post #691 of 5987
12/4/12 at 7:27am
- gsr
- Trader Feedback: 0
- Oppo Beta Group
- offline
- 6,603 Posts. Joined 4/2001
- Thumbs Up: 61
- Select All Posts By This User
You should be able to run that test with your Zektor switch. Hook the front L/R outputs up to one input on the Zektor and the dedicated stereo outputs up to another input on the Zektor. If you set the dedicated outputs to be used as front L/R, both outputs will still be active, so you should be able to switch back and forth just like you did with the 95 and 105. Just make sure the rest of the multichannel outputs aren't hooked up to the Zektor while you run this test (either hook them directly to your amps so they're used both ways or leave them completely disconnected and setup the 105 for a 2.0 downmix).
