Originally Posted by
Torqdog
Me thinks he means that he cancelled his cable subscription 12 years ago. I cancelled mine and went satellite back in 1996 and haven't looked back once.
Or move to Europe where in my personal experience this is a non issue. (excl UK
damon
The way I was thinking of setting up the system I proposed above would require the 105 to have to have 3 separate analog outputs.
I realize that Front RT, Front LT on the surround sound can be set to down mix into stereo.
This leaves the 2 Stereo Balanced & Unbalanced analog outs. Is this a choice on the remote & on the remote app? I need to be able to "toggle" between these 2 & do not want each to be active simultaneously.
Seeking to have 3 separate 2 channel Zones & open to suggestions.
I am using the app regularly. On iOS it needs to reconnect each time you switch between another app. It functions well and fast although the volume button is not helpfull to quickly move the volume up or down. As part of their tweaks I hope they introduce a slider for volume control.
No macros either so the 3 zone controll is going to be a tricky one. And it will not output different signals to different outputs. Seems u r back to basics. It can be the single source but all controls you need to have in the zone itself.
Overall I use the app for ad hoc control. For regular use the physical remote is simply faster and usable with your eyes on the screen.
