AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 131
post #3901 of 5654
Quick question about bass management given my unique situation:
I recently purchased a Rel R-528 sub, which features a high-level input as well as the LFE connection. Rel insists it is mandatory for the front speakers to be set to LARGE to take full advantage of this sub. After much experimentation and advice from AVS members in the Marantz 8801 thread, I have found the best results come when in fact my mains are set to large, and the LPF on the Marantz are set to 250Hz. I am EXTREMELY happy with this set up. The high-level connection on the sub gives me exceptional bass, even when I play two channel music from my Mac Mini music server into the USB input of the 105.
My question is in regards to the settings for the 105 with this configuration. Should I set the speakers to LARGE in the speaker configuration settings of the 105 as well? I understand these settings don't apply for the USB input or when listening to DSD output from SACD, but for all other material that I listen to through the 105's DACs (DVD-A, CDs), I'm not sure how to configure it.
Thanks in advance.
post #3902 of 5654
Originally Posted by Paul Kile View Post
I just picked up a BDP-105 this weekend, hot on the heels of a Pioneer Viera VT50 55" plasma. I am running a Pioneer Elite VSX-94TX A/V receiver. Does anyone out there know if an earlier OPPO remote has discrete on/off commands? I know OPPO publishes an Excel spreadsheet with discrete codes, but I have an old UTC MX-500 that can only be programmed with direct IR learning, no provision for hooking to a computer to input command codes.
Anyone out there using an MX-500, and if so, how did you input discrete commands for the OPPO?
Thanks in advance,
Paul
Harmony has discrete on/off IR codes, but I had to call it a BDP-83 to get them (they don't include them if you say your device is a BDP-105, but the 83 codes work fine). I bought the cheapest Harmony remote several years ago and use it to download discrete IR codes for all of my various components from their website. I then use the Harmony to program a Sony universal remote with direct IR learning. Of course, I could just use the Harmony remote, but I prefer to use macros on a Sony RM-VL900. Harmony's website has never let me down; they have discrete IR codes for everything I've tried.
post #3903 of 5654
What make/model is the headphone chip in the 105? I thought that was posted on this thread somewhere, but I can't find it?
post #3904 of 5654
Thanks in advance,
Paul
Yes, the remote for the BDP-83 and BDP-93/95 has discrete on/off commands:
Backlit Version
Non-backlit Version
post #3905 of 5654
Thanks for the input, Bill!
One question though - Our local high--end audio store (where I do most of my business), says Harmony uses toggles rather than discrete codes in their macros, that's why they don't sell or recommend them, since they say it is too easy for sequences to get out of sync with on/off commands and such.
Your post indicates that Harmony CAN supply discrete codes, so if that is true I will disregard the store's info and invest in the cheapest Harmony remote, using that to transfer commands to my MX-500. I might even program some macros into the Harmony
Cheers,
Paul
post #3906 of 5654
Backlit Version
Non-backlit Version
Thanks, gsr! I have just called OPPO and ordered the BDP-80 remote for a whopping 13 bucks (including shipping)! The tech checked and it indeed does have discrete on/off buttons. He indicated the discrete functions were deleted in order to add the dedicated Netflix and VUDU access buttons per their licensing requirements (which I will never use...grr). So hopefully next week I will get a remote programmed that my wife can deal with.
And Bill, I may still look into a cheap Harmony remote as well, for command transfer purposes as you described.
Cheers,
Paul
post #3907 of 5654
I am considering getting a BDP-105 but wondered if anyone here has heard the 105 vs the Sony XA7ES for 2 channel audio? I am very attached to my XA7ES but wouldn't mind combining my 2 channel listening into the 105 if the SQ is in the same ballpark as with the Sony. Anyway if anyone has any experience with both please comment. For reference my pre-amp is the Emotiva UMC-200 (wanted the new higher end one but its still not out and got impatient LOL). My speakers are Monitor Audio GS20's and the amp is a Sunfire Cinema Grand 5x200.
post #3908 of 5654
Originally Posted by Bob Pariseau View Post
If your trims are already all at 0dB or below now, then I'd leave them right were they are and just adjust the main, Analog output Volume setting for the OPPO as needed to prevent clipping the Analog input of the preamp when playing louder content.
My expectation would be that you won't have to lower Volume very much to accomplish this (perhaps just a few steps). Keep in mind that each Volume step on the 105 is an attenuation of -0.5dB.
--Bob
The problem is that thought he difference between each step is very small, the difference between step 0 and 1 is farly significant.
Cheers,
Paul
He lied, whatever commands are available to be used can be used on the logitech. If it does not have discrete commands in the database then you can't use them but most devices have them and you can use them. It would be a worthless device if all the components turned off each time you changed modes with the remote.
post #3909 of 5654
Originally Posted by tme110 View Post .....He lied, whatever commands are available to be used can be used on the logitech. If it does not have discrete commands in the database then you can't use them but most devices have them and you can use them. It would be a worthless device if all the components turned off each time you changed modes with the remote.
And there lies the problem these sales people lie all the time so they can push you into buying a more expensive product!
post #3910 of 5654
Thanks in advance,
Paul
I didn't think Pioneer was making plasma displays. Did you mean to say Panasonic Viera VT50?
post #3911 of 5654
He lied, whatever commands are available to be used can be used on the Logitech. If it does not have discrete commands in the database then you can't use them but most devices have them and you can use them. It would be a worthless device if all the components turned off each time you changed modes with the remote.
I did a setup of a BDP-105 at my friends and he had an older harmony.
If you do not find the commands listed, you can learn them from the remote and then use them.
If you want to help others, enter a ticket on the Logitech Harmony support site. Perhaps if they get enough of them, they might update the master DB.
One trick for Harmony, is you can add specific commands to an activity during startup.
If you put the Power-ON in here explicitly, it appears to always send them.
This is much better because the Harmony is brain dead and thinks it is doing you a favor by remembering its state.
Of course, when a command is missed, you now have to sequence through the help screen.
I hate this about those remotes. Perhaps the new owners will do better.
- Rich
post #3912 of 5654
Cheers,
Paul
Backlit Version
Non-backlit Version
Cool! I just ordered one. For 13 bucks I couldn't pass it up. I can always use another remote, especially one with discrete commands.
Paul, you don't really need the Harmony if you're getting the BDP-80 remote and all you want to do is teach the discrete on/off codes to your existing universal remote. But I have found their IR database to be very useful for many different components.
post #3913 of 5654
You are right - my mistake. Due to the fact our new Viera is replacing a vintage Pioneer Elite 42" plasma monitor that expired a few weeks ago (with a sound like a rifle shot when the power supply grenaded). My wife loved our old unit, and still hasn't fully accepted the Viera - she thinks the new TV is too big for the room.
Cheers,
Paul
post #3914 of 5654
Yep, I probably don't need the Harmony, but my wife might like it better than my hoary old MX-500. All she uses the MX for is powering up and turning off the system, then she reverts to the dedicated remotes for the cable box, blu-ray, DVD, HD-DVD, and (dare I admit it) the VCR! Buying the 105 is allowing me to ditch the DVD player (retained until now for its ability to play DVD Audio and SACD) and the cheap LG blu-ray (which had HDMI handshake issues with the Viera, and therefore prompted me to look into the 105). I use the MX-500 more than she does at this point.
Cheers,
Paul
post #3915 of 5654
I've only had the 105 for 3 days, and I am already impressed with OPPO.
Here's why...I was demonstrating the musical prowess of the unit for my wife last night, put in one of the CDs of her local concert band (she plays the oboe). She uses our A/V system to play the CDs and analyze how her performances went. Our old DVD player was able to do a 2x fast forward, outputting audible content while fast forwarding. Using that, she was able to locate areas within the tracks very easily. Unfortunately, the 105 does not have this capability, it only allows "jumps" of a few seconds ahead, with no audible content until the "jump" is completed. So she threw the remote back at me, saying this was a major problem. I may need to put the old DVD player back in the system, just for her band CDs!
I e-mailed OPPO this morning, inquiring if the ability to do a 2x audible fast forward was possible, and within 3 hours got the following response:
Paul
The ability to hear the audio being played at a sped up rate when using fast forward is something that we can consider for a future firmware release.
Best Regards,
Customer Service
OPPO Digital, Inc.
Nice to know my request didn't go into the proverbial corporate "Black Hole". If any of you guys out there would have the need (or desire) for an audible fast forward feature, please let OPPO know. That will let them know there is more than one guy who requested this, and probably increase the chances of it making it into their firmware.
Cheers,
Paul
post #3916 of 5654
I'm not sure why you quoted my post, since neither my post nor the question I was responding to have anything to do with the transition between Volume 0 and Volume 1.
That aside, Volume 0 is implemented as Mute. Volume 1 is 99 steps below full reference volume at -0.5dB per step in the 105. So Volume 1 is an attenuation of -49.5dB.
Whether the step between 0 and 1 is too large is thus dependent on how loud -49.5dB is in your system.
--Bob
post #3917 of 5654
--Bob
Bob, a quick question regarding the Oppo's volume control. I understand how the 105 works. Does the 95 work the same way with a 0.5db step for each step on the volume control?
post #3918 of 5654
Yes, it is the same with the BDP-9x series.
post #3919 of 5654
post #3920 of 5654
I called Oppo and got a link to the unsigned driver for windows 8 32 / 64 x86 x64. Here is the link [URL=http://]http://download.oppodigital.com/BDP0103/USB_DAC_Driver_Win8/OPPO-USB-AUDIO-2.0-DRIVER(WINDOWS)_v1.61.zip[/URL] ....
Follow these instructions : [URL=http://]http://www.computeraudiophile.com/f11-software/preinstallation-failed-please-run-setup-again-if-you-are-asked-confirm-installation-software-please-confirm-13783[/URL]
I did this and it worked on windows 8 64 bit. I am using cplay and it sounds great!
Edited by Alan Valenti - 2/28/13 at 6:19pm
post #3921 of 5654
My local audio shop is telling me to purchase the Cambridge Audio Azur 752BD instead of the Oppo 105. Have any of yous played with one of these? My dealer tells me that the OPPO guys used to work for Cambridge. He says that the Cambridge is a better built unit. Just wanted to hear from some people that know .
post #3922 of 5654
I doubt that the Oppo guys worked for Oppo although Cambridge does source hardware/technology from Oppo's parent company
post #3923 of 5654
Does this dealer sell both or just one brand wink.gif. Assuming just one brand, take that into consideration when making your own decision.
post #3924 of 5654
I suggest you try both in your system.
- Rich
post #3925 of 5654
Of course my dealer only sells Cambrdge. I know thats why he wants to steer me away from Oppo. I do think that he knows his **** so to speak and I trust his opinion to some degree. Even if it is biased. I was hoping that some of you guys have had experience with Cambridge and could give me some wisdom.
post #3926 of 5654
Define "better built".
The Oppo has measurable performance at the limit of both state-of-the-art test equipment, and sheer physics.
If the dealer--translation: sales guy--means some kind of fancy faceplate, etc., save your money.
Electronics salesmen make as much sense in this day and age as car salesmen. It's all online.
post #3927 of 5654
I've never played with the Cambridge, so I can't tell you. However, I do work (part-time) for an authorized Oppo dealer. No one at the shop wants to sell the Oppo because there is a very tiny mark-up. Much more profits selling other brands. We also carry Denon and Marantz and their mark-up is MUCH higher than the Oppo. Oppo units are sold specifically to those who come and ask for it.
post #3928 of 5654
- Rich
Clever.
I have followed many of your posts on the AV-8801 thread and I know as you have stated that you are much more thorough then most. I am a rookie to this sport and had hoped that I could learn from some of the seasoned veterans.cool.gif
post #3929 of 5654
Clever. I have followed many of your posts on the AV-8801 thread and I know as you have stated that you are much more thorough then most. I am a rookie to this sport and had hoped that I could learn from some of the seasoned veterans.cool.gif
Let you ears decide! Yes your dealer wants to push Cambridge the margins are 40- 50 points :)
post #3930 of 5654
I dont know what the "Sales Guy" ment by better built. I do know that the prices between the two units is comparable within a hundred bucks I think. Im not so worried about the money just want the better piece. I keep reading about OPPO on the AV8801 thread and have never heard mention of the Cambridge. That alone speaks volumes to me.
