AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 98
post #2911 of 5543
Originally Posted by TrebleClef View Post
Originally Posted by Bob Pariseau View Post
Yes, the 105 can play 5.1 FLAC 96KHz 24-bit music files -- both from an attached hard drive and over your in-house network.
People have reported some issues with a type of meta-data sometimes found in them which rejoices in the name "ID.3 tags", which are not really SUPPOSED to be in there, I gather. (They are actually for a different file format.) There are evidently easy ways to strip those with utilities if needed.
Quite a few of the posters here are happily using multi-channel FLAC files, so I expect some will pop up with answers if you need more details. --Bob
So, if using the highly heralded OPPO DAC, we must add a Processor down the chain to get multichannel, correct? The OPPO DAC only delivers 2.0 audio.
I understood UPTHREAD (yes, I've read the entire thing), that this in some way would compromise or circumvent the high quality output from the onboard OPPO DAC.
Still learning....Thanks.
I didn't want to quote all of your posts, but it looks like you are still getting your head around how the audio works. Not surprising, as it can certainly be confusing.
First off, if you are listening to the Analog outputs of the 105 then you are using the fancy DACs in the 105. Always.
The DACs are "Digital to Analog Converters". Their job is to convert a digital audio stream into Analog audio for output on the Analog audio jacks. No matter HOW you play audio on the 105, if you are listening to its Analog audio output jacks (including the Headphone jack), then you are listening to the output of its fancy DACs.
Now, the audio you are trying to play is recorded digitally in one of various file formats. To play audio, the file you select has to be decoded from its file format and "rendered" into a simpler digital audio stream that can be handled by the DACs in the 105. This is where your confusion comes from as there are multiple ways to do that.
The simplest way is to play a shiny disc or select a file off a hard drive directly attached to the OPPO. When you do that it is the *OPPO* which decodes the file format, renders that into the appropriate digital audio stream and directly passes that to its DACs to generate Analog audio output.
The OPPO is capable of playing numerous music file formats this way (but by no means every such file format in existence), including multi-channel file formats up to 7.1 channels at 192KHz 24-bit.
Directly attached hard drives are attached using the "normal" USB sockets of the 105 -- not the special, Asynchronous USB DAC Input.
Another way would be to play the file on your computer -- as for output to speakers directly attached to the computer.
When you do that is it the *COMPUTER* which decodes the file format, renders that into the appropriate digital audio stream and directly passes that to ITS OWN DACS -- DACS in the sound card in the computer -- to generate Analog audio output to the speakers attached to the computer.
But as you can imagine, many people are not satisfied with the quality of the audio when they do that. No matter how good a program they use in the computer to decode and render the audio file, they are limited by the quality of the analog output stage of the computer's own sound card -- the DACs installed in the computer.
And THAT is where the Asynchronous USB DAC Input of the 105 comes into play. Because if you run the appropriate USB cable from the Computer to that USB DAC Input of the OPPO, and have the appropriate driver in the computer, the OPPO can REPLACE the sound card in the computer! It is still the computer -- more specifically whatever sound playback program you are running in the computer -- which decodes the music file and renders it into the appropriate digital audio stream. But now instead of sending that to the Computer's own sound card it is, instead, sending that stream out the USB cable to the Asynchronous USB DAC Input of the 105 -- which sends it directly to the fancy DACs in the 105 for conversion to Analog output on the 105's own Analog output jacks.
That connection -- that very special connection for replacing the function of the sound card in the computer -- is limited to 2.0 LPCM 192KHz 24-bit.
That is, even if the computer software was capable of playing a multi-channel audio file (decoding it and rendering it into more than 2.0 channels of digital audio) -- the Asynchronous USB DAC Input of the OPPO can still only accept 2.0 LPCM input. The OPPO can replace a STEREO sound card in the computer but not a multi-channel sound card.
So if you want to play multi-channel audio, you DON'T DO IT THIS WAY! Instead you get your audio into a music file format the OPPO knows how to decode and you get the FILE into the OPPO -- not a digital audio stream already rendered by some music playing software on your computer.
SO, perhaps it is not convenient to get your music files onto a shiny disc or onto a directly attached hard drive. And perhaps you need to include the flexibility to play multi-channel audio.
In that case you need to explore the in-house, network playback options in the 105.
These come in THREE flavors:
1) The 105 can access "SMB Shares" which you set up on a server on your in-house network. Once connected to the SMB Share (over your house network), the OPPO lets you browse it and playback files from it basically the same way as if it were a directly attached hard drive.
2) The 105 can access files offered up by a "DLNA Server". A DLNA Server -- software that runs on a file server on your network -- presents music files in a somewhat trickier fashion. That's because the typical DLNA server can be configured to understand what the OPPO can decode, and can "transcode" other music file formats into something the OPPO can handle. There are other services that DLNA servers provide such as formatting/sorting your file lists and presenting additional meta-data to the OPPO such as album art. There are lots of different DLNA server programs out there -- some free, others you buy -- and all of them will have a learning curve in terms of how you install them and configure them for most convenient use. But the actual playback of music is very similar to playing files from a directly attached hard drive. You browse the files using the OPPO's own, on-screen browser, and select which file you want to play next.
3) The 105 can ALSO serve as a "DLNA Digital Media Renderer". Again this involves a "DLNA Server" set up on some file server on your house network. But this time it is the DLNA server that finds the OPPO and *SENDS* files to it to play! Note the difference from attached hard drive playback or (1) and (2) above: You no longer use the browser in the OPPO to find the files you want to play. Instead you use the facilities of the DLNA server itself to select files for playback which get SENT to the OPPO. The piece of the DLNA server that lets you do this is called a "DLNA Digital Media Controller", and the latest advance in such stuff is Digital Media Controllers that let you use a separate device for doing the control -- such as an Apple iPad.
You'd be forgiven for thinking that (3) -- Digital Media Render playback -- is the same thing as using the Asynchronous USB DAC Input, which is where we began above. Once again it is the computer (or a separate device like the iPad) which is being used to select the file to play, and the computer -- or the DLNA Digital Media Controller, to be precise -- which is sending the music to the OPPO.
But there's a major difference: In Digital Media Renderer playback it is THE FILE which is being sent to the OPPO. It is the OPPO which is decoding that file and rendering it into the appropriate digital audio stream for sending to the DACs in the 105. So for example, you can play multi-channel files this way.
Contrast with the use of the Asynchronous USB DAC Input, where it is the Computer which is decoding and rendering the file and the resulting, rendered, DIGITAL AUDIO STREAM (*NOT* the original music file) which is being sent into that input and thus straight to the OPPO's DACs.
And that last bit is also an important difference. When using the Asynchronous USB DAC Input, the digital stream goes *STRAIGHT* to the DACs in the OPPO. Thus there is no chance for the OPPO to do any digital audio processing on it before the DACs do their thing.
But when you play *FILES* via a shiny disc, or via a directly attached hard drive, or via an SMB Share, or via a DLNA Server, or pushed to the OPPO by a DLNA Digital Media Controller, it is the OPPO which is decoding and rendering the file -- and thus all of the OPPOs audio processing features are available to adjust that audio before it gets -- as the last step -- sent to the 105's DACs for conversion to Analog output.
--Bob
post #2912 of 5543
Originally Posted by Torqdog View Post
Originally Posted by Doug Blackburn View Post
Uh, yes, your eyes ARE lying to you.
I don't like posting "contrary" opinions, but this thing (HDMI cable vs video image quality) is backed-up with measurements (which I've been doing since 2007 when I was very surprised to find that no HDMI cables made video images look better or worse) and statements from cable manufacturers which just doesn't happen unless they are certain.
This may come as a shock but I totally agree. I finally had a chance to do some A/B testing using the Spears and Munsil disc and I could NOT see any difference between the cables.
I will try very hard to avoid saying words to the effect, "I Told You So!" biggrin.gif
--Bob
post #2913 of 5543
Are you running the latest firmware? Check Setup > Device Setup > Firmware Information. Your "Main" firmware version should end 1220.
How are you connected for audio output when the problem happens? Are you using the multi-chanel Analog outputs? Are you also using Dedicated Stereo Analog outputs in place of the normal LR/RF output pair of the multi-channel Analog outputs (i.e., Stereo Signal = FRONT LEFT/RIGHT)?
What does the on-screen music playback graphic say is happening when the problem happens? For example, for SACD it will display whether it is playing the 5.1 or the 2.0 layer.
--Bob
Hi, Bob. Yes to about everything!
Have latest firmware.
Using RCA analogue outs including the Dedicated stereo RCA
The player screen indicates it's playing the multichannel program.
Weird issue. Inconvenient but at least there's an easy work around. Hope it's something that will be resolved in future update.
post #2914 of 5543
Streaming using JRiver MC to the 105. I have some 24/192 files that play as they should via regular usb hook-up of a hard drive. However, even though I have JRMC set up to output 24/192, 48 kHz is all I get. PC with Windows 7. Does anyone know why it is being down-sampled?
post #2915 of 5543
Originally Posted by drumgail View Post
Hi;
I purchased the Oppo -105 as soon as it became available, my set up is running the Oppo out of HDMI 1 into my Onkyo TX-VR 809 Receiver, then HDMI out of the audio receiver into the TV (Sharp LC-60LE632U) for my video, should I run the HDMI out of the OPPO straight into the TV? If I do this, what is done about the audio for the Receiver?
I was also trying to run HDMI 2 out of the Oppo into my receiver for audio for my DVD-Audio and SACD playback because I have several discs and love the DSD sound, doing this, I had no sound coming out of HDMI 1 using the HDMI AV Split setting, I got audio when I went to the Dual Display HDMI setting, I got 2 different responses from Oppo when I talked to them, one was that by using the Dual Display setting I am not getting the best audio possible, another was that it was ok to use the dual display setting, I want the best audio on HDMI 2 and the best Video/Audio on HDMI 1.
I bought the Onkyo because of the DSD decoding capabilities. By using the HDMI 2 output instead of going analog out of the Oppo am I shortchanging the sound possibilities? Should I not be concerned about the DSD decoding in the Onkyo and just run analog cables? I believe the Onkyo does the DSD decoding over the HDMI, not sure if it will decode it over analog cables. Does the analog quality outweigh the HDMI DSD method?
If I go strictly HDMI, I am trying to go best possible Video for HDMI 1 and best audio for HDMI 2 but to use the AV Split setting, it would force me to pull out the HDMI connection in the back of the Oppo out and move it when I want to play blu ray and when I wand to play SACD which is inconvenient, The Oppo Tech said just leave it in HDMI 2, that the video improvement would not warrant the inconvenience, saying that the only difference on HDMI 1 is Contrast Enhancement, Noise Reduction and 4K capabilities.
I recently sold my home and moved into a new one, my basement man cave in the new home will not be finished until I get more funds, unfortunately I had to leave much of my home theater as well as my old PSB Stratus speakers as part of the selling price of my old house. I am currently using for my living room setup: Onkyo TX-NR 809, Wharfedale Diamond 8.4 for fronts, Wharfedale Diamond 10 CS for center, 2 JBL ES250 12" for Subs and my wife made me put speakers in the ceiling for aesthetics for surround, I think it is Dayton Audio Ultra Series, Acoustic Research AR-1 turnatable and now the Oppo-105.
What should my suggested setup and settings on the Oppo be? Not ready to run separate amps into Oppo, but should I go analog out for SACD/DVD-Audio playback? Since HDMI 1 will control the Video/Audio of the bluray, if I go analog, what do you use for the visual of the SACD menu and the DVD-Audio visual functions? The Oppo is capable of running HDMI 1 out and analog at the same time right?
Lastly, the audio/video sync issue on the Oppo I have had from day one is very concerning to me, I would think that this would have been resolved prior to it's release.
Be easy on me, I am not that astute at Audio/Video, but I love it ! Thanks .....Mark
First of all, welcome to AVS and to this Thread!
The choice of Split A/V vs. Dual Display ONLY APPLIES if both HDMI outputs are "live" at the same time. If only one of them is live, even though both might be cabled, then that setting is ignored and best quality video and audio both go out the live cable.
So to get best quality audio you should have only one cable live at a time, or, if using both cables at the same time, you should set Split A/V and use the HDMI 2 cable to carry the audio. (HDMI 1 will be silent for audio in that case.)
Now you say you want to get best quality audio BOTH on HDMI 1 and HDMI 2 in the dual-cabling arrangement you are considering, but if you think about it, when cabled that way HDMI 1 is going directly to your TV and it is highly unlikely your TV can actually ACCEPT things like 7.1 LPCM audio or Dolby TrueHD or DTS-HD MA Bitstreams.
So really there's no point in trying to send "best" audio to the TV, because the TV will simply declare -- during the HDMI handshake -- that it doesn't know how to handle those, and please sir, send me something simpler that I know how to handle! biggrin.gif
OK so what to do?
Well here's one possibility: Cable HDMI 1 to the TV and HDMI 2 to the Receiver. Set Split A/V
For "normal" use you will have both the TV and the AVR turned on, and so both cables are "live" and Split A/V comes into effect. That means best video goes to the TV (with no audio) and best audio goes to the AVR. HDMI 2 will carry SACD HDMI DSD if you want, so you get that possibility covered as well.
When the time comes that you want to play audio out of your TV's own speakers, simply turn off the AVR! That makes the HDMI 2 connection no longer "live" -- so the Split A/V setting is ignored, and both video and audio go to the TV over HDMI 1. Now be under no illusions here -- the TV won't get "best" audio because it won't know how to handle that. But the HDMI handshake will negotiate the best level of COMPATIBLE audio the TV can handle.
And here's another possibility: Cable HDMI 1 *AND* HDMI 2 to the Receiver, and cable the Receiver to the TV.
For "normal" use select the input on the AVR which comes from HDMI 1. Since the input coming from HDMI 2 is not selected, that cable is not "live" and thus the Split A/V vs. Dual Display setting in the OPPO is ignored. Best video and audio goes over HDMI 1 and HDMI 2 is not used. The AVR uses the audio and sends the video on to the TV. Video on the HDMI 1 output will use the QDEO video processing in the OPPO.
When the time comes that you want to play SACD HDMI DSD, change the AVR to use the input coming from HDMI 2. That makes the HDMI 1 input no longer "live", and thus, again, Split A/V vs. Dual Display does not matter. Best video and audio go to the AVR over HDMI 2 -- with HDMI DSD if that's what you want. The video is not being processed by the QDEO video processor in the OPPO, but that's irrelevant for SACD playback.
Now, if you want to get audio from the TV's own speakers instead, that will depend on the features in your AVR. For some AVRs you can just turn the AVR OFF and its last-used HDMI Input simply becomes "pass through" to the TV. For others you will need to leave the AVR ON, and mute the speaker outputs of the AVR so that the only audio is coming from the TV.
(And vice versa, when you want to use our "normal" speakers you will need to mute the speakers in the TV.)
--Bob
post #2916 of 5543
--Bob
OK, you may be getting bitten by the bug where the Stereo Signal setting is getting incorrectly executed.
The next time this happens, instead of power cycling the player, go into Setup and change Stereo Signal to DOWN MIX STEREO and then immediately back to FRONT LEFT/RIGHT and see if that cures your problem.
If so, please email your finding to OPPO Tech Support.
--Bob
post #2917 of 5543
--Bob
Will do. I'll actually test it in a bit. I'll power system down & start over as i did this evening and each time it has occured.
Thx, Bob.
post #2918 of 5543
--Bob
Great post Bob, now all I need is an Apple DNLA Server for music to an Oppo 105 for Dummies Book. . .
post #2919 of 5543
Hi Real,
When streaming, the settings are slightly different within MC(18 at least). The settings are linked to the DLNA server activated.(Tools>Options>Media Network>Add or configure DLNA servers>
Select your server (or create one) and use audio 'never convert') and don't forget to associate it to the OPPO (right click on the Oppo in Playing Now tree).
You may refer to that thread in the JRiver forum:
http://yabb.jriver.com/interact/index.php?topic=76654.0
The MC18 / oppo-105 couple is near a perfect match!
Best
Kami
post #2920 of 5543
--Bob
It's quite alright and I'm quite capable of admitting I was wrong. I just wish there was someway to always watch with "placebo-vision". LOL
post #2921 of 5543
Lip Sync issues again! I just put the latest firmware one hour ago and the issue is still there. Everything starts fine and then after a while it gets out of sync. I switch channels and it corrects itself and then it happens again. I've never had this problem before.
Edited by nycjazz - 1/17/13 at 8:23pm
post #2922 of 5543
I.......
--Bob
Hi Bob,
Thank you for the usual informative and well put answers.
I am following this thread from day 1 and recall having read from a well informed reviewer that a driver to allow for multichannel or DSD via USB is in the work.
Any update on this ?
Should this happen, I will be able to use JRiver MC18 to its full power and use room correction, the so called 'convolution' and any plug-ins added.
That will also allow for bass mangement at the source and avoid later sound treatment.
Best
Kami
post #2923 of 5543
People report quick success with Twonky.
-Bill
post #2924 of 5543
Confused about 95/105
I have had the 95 for a while now. it does everything beyond perfect (to me anyway) I had an 83 before that, loved it too.
My question is what is the advantage of the asynchronus digital inputs on the 105 over the usb inputs on my 95. I play all my stuff from a large external HD into the 95 and it works great. What would I do with the 105's DAC inputs and why please.
post #2925 of 5543
The Asynchronous USB DAC Input of the 105 lets you use the 105 IN PLACE OF the normal sound card in your computer. You play music using software on your computer -- just as if it was going to come out the normal computer speakers. But instead the stereo digital audio stream goes across that asynchronous USB connection to the 105, which plays it through the audiophile quality DACs in the 105.
--Bob
post #2926 of 5543
Originally Posted by stevepow View Post
The only Blu-ray content I have evaluated so far is this sampler / calibration disc - AIX Records - Blu-Ray Audio Calibration Disc and HD Music Sampler - and it sounds wonderful. That and Stones Live at the MAX - pretty great sounding as well.
Highly recommend getting a 2L audio-only (Blu-ray profile 3) disk to try. Even a die-hard SACD fan has to admit the 24 bit, 192 kHz PCM sounds incredibly good. I hope the format catches on--there will be way more Blu-ray players than SACD players.
post #2927 of 5543
What formats support 7.1 at 24-bit/192kHz? Blu-ray runs out of steam above 5.1.
post #2928 of 5543
Good catch.
That's correct. 7.1 is limited to 96KHz 24-bit. 5.1 can carry 192KHz 24-bit. That should have read up to 7.1 channels at up to 192KHz and up to 24-bit.
--Bob
post #2929 of 5543
--Bob
Thanks, Bob, for yet another excellent, educational Post in this Thread.
Yes, I am definitely always in learning mode, especially compared to some of the redoubtable audio/video experts (such as yourself) on this Forum. This, if I may say, revolutionary piece of equipment, has triggered another new effort on my part to get up to speed on a very rudimentary level, with the current audio/video state-of-the-art. It is difficult given my time constraints to stay current.
Now, I need to digest your superb Post and much of the other information on this Thread, before I formulate another series of noob questions.
Thanks Bob and to all.
post #2930 of 5543
--Bob
Some AVRs apparently keep both HDMI 1&2 active even when only one is selected. That's the behavior of my Marantz AV7701 Pre - I run Split A/V (HDMI1 to "Blu-ray" input and HDMI2 to "DVD" input) and only select the 7.1 audio inputs on the Marantz for the Blu-ray/HDMI1 input - if I select HDMI for the audio input over HDMI1, I get no sound. I only get sound over HDMI from HDMI2. If I switch to Dual Mode, I can get sound over HDMI from either input.
I have arbitrarily set it up that way for the moment using the "Blu-ray" input for analog playback and my "DVD" input for HDMI that can take advantage of Audyssey, and I switch easily between the two for comparison. Although I have not listened to audio over HDMI in days - the analog outputs sound so fine.
My current video monitor is so small and far away, video quality is not a concern yet.
Steve
post #2931 of 5543
Good catch.
--Bob
And my ears can probably only process 32KHz / 24-bit these days. Who am I kidding...144dB of dynamic range? I'm probably doing good to appreciate well done 32/16. rolleyes.gif
post #2932 of 5543
Steve
Often you can fix that by adjusting settings in the AVR. The most common reason for a device to keep an otherwise unused HDMI socket "live" is in support of HDMI CEC (remote control over the HDMI cable). Turn off settings in the AVR related to automatically powering On/Off other devices over the HDMI connections, or related to automatically switching inputs if another device is turned On.
--Bob
post #2933 of 5543
Well keep in mind that you need twice the sampling rate to support a given frequency. That's why even CDs use 44.1KHz. Higher sampling rates can make it easier to do various bits of digital audio processing (during mastering for example) without having to be quite so careful regarding aliasing.
The best write-ups I've seen say human hearing is limited to about 20-bits dynamic range, so 24 is overkill, but not by that much.
--Bob
post #2934 of 5543
post #2935 of 5543
Thanks Bob. So I could take advantage of any music file control software I have in my PC to feed the the 105's Sabre DAC rather than just seeingthe set list as interpreted by the BD 95 when I feed it stuff via an external HD through the Sabre DAC in the 95 . Correct?
Mike F.
post #2936 of 5543
Anybody?
post #2937 of 5543
I also have the synch issue when I use my OTA tuner from the HDMI Back, starts bad then seems to resume partially .. anyway it is definately noticable and annoying
post #2938 of 5543
Anybody?
I had oppo bdp-103 and never had lip sync issue. I upgraded to BDP-105 and have pretty bad lip sync issue. One thing i have noticed with oppo that things do smooth out ouver time. For example on 103 i had motorola freezing because of hdmi hand shake issue in first couple days and then it disapeared. Not sure if that is going to be the case with lip sync or if there is a fix on the way? Mine does it when connected directly from motorola to oppo to projector.
post #2939 of 5543
close to pulling the trigger on the 105. I have a Motorola STB VIP 2262 and Apple TV. What is the best way to hook these up to the 105 and back to the TV which has 2 HDMI inputs. Audio will run from the 105 direct to the amps using the analogue outputs. No audio from the TV. What's best? The STB into the HDMI in the back of the 105 and the Apple to the HDMI in the front? Will the 105 then process the audio based on which box is in use and will the audio be processed automatically from the HDMI inputs or should I use the optical in from the STB? If this has already been covered please refer me to the post.
post #2940 of 5543
Originally Posted by audiofan1 View Post
Nope........ no point in that. Since there is no difference and these cables ARE quite a bit narrower, I'll keep 'em employed.
