Originally Posted by Hikmer
How does the analouge output between the 103 and the 105 compare? I am finding my outboard DAC to sound better than the 103 and was hoping somoene could compare the two. The bass in the 103 is a tad on the soft side compared to my outbard DAC. I was thinking of picking up the 105 and doing a side by side, then retrun the 103 if I find it worth the extra $700+ dollars. Can you providse any of your findings?
Check to make sure you have the Subwoofer output properly calibrated in your 103. If you have all speakers set to Large (or OFF) the Subwoofer output of the 103 needs +10dB boost external to the player to match the other multi-channel Analog output channels.
If any speakers are set to Small the Subwoofer output of the 103 needs +15dB boost external to the player to accomplish the same thing.
I recommend using a calibration disc to check this, such as the LPCM test tracks from AIX Audio Calibration, Blu-ray. Note that if your room has typical amounts of Room Gain, the SPL of the Subwoofer test tone will typically measure 2-4dB SPL hotter than the other channels when it is set "correctly" -- "C" weighting, slow response on the meter.
--Bob
