AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 120
post #3571 of 5605
....double post.............
post #3572 of 5605
Originally Posted by BenGodzilla View Post
I have never bought the concept of burn in but the player does seem to improve when it's been running a while and changing over my power cord last night seemed to move the player up a notch but of course in all the excitement of trying out discs and messing about you can get fatigued. I think it takes time to digest a new player fully.
Right, like a new brand of Whisky - don't really start to appreciate it until the bottle is almost done. Fortunately don't have to go out and get a new Oppo after a long "session". wink.gif
Q on the power cord thing - is it also necessary to rewire the from the panel to the outlet with equal quality wire, not to mention whatever the PoCo is providing from the station to the house, or does that last few feet really make or break it? Or does the cord have some sort of conditioning circuitry in it? Would an on-line style UPS that was basically isolated from the PoCo and other in-home circuits do as well or better? On-line UPS can be expensive, but compared to some of the power cords I have seen eek.gif, not so much.
post #3573 of 5605
The power cord I have was made by a friend who got into making them for a short time, he had a review in Hi-fi Choice in the UK many years ago....it's big chunky guy but I have no idea how he constructed it .
That's all I use and the Oppo power cord went on the CX-7......to be honest today I wouldn't say the cord sounded that important.....last night later on as is commonly observed I thought he Oppo sounded better and when I swapped cord it seemed to go up a notch again. Today's session was during the afternoon.....as you probably know it's a common observation hi-fi's sound better at night.
post #3574 of 5605
Anyone using the Oppo 105 with Adam active monitor speakers like the S3X-H ?
post #3575 of 5605
Adams are brilliant - it should sound glorious and if not, I blame the Oppo. biggrin.gif
I'm running the Stereo Analogs, as another zone, into a pair of Meyer HD1s and it is excellent. Still trying to decide if is as good or better than my years old Apogee converter - either way - nice to have comparisons like that to sort out.
Edited by stevepow - 2/10/13 at 9:06pm
post #3576 of 5605
OK, so - Bob - or Bill - or the others "in the know"...
What's the deal with DTS Neo? I like to use this sometimes for stereo playback and when I enable it on the Oppo, the volume drops off a cliff. On my Marantz 7701 pre - and any other pre I have used, it works fine and switching between stereo and DTS Neo doesn't normally require a massive volume correction.
I read where someone posted a few days ago that it doesn't work in 5.1 so I set my Downmix to 7.1 and there's no real difference - not even sure if I believe the "5.1 bug" comment - it just seems like it isn't working correctly in general and the surrounds seem maybe 3dB or more down from what they should be, beyond the fact that all the speakers are low to begin with. Is Oppo working on fixing this?
I know it is an odd contradiction that I'd want to have a more "pure" version of this maligning of the stereo signal than letting the Marantz do it, but I do - and it should work.
Thanks for any insight.
Steve.
Are you sure you aren't exaggerating? By my testing, engaging DTS Neo:6 drops the volume about -4dB.
The bug where Neo:6 processing would not engage for a 5.1 down-mix no longer exists in the current firmware.
As with all surround sound algorithms, whether you like the result will often depend on the particular stereo content you are playing.
I've compared Neo:6 in the 105 to surround sound processing in my Anthem D2v and the results are comparable. Of course neither sounds as good as playing a "real" multi-channel audio track.
I recommend you re-check your Analog output speaker volume trims using the 5.1 LPCM test track from the AIX calibration Blu-ray disc.
Also, if you are using Stereo Signal FRONT LEFT/RIGHT. Try toggling that to DOWN MIX STEREO and back to FRONT LEFT/RIGHT to be sure you aren't getting bitten by the bug we've discussed here.
ETA: That bug, if triggered WOULD have the effect of making the surrounds sound low because the surround channels are ALSO, mistakenly, coming out the front channels (i.e., fronts and surrounds are out of balance with fronts sounding louder). In addition, the over-all output is lowered because of "down mix attenuation". You can toggle that Stereo Signal setting "on the fly" and if that's the cause of your problem you will hear the fix immediately when you toggle back to FRONT LEFT/RIGHT.
--Bob
Edited by Bob Pariseau - 2/11/13 at 3:16am
post #3577 of 5605
Originally Posted by SlaB View Post
Thanks for reply. I'm actually not concerned with the HDMI audio in this case, it seems to work fine. I am concerned with the digital coaxial output of the Oppo. I have a lot of videos that are encoded with DD or DTS 5.1, and the only way to send that audio to the soundbar in it's original multichannel format is to configure the Oppo's coaxial output for Bitstream format (there is a huge difference with the soundbar when playing back DD/DTS 5.1 sources vs. 2ch LPCM). But I also have many videos that are encoded with simple 2ch stereo 48kHz audio and as mentioned in my initial post, the soundbar doesn't like what the Oppo is sending along (even though the same 2ch stereo 48kHz videos play fine via the Oppo's HDMI connection to my Panasonic HDTV and out the Panasonic's optical output to the soundbar).
I'm curious if anyone else has experienced any problems with an audio source that does not work on the coaxial/optical out of the Oppo, but does on the HDMI out (assuming both are configured for Bitstream format)?
Thx...
Are you running the latest firmware in the 105? There was a recent bug fix for Optical/Coax output. Check Setup > Device Setup > Firmware Information. Your "Main" firmware version should end "1220".
--Bob
post #3578 of 5605
Originally Posted by wmcclain View Post
On the -103/105 composite output is for "diagnostics only". You can use it to see the Setup Menu, nothing else.
This is part of the Analog Sunset enforced by recent industry licensing changes. They don't want any video going out except over HDMI.
-Bill
Thanks, that's too bad but I am sure (hopefully) I can find a way t get around that..
post #3579 of 5605
RouslanB.and to the rest of the thread readers,
I think that perhaps my quick-review should have been put into the 105 "sound" thread. Please move it you feel that is the case. Apologies.
Now to answer RouslanB's question:
As per your request, I did hook the 105 directly to the mono blocks via XLR. This is what I heard, and again this is an initial impression.
Overall, very good sound but no match for the XSP-1 pre amp. Direct hookup gave a slight closed in feel for the sound stage, though the sound stage was very very good. Bass response seemed to become a bit louder and a little bloated to my ear. But again ...not bad. When hooked up through the pre-amp, bass was more detailed, tighter and controlled.
Overall: (with the XSP-1 in line), bigger sound stage, with significantly better, detail, as well. I got a more open, airy sound; minute, low-level detail was there, notably in Diana Krall's voice in "A Case of You" on the Live in Paris CD.
I should have tried direct to mono block via RCA but I just didn't have the time as it was a busy weekend. Also to note, I did not have any attenuators in-line when performing the test. The XSP-1 is noted for having a very accurate volume control.
I think one could save money and listen directly to the amps with the BDP-105 and be very happy, but for those like me, who still listen to vinyl, you're still going to need that pre-amp..
Looking forward to hearing things with XLR connectors and with more miles on the odometer. I still think that the upper range needs to smooth out a tad bit but after reading posts here on AVS Forums, I trust that will come.
KP
post #3580 of 5605
>>>>>I put on a .Wav from a Darol Anger album. Acoustic guitar strings had so much more “low level” information associated with them. I could here, for a better term, “micro harmonics” emanating from the speakers. Sounded so much more real. Moving quickly on to Gary Willis' “Bent” album....Jazz fusion.
Bass drums were, tighter, punchier and detailed, as was bass guitar. Toms were wide open with lots of tone and ring. This thing just “breathes” in and out!>>>>
Wow!! from Anger 's organic bluegrass fiddling to Dennis Chamber's teeth rattling bass drums and "tribal" (pun intended) explosions on " Bent" -- lol now THAT's putting the 105 through its paces.
post #3581 of 5605
@Beatmachine
LOL, "Armageddon Blues" (Bent) is not for the faint of heart! The 105 handled it all with aplomb....so it is....the bomb!
post #3582 of 5605
Originally Posted by Kal Rubinson View Post
Or an ISO?
Will you compare the BDP-95 to the BDP-105 I am wondering if it is worth the upgrade?
post #3583 of 5605
Only very briefly.
post #3584 of 5605
Originally Posted by Ramatam View Post
@Beatmachine
Precisely the tune I was thinking of! "Emancipation" is another good one because the percussion is tuned almost as low as the bass. Ive had problems with other changers not easily distinguishing between the two.
Not so with the 105!
post #3585 of 5605
KP
Ramatan, thanks a lot. Do you remember by any chance what was the volume level on Oppo?
Attenuators helped me to get volume higher - 60 - 70 for moderate volume to minimize digital volume control imperfections and be close to 100 (the volume you would have with a preamp like XSP-1)
post #3586 of 5605
What app do you use on your iPad or Android to control the 105?
post #3587 of 5605
The oppo has a lossless 32-bit digital attenuation, you really dont have to worry about it.
post #3588 of 5605
jriver media center running on my HTPC for my music and movie library, with Jremote running on my iPad to control and push music via DLNA to the 105.
post #3589 of 5605
HERE, bottom of the page.
post #3590 of 5605
Only very briefly.
Ok we just need to know if you think it sounds better, many reviewers don't think so?
post #3591 of 5605
Unfortunately, this persistent rumor that Oppo's 32-bit digital volume control 'drops-bits-hence-affects-resolution' stubbornly refuses to go away despite many, many posts and conclusive mathematical proofs from Oppo that show otherwise...(sigh!)
post #3592 of 5605
--Bob
Thanks Bob.
4dB is about what I measured - that's quite a bit of a listening level change. I don't get that sort of fall off with any other processors I have used. I'll check the other settings and toggle the Downmix just to make sure, but if you are getting a 4dB drop it sounds like that is how it is implemented. On my Marantz Pre/Pro the front levels don't change from Stereo to DTS Neo:6 and back - if they do it is imperceptible. And that seems correct - I have googled around for what "DTS Neo:6 Music" does and apparently it is supposed to leave the front channels alone and create the other channels from them.
From Dummies.com (sounds reliable, right biggrin.gif - why I checked for more sources):
"DTS Neo:6: DTS Neo:6 Music and Neo:6 Cinema are decoding techniques for stereo or Dolby Surround-encoded two-channel sources. Neo:6 Music keeps the front left and right channels intact while synthesizing the center and surround channels from the 2-channel source. Neo:6 Cinema can create a 6.1-channel signal from 2-channel movie sources."
From a Crestron explanation:
"DTS Neo:6 Music
This mode is suited mainly for playing music. The front (left and right) channel
signals bypass the decoder and are played directly, so there is no loss of sound
quality, and the effect of the surround signals output from the center and the
surround (left, right, and back) channels add a natural sense of expansion to the
sound field."
This ATI manual says essentially the same thing - http://www.brentbutterworth.com/PDFs/8500.1_manual.pdf
So I think whatever the Oppo is doing is not correct for "music" mode - the fronts should not be attenuated. I have emailed them about this - maybe they fix it. I like to switch between listening modes as I please and late at night an errant 4dB level change can disturb the sleeping family members - don't want to lose my "stereo privileges". eek.gif
Steve
post #3593 of 5605
Can you play video from the HTPC to the Oppo? Does this work with DVD and BluRay ISO files?
post #3594 of 5605
Has anyone used the audio outs to their av amp and then hdmi from the av amp back through the oppos input. So the av amp is a kind of hdmi hub. This would be really convenient but will it blow my amp.
post #3595 of 5605
I'm using JRiver now and noticed something I'll pass along. Sometimes Jriver doesn't see the Oppo. The solution is to power up the Oppo after launching the Jriver Media Center.1.gif
post #3596 of 5605
Bob,
I didn't make a note of the volume level when using the Oppo straight to amp. I can say that it was at a healthy listening volume, around the same level as when I do serious listening with the Eomo pre in place. Not an exact science but it wasn't meant to be. Sorry.
I wish I could get a set of Emo XLR's in the 2M length to run the Oppo to the pre, but they are out of stock. Got a free pair when I bought their pre back around Christmas. I want keep both sets of xlr's the same.....not sure why though, just seems like a logical thing to do. Otherwise, I'd go BJC..... but then I'd b throwing a set of xlr's away. So for now it's RCA for the time being.
Using RCA to the pre and then using XLR to the amps really kinda negates any valid conclusion one can make about about the sound comparison...but that is what you asked me to do so that's what I did.
kp
post #3597 of 5605
Every digital volume control 16 bit or 32 bit has a potential to introduce a distortion compared to a analog volume control. You may argue that distortion is negligible an inaudible :-) but technically it is there.
post #3598 of 5605
More accurate would be "Every volume control has a potential to introduce a distortion." In many cases your analog control may be much worse the ESS Sabre's digital one.
See this for some background: Digital vs. Analog Volume Control
Chris
post #3599 of 5605
Unfortunately, along with the meager useful information, there is a large dose of game playing in that presentation. The horrible S/N of the 16-bit DAC (if anyone is even using 16-bit DACs anymore!) is only an issue if the noise floor is already audible. When the music fades out, are you hearing hiss/noise from the speakers?
I didn't see them making the case that analog volume is worse than digital, but that digital, done right, could attain most if not all the benefits of analog volume. With that I agree.
post #3600 of 5605
Guys, please, don't get me wrong - this is not a theoretical discussion for me - trying to decide if SQ will benefit from a pre-amp (emotiva XSP-1 for example).
What do we know:
- oppo's pre-amp outputs amplified enough signal to drive Emotiva XPA-1 power amps directly (at less than 100 volume)
- XSP-1 has an excellent analog volume control
- we have some data ( algthought not double blinded AB test) suggesting that Oppo ( at 100 volume) with XSP-1 preamp sounded better than Oppo ( at less than 100 volume) connected to the same power amp directly.
How do we explain this leaving aside physiological factors?
Quality of XSP-1 preamp section is irrelevant - input signal is amplified enough by Oppo already with all the potential distortions Oppo preamp might've introduced. There is nothing XSP-1 could've done to make source signal better in its amp section.
The only potential difference - in one case the volume in Oppo at 100 (digital volume comtrol bypassed) and in the other case (driving power amp directly) - digital volume control could be much less - for example - 30
Superbly implemented analog volume control of XSP-1 could be the only explanation why Oppo + XSP-1 may sound better. Do you guys have any other hypotesis?
If I follow that logic adding attenuators ( a static analog volume control) may bring digital volume on Oppo closer to 100 potentially improving SQ without investing in preamp.
