Here is the email reply from oppo. I recieved this reply back in about a day and during weekend, which is very respectable. I am gonna follow what they advised and see if it works?
1. In our experience issues related to the remote control not responding well are due to variances in the environment which can cause interference. We often find that changing the Remote Control Code can resolve these errors.
Please remove the battery compartment from the back of the remote control and change the dipswitch from I to II or III. Close the battery compartment.
Press the OPEN button on the front panel of the player. Aim the remote at the front panel of the player and press and hold the ENTER button on the remote control for 5 seconds. The message CODE 2 or CODE 3 should appear.
Does one of the new Remote Control Codes work with the player?
2. Ensure that you have upgraded the firmware of the player to the latest firmware release: https://www.oppodigital.com/blu-ray-bdp-103/BDP103-firmware-38-1220.aspx
If the firmware is out of date, then the audio and video synchronization errors will be incredibly bad. We will be releasing a new firmware in the following weeks which will further refine and fix audio and video synchronization errors.
3. Try using an alternative DLNA server such as oShare (http://sourceforge.net/projects/oshare/) and see if the same errors occur. It is highly likely that the issues are related to the DLNA server and not the player's performance.
Future Support:
1. This is something that has been requested, but at this time we do not know if we will make a firmware which will allow the inputs to be adjusted when the player is powered off or resumed when the player is turned back on.
2. This will likely not be supported as this has to be engineered into the player's hardware, not the software. The decoder, which passes the HDMI information, is completely off when there is no power going into the player. So HDMI passthrough is not possible when the player is off.
3. We hope to add this to a future Media controller for Android and iOS devices.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119
________________________________________
Sent: Saturday, January 26, 2013 7:22 AM
To: OPPO Service
Subject: Message From Kris
Message from Contact Us Web Page
Preferred Contact Method: E-Mail
Category: Technical Support
Order Number:
Note: Hello, i have few issues with my BDP-105 and need help. I have your latest firmware installed.
1. Player gets sluggish to remote control commands. Hardware and software remote commands, have to recycle the power, but have to leave it off for at-least 10 minutes before it starts working again. Seems like heating up? I have put the player away from the rest of the av equipments and it seems like it does better but i am not sure.
2. Very bad lip synch issue for cable signal. I have tried connecting directly to the projector and through the denon 4520ci. Video files from hard disks not often but it does it once or few times in a movie but is able to self correct. In cable signal i have to skip the channel back and forth to correct it. Also cable lip-synch issue is variable timing. So i cant correct it.
3, when browsing network video or audio files, player browses fine up to 4-5 screen lengths of files just fine but when try to reach over 60-70 files, it rests the browsing process and goes back to the root folders. I am using plex server because thats the only one successfully can be used. I tried other methods of browsing files through oppo to my network unsuccessfully. I am using windows 8 on an i7 machine with 10gb rams. Wndr3700 netgear router and i have tried using oppo wirelessly and wired, same results.. I have grace note option shut off In oppo.
I would also like to know if the following features are on your table for the near future firmware updates?
1. Having the custom option to select input port? When player is powered on/off?
2. Hdmi pass through when player is off? Seems like player does have the ability to pass through when powered.
3. To show media info in the tablet app without using the tv screen?
And at the end, i do wanna congratulate you for creating such a great product. That is the reason that i wanna go trough this to fix up the quirks and i believe that you guys are fully capable of doing this. Any new product on the market is very seldom perfect.
Sound alone is worth keeping this player. Most of the issues are video and network related.
Regards.
Kris
Future Support:
Best Regards,
Customer Service
OPPO Digital, Inc.
Tel: 650-961-1118
Fax: 650-961-1119
To: OPPO Service
Order Number:
Regards.
Kris
as my LG BH200 was getting old. I love the sound quality of this player. Right out of the box, it has the nicest sounding bass of any digital product I have owned. Nice and tight.The examples for sound quality used so often in here are so very correct. I am wondering about one thing though. I have noticed that the white level is washed out somewhat. Like for instance white sheets on a bed. Or a white T-shirt, my LG would let you see the texture of the sheets, or shirt. The Oppo is washed out and looks out of focus. I have tried pretty much every setting and it always looks the same.The contrast enhancer is off." I have adjusted the brightness and contrast with the Oppo in the chain. Likewise with the LG in the chain." Pretty much nothing changed. I thought the focus might be off on the projector so tried that. It is exactly like the whites are out of focus. Everything else is perfect. The image is amazing other than that. I have gone back and forth between the LG and Oppo. The LG definately has very detailed whites where the Oppo's is washed out. Could this be a problem with the player. Like a cap or resistor or another part out of spec in the video section or something? I already have it mounted in my rack. But wonder if I should give Oppo a call? I figured I would give you very knowledgeable AVS folks a try first. So if anyone has a clue of what might be going on here please let me know.Thank You for any and all help you can give me.
the 900 was going to be.
, and based on what I recall about your system from previous discussions, I'd suggest that buying the BDP-105 now hoping you might use the extra features in a few years probably isn't the best investment as it's pretty much a sure thing that Oppo will have a newer, better, model out by then (or you'll almost surely still be able to get a new 105 around the time the new player comes out if you decide the 105 meets your needs better). If you're looking for an upgrade to your BDP-83, the BDP-103 would give you a lot of new functionality that the BDP-83 doesn't have and the upgrade wouldn't cost you very much after selling off the BDP-83 (unless you'll be re-purposing it for another room).
