AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 235
post #7021 of 10110
Sure. Where woud I find this utility please (forgive the n00b question)?
post #7022 of 10110
http://mediaarea.net/en/MediaInfo/Download
post #7023 of 10110
We did a little shootout of modified Oppo BR players over the weekend, and included 3 BDP 105s and a 83 SE mod..
http://peteswrite.blogspot.sg/2013/08/modified-oppo-blu-ray-player-audio.html
post #7024 of 10110
Originally Posted by petetherock View Post
We did a little shootout of modified Oppo BR players over the weekend, and included 3 BDP 105s and a 83 SE mod.. http://peteswrite.blogspot.sg/2013/08/modified-oppo-blu-ray-player-audio.html
And the winner is?
post #7025 of 10110
And the winner is?
The article said the modded 105 units sounded better than the stock/base 105 and the modded 83SE... From the article, the audiocomm version of the 105 sounded best?
post #7026 of 10110
My conclusions are in my post..
The essence is YMMV...
We intend to do this again when we get our hands on a modwright, and perhaps throw in a Pearl KI SACD player to compare...
Also the partnering system is important.
post #7027 of 10110
@ DanF8500:
Here is one of the files:
General
Unique ID : 216903338652137144403443028968050594947 (0xA32E1041317F9B7589420BF60F491483)
Complete name : N:\New\Great.Gatsby.1080p.BR.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.80 GiB
Duration : 2h 22mn
Overall bit rate : 1 810 Kbps
Movie name : The Great Gatsby 2013 1080p BluRay x264-SPARKS (1)
Encoded date : UTC 2013-08-10 08:44:34
Writing application : mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 12:38:35
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 22mn
Nominal bit rate : 1 617 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.044
Writing library : x264 core 129 r2245 bc13772
Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1617 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 2h 22mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:11:04.080 : en:00:11:04.080
00:22:55.833 : en:00:22:55.833
00:34:26.898 : en:00:34:26.898
00:44:48.728 : en:00:44:48.728
00:55:36.333 : en:00:55:36.333
01:06:20.643 : en:01:06:20.643
01:18:27.786 : en:01:18:27.786
01:31:13.927 : en:01:31:13.927
01:44:11.954 : en:01:44:11.954
01:56:35.155 : en:01:56:35.155
02:05:46.122 : en:02:05:46.122
02:09:40.982 : en:02:09:40.982
And here is the second:
General
Unique ID : 245251118909295746252816900669855482910 (0xB881A5BAB542AF15ABBD17781733C41E)
Complete name : N:\New\Now.You.See.Me.br1080p.mkv
Format : Matroska
Format version : Version 2
File size : 1.60 GiB
Duration : 2h 4mn
Overall bit rate : 1 837 Kbps
Movie name : Now You See Me 2013 1080p BluRay x264-SPARKS (1)
Encoded date : UTC 2013-08-22 08:25:46
Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Duration : 2h 4mn
Nominal bit rate : 1 644 Kbps
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.045
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=1644 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AAC
Codec ID : A_AAC
Duration : 2h 4mn
Language : English
Default : Yes
Forced : No
Menu
00:08:26.548 : en:00:08:26.548
00:14:41.923 : en:00:14:41.923
00:21:25.868 : en:00:21:25.868
00:32:02.003 : en:00:32:02.003
00:39:29.158 : en:00:39:29.158
00:47:07.199 : en:00:47:07.199
00:56:43.441 : en:00:56:43.441
01:04:35.371 : en:01:04:35.371
01:10:23.135 : en:01:10:23.135
01:20:04.549 : en:01:20:04.549
01:29:01.002 : en:01:29:01.002
01:35:22.883 : en:01:35:22.883
01:44:06.281 : en:01:44:06.281
01:45:47.507 : en:01:45:47.507
01:54:24.607 : en:01:54:24.607
Let me know what that tells you please, thanks.
post #7028 of 10110
I'll check some test files I have later, but that line got my attention. HE-AAC is for reduced bandwidth streaming applications and I have understood that to mean low quality.
But the last time I checked it did work on the OPPO and sounded ok; I'll check my test file again.
Did you produce this file yourself from the original Blu-ray? By what process?
If not, just say "no". Downloads of these types of files are illegal and are not to be discussed at AVSForum.
-Bill
post #7029 of 10110
Bill:
'No'
post #7030 of 10110
Bill:
'No'
I'll check HE-AAC in my test suite to verify it is still working.
You might check your file sources to see if other audio formats are available. AAC itself works well, as do the original Blu-ray audio formats.
-Bill
post #7031 of 10110
Thanks for your help. I'll try converting to another format and see if that improves things as well.
post #7032 of 10110
Bill:
'No'
Also you said that you were using an USB drive, if it is a thumbdrive, Check if your thumbdrive is not too slow for the oppo to pull the data our of it.
Just put the same drive in your computer and play the file directly from it with vlc and let it run for a few minutes to make sure that vlc buffering does not matter.
post #7033 of 10110
I looked at the Audiocom site. Crikey!
3,000 GBP for the 105EU w\ mods.
Considering the player is 1,000 GBP, it had better sound a lot better at triple the price.
post #7034 of 10110
Is the 105 able to play the 5-channel downloads from qobuz.com?
post #7035 of 10110
It should QOBUZ is unavailable in the US:(
post #7036 of 10110
What format are they?
post #7037 of 10110
They would seem to be FLAC, although I have not purchased one yet. There are 30 classical albums in 5.1 available for purchase and download in the US. Most of them are 24/88 or 24/96.
I see in the Oppo manual that the USB computer input only accepts 2 channels. Is this still correct?
If the 105 won't play these files, how can it be done? Thank you in advance!
post #7038 of 10110
The USB DAC input only accepts 2-ch streams. The regular USB ports allow playback of any file from a storage device.
post #7039 of 10110
Also multichannel FLAC files can be played back via DLNA or SMB either via Wi-Fi or Ethernet.. DSD (2-ch or mutlichannel) via SMB only, wi-fi or Ethernet attached.
post #7040 of 10110
DSD files can also be played from attached storage.
post #7041 of 10110
So it seems my best bet is to simply copy the 5.1 FLAC files to a USB thumb drive and plug it in to the Oppo? Will this also work on my BDP-83SE?
Can I use Foobar (or other) to send the 5.1 signal from the HDMI output of my PC to the HDMI input of the BDP-105? Thanks again!
post #7042 of 10110
No FLAC support on the BDP-83.
-Bill
post #7043 of 10110
I just noticed the other day that my choice of DVDA is black out, as its not available. What did I setup wrong? Need help!
post #7044 of 10110
Choice of DVD-A? Where is that? Are you talking about the Setup menu? Where exactly?
-Bill
post #7045 of 10110
-Bill
Some setup items are not available when a disc is in the drive.
post #7046 of 10110
Foobar has a UPnP plug in that offers DNLA streaming. But the 105 can access those files directly on your PC if it's networked and shared. See: SMB.
post #7047 of 10110
You are so right! It got me worried for nothing! Thanks for the heads up!
post #7048 of 10110
What do you mean by not available in the US? Are you saying the French site won't allow downloads to US-based  IP addresses?
post #7049 of 10110
post #7050 of 10110
Correctomundo
