter and I need more volume. Redbook CDs play loud enough (which I have at about an 85 volume), but I just want to turn on my TV and then plug into the 105 for some late night movie viewing and I'm found wanting. I know that my headphones are hard to drive, but is there any work-around or solution for me so that I can gain about 10 or 15 "clicks" on the volume meter?
(I'm not asking for much--just a 10% increase on the headphone volume
)Thanks for any thoughts or solutions.
Pretty sure the peeps be modding their Sennheiser cables with XLR connections and running right out of the balanced back end of the Oppo.
Check on head-fi in case I've lost it though ....
- bakerwi
- Trader Feedback: +3
- offline
- 2,659 Posts. Joined 7/2008
If the results of my work meet my expectations:
The 103 will be a FANTASTIC machine for ~$1K, that will perform very well for audio, both 2CH and MCH and will be improved in both its performance as a video player and a transport for feeding digital audio to a pre/processor.
The 105 will be a WORLD CLASS player AND DAC, with our tube analog stage, for < $3500 and will perform at the $10K+ range ABSOLUTELY! We may also offer an upgrade option to the SMPS that will further improve video playback! I will investigate a SS mod for the 105 that is likely 1/2 the price of the tube mods.
I wonder if he has he come across a sub $2K transport that he couldn't improve upon?
Edited by bakerwi - 11/21/12 at 5:51pm
- Franchot
- offline
- 1,521 Posts. Joined 3/2001
Note that if you Track Back to restart the first track, it won't happen at that point because the digital audio stream is already established. This is all tied up with the complexity of the HDMI handshake, so anything that causes HDMI retries makes it more likely you'll encounter this -- i.e., HDMI cabling issues or issues in your AVR/Display responding to the handshake.
I.e., whatever you do to improve your HDMI performance (reduce retries) will also help eliminate this issue on music discs that start the first track instantly at time code 0. Consider setting HDMI Audio OFF if using Analog output.
--Bob
I have this problem with my 83, but have not experienced it at all on the 105. I also have the "Auto Play Mode" set to OFF . Might this help to alleviate the problem?
(And thanks, Bob, for your reply about the headphone volume that I asked about.)
- Bob Pariseau
- Read the FAQ!
- offline
- 24,243 Posts. Joined 7/2004
--Bob
It is possible that with Auto Play ON the Display (in particular) may not be fully awake yet when the music disc initiates the HDMI handshake during the disc load on Power UP. However, that would not apply to discs you start after everything is already powered up.
So I suspect the difference you've found between the 83 and the 105 is simply that the 105 is faster.
--Bob
- BillP
- offline
- 13,494 Posts. Joined 8/2003
- skriefal
- offline
- 781 Posts. Joined 1/2000
That was a few hours ago. I just tried again and things now seem to be working as expected. Fingers crossed...
- Bob Pariseau
- Read the FAQ!
- offline
- RickS
- offline
- 789 Posts. Joined 8/1999
Well I got the 105 today and installed it into the rack tonight. I'm sitting listening to music CD's and am very shocked at the great improvement in the quality of music in my system. Will give it a few days burn-in. I have been using BD players mostly for home theater use but I can see going back to audio. WOW!!!
Here are a few pictures. I'm using a Denon AVR-5308CI for a pre/pro and Verastarr SS64 for bi-amping front VMPS-40 modded mains with stereo SVS PB13 Ultra's. I have a Parasound HCA-2205A for surround duties.- dmusoke
- offline
My mistake indeed ... I talked to him and he said he plans to improve the power of the headphone amplifier, giving it more output power as well as benefiting from the tube sounds.
- Bob Pariseau
- Read the FAQ!
- offline
- dmusoke
- offline
Hi,
Does the rack mount kit make the 105 a full 3U height unit?
- RickS
- offline
- dmusoke
- offline
- dmusoke
- offline
Please forgive my cluelessness but I'm really puzzled as to why folks would connect their cable or sat boxes into the 105 HDMI inputs. Is their AVR or sat_box upscaling/de-interlacing performance so bad that they must use the Oppo instead??? Now to watch TV, you must first turn on TV, then bluray player, then AVR
???. Most newer satelite and cable boxes(past 5 years at least) actually have rather excellent scaling and de-interlacing chips(Broadcom BCM 74xx series). In my MOXI HD box, i tell it to output only 720p & 1080i video streams. 480i streams from SD channels are automatically upscaled to 1080i by default. I feed the Moxi output into my Anthem D2v which upscales everything to 1080p and the visual results are excellent especially on well recorded programs such as the 700 Club and many others. Yes, badly recorded programs still remain bad but that is the fault of heavy compression (and re-compression) by the sat/cable providers. Actually the TV networks produce a high quality stream but it is re-compressed like heck by the service companies so that they may cram more channels into their pipe,
Obviously, I must be missing something here so i hope to be schooled(gently ofcourse
) by those who use the Oppo like this.
Happy and blessed Thanksgiving to all Oppo-ites
- David
I am the happy owner since its release of a BDP-83, then upgraded ingto 83SE. I eagerly consider the purchase of BDP-105 to add streaming capability lacking in 83SE (very limited file compatibility). But I'm really curious about the quality of stereo sound (through balanced XLR) compared to that of the 83SE, any comments?
As I look at some pretty upscale audio equipment and consider Lynn Akurate DS plugged into an external DAC like Berkeley Alpha DAC 2.
I wonder if using the oppo as a streamer connected to the Berkeley DAC would give the same sound quality as with the Lynn? (or whether the oppo by itself is soulding close enough?)
And can anybody comment on the audible difference between the 105 and the combination 103 + a very high quality DAC?
FYI I use Belcanto Prepro preamp, amp Belcanto evo6, speakers piega P4MKII, and Nordost red dawn cables in between.
Thank you in advance for your thoughts!
I would rate the Linn Akurate DS best with a 10. 2nd and very close was an Audionet CD player (german high end brand) with a9.5; 3rd Linn Majik DS 8pts; 4th Naim Nd5 XS 7pts; 5th Oppo 95 with 5pts; 6th Marantz 7001KI 3 pts; 7th Marantz Sr9600 DAC 2pts. Overall all tested equipment was very good and I believe that if you do not directly compare; it is hard to find out what is what. I would be very interested where the 105 fits into this list. Hopefully it closes the gap to the Linn DS'S
I had the chance to compare the 95 with a few players.
I would rate the Linn Akurate DS best with a 10. 2nd and very close was an Audionet CD player (german high end brand) with a9.5; 3rd Linn Majik DS 8pts; 4th Naim Nd5 XS 7pts; 5th Oppo 95 with 5pts; 6th Marantz 7001KI 3 pts; 7th Marantz Sr9600 DAC 2pts. Overall all tested equipment was very good and I believe that if you do not directly compare; it is hard to find out what is what. I would be very interested where the :cool:105 fits into this list. Hopefully it closes the gap to the Linn DS'S
All things considered the Oppo at that price seems like a fantastic challenger and I believe if it beats the Naim then I have a winner.
(notwithstanding the fact that if I connect the 95 with a DAC I may have a system better sounding than the Linn Akurate...)
Thank you very much for your inputs. I would say this is pretty much what I expected, with the added benefit of your part mentioning "if it were put next to each other it would be hard to discern"... unfortunately that's for me the biggest challenge in very high end audio and that's why I genuinely believe finding the right price point considering all factors including your room size, wall/floor materials and soundproofing quality is paramount.
- gsr
- Oppo Beta Group
- online
- 6,538 Posts. Joined 4/2001
- sac8d4
- Trader Feedback: +2
- offline
- 443 Posts. Joined 9/2007
Please forgive my cluelessness but I'm really puzzled as to why folks would connect their cable or sat boxes into the 105 HDMI inputs. Is their AVR or sat_box upscaling/de-interlacing performance so bad that they must use the Oppo instead??? Now to watch TV, you must first turn on TV, then bluray player, then AVR:confused: ???. Most newer satelite and cable boxes(past 5 years at least) actually have rather excellent scaling and de-interlacing chips(Broadcom BCM 74xx series). In my MOXI HD box, i tell it to output only 720p & 1080i video streams. 480i streams from SD channels are automatically upscaled to 1080i by default. I feed the Moxi output into my Anthem D2v which upscales everything to 1080p and the visual results are excellent especially on well recorded programs such as the 700 Club and many others. Yes, badly recorded programs still remain bad but that is the fault of heavy compression (and re-compression) by the sat/cable providers. Actually the TV networks produce a high quality stream but it is re-compressed like heck by the service companies so that they may cram more channels into their pipe,
Obviously, I must be missing something here so i hope to be schooled(gently ofcourse:p ) by those who use the Oppo like this.
Happy and blessed Thanksgiving to all Oppo-ites:) !
- David
I don't have an HDMI capable set up (receiver) so I'm using the Oppo as such, gentle enough?
by the way I disconnected the Oppo for half an hour and cleaned the memory and all seems to be working including the trimming feature, hoping it continues to perform.- Torqdog
- Audio Junkie
- offline
- 948 Posts. Joined 5/2010
I know many of you are still wanting feedback on the BDP-105 vs BDP-95, as with every other OPPO i have owned in the past ( DV-981HD to DV-983H, BDP- 83 to BDP-83 SE Nuforce Edition, BDP-95 to BDP-105), Oppo has found away to make improve upon their previous players. Only referring to (analog) audio quality,the margin of improvement is less and less with each Oppo product. Now on to the specific audio qualities of the BDP-105....As various others have reported, the bass does appear to be improved over the BDP-105. To my ears the bass could be described as less "boomy", which makes it seem that that Oppo was able to dig down and reproduce a few octaves lower compared to previous Oppo products. Additionally, the upper octaves seem to have more energy on top. I know many will read this and will think, Bdp-105 is "bright" sounding, but that is an inaccurate description. For those of you that are concerned with the lack of DAC stacking in the design of the BDP-105, this isn't something you will even notice sonically. In fact, I would say that the improved analog path has helped with the sound of this machine. Conservatively, I would quantify the amount as 0%-5% increase in sound over the BDP-95. (I am only referring to the discrete stereo connections, XLR and RCA) Those of you that are on the fence and simply want to purchase a universal player that sounds leaps and bounds better than the previous flagship Oppo player, this may not be the player for you. However, this the best sounding Oppo player to date and has so many important features on the audio side of the house(such as the use of this player as a DMP and USB Asynchronous DAC), that is what sets this player apart from other universal players on the market as well as other Oppo players.
Thanks for the review.
- David
In my case I'd like to get the AV Receiver/Processor out of the mix entirely - the 105 is allowing me to do that.
HDMI from my cable box goes into the HDMI input on the back of the 105.
My old processor (Arcam AVP700) was nice sonically but didn't do any upscaling of video - it just had HDMI switching/passthrough capabilites.
To play records I might shim an analog pre-amp with Hometheatre passthrough into the mix at some point.
- Sharp1080
- offline
- 1,425 Posts. Joined 8/2000
- Brian-HD
- offline
- 2,137 Posts. Joined 1/2008
Seems identical to the 95 with improvement to 0-5%
I should have my 105 this afternoon, I currently have a 103 and a decent outboard DAC (MSB) which I find to be better than the stock 103 (which I still think is good but not exactly my tastes). I will add my comments about the 105 and compare stock stereo RCA outputs vs my outboard DAC. Really hoping the 105 blows my old MSB DAC away so I can get rid of some equipment!
So I got my 105 last night and wanted to post my initial thoughts before heading to Grandmas for Thanksgiving. Here is my system for those who are curious
Conrad Johnson LS 17 Pramp
Conrad Johnson 2300A Amplifier
MSB LINK II DAC (slightly modified)
Vandersteen 3A Sig with 2Wq subwoofer
Oppo 105
Oppo 103
So I was expecting to play the 105 against the 103 and see if I could hear a difference. After initially playing the 105, I didn't bother...the 2 channel 105 is a significant improvement in dynamics and lower end bass definition that I was hoping to hear. My only hesitation is that against my DAC it isn't as clear which is better. The most difficult issue I face in doing an A/B has to do with the line output levels, the Oppo is about three or four clicks quieter than my DAC so when switching between inputs, I have to turn the volume down and up in order to compare.
I am for sure an 80/20 kind of person so after the 105 has settled in I will do a more thorough listening session....but I really need to justify the price difference and if I really can hear it...I suppose trying SACD and other formats that can't be output to my DAC in HiRez will also help to my review.
So far both units are great, playing Pandora last night actually sounded pretty good. This is my first multimedia center unit, so I am finding myself immersed with new content and listening to things I wouldn't have been exposed to before since I never liked digital over internet sound quality until now.
1. Their sensory perceptions are incapable of differentiation.
This isn't meant as an insult. I've had friends and family members who haven't noticed any differences at all between components whereas some say the difference is "night and day". Lucky for the people that can't notice the difference as they can be happy with a ghetto blaster and save a ton of cash.
2. Their system is incapable of differentiation.
This could be due to a number issues. There are a lot of components between the source and the final sound heard by the listener and any can degrade the sound considerably.
The most common I've found is overly complex passive crossover networks which "filter" and degrade the sound sometimes rendering a very high quality source such as the Oppo to just "average". For example I have two systems. One is capable of taking full advantage of a very high quality source such as the Oppo 105 and the other is not. On the secondary system, the Oppo does sound a little better than some of the inferior dacs. On the main system, the differences are like "night and day". Also price has a sparse relationship to sound quality. I've heard a pair of $4000 single driver speakers sound much more "refined" than a pair of $180,000 speakers. So if you can't hear much difference between the Oppo and another DAC/squeezebox etc then don't blame the Oppo look elsewhere within the system...
Over the next few weeks, I'm going to do the following:
1. compare the Oppo to a variety of pre-amps in the $150-$15k range and decide whether the Oppo sounds better standalone or with a preamp.
2. Compare the Oppo to a variety of external DACs in the $500-$15k range to determine where the Oppo fits with differing priced dacs.
3. Compare a variety of amps with differing input impedance to determine whether it is a "true preamp". Despite the "theory" it should work, this needs real life testing as I've had mixed results in the past.
I hope other people post their comparisons on the above items as well so we can get a feel of where the 105 ranks in the grand scheme of things.
I've also found this unit needs quite a bit of burn in time. I've been burning this in 24/7 since I got it and it took a long time to settle down. Plugging it in on arrival and then firing off a review after an hour or so is doing this unit a disservice in my opinion.....
Edited by djkiwi - 11/22/12 at 10:39am
- dmusoke
- offline
Never thought of your scenario Luis, thanks. But what were you using before the 105? Component video / RCA audio from your cable box to your receiver?
- Official OPPO BDP-105 Owner's Thread
Recent Discussions
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 48 seconds ago
- › The OFFICIAL JBL Owners Thread 57 seconds ago
- › plasma....it's just not that good. I'm not trolling! 1 minute ago
- › Samsung UNXXF6400 Thread 3 minutes ago
- › Ofiicial Sony XBR-55X900A / XBR-65X900A Anticipation Thread (... 3 minutes ago
- › MITSUBISHI HC5, new 3D SXRD projector based on HC9000 2500 euros 3 minutes ago
- › Sony XBR-HX950 Owners' Thread (XBR-55HX950 and XBR-65HX950) 4 minutes ago
- › Greenville, SC - HDTV 4 minutes ago
- › Star Trek 2 4 minutes ago
- › Need some help building a home server 4 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
