AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 29
post #841 of 5982
Originally Posted by gsr View Post
The dedicated stereo outputs (both XLR and RCA) can either be configured to be a 2 channel downmix OR as front R/L to be used in conjunction with the rest of the multichannel outputs. That choice is made in the Setup menus. Even though they're still using just a pair of DAC channels, the rest of the DAC implementation is better on the stereo outputs.
Thanks.. I think this is new, I could not do that (or never figured out how) with the 95, so that's great!
post #842 of 5982
Nope, it's not new to the 105 - the 95 has the same feature. See page 74 in the BDP-95 manual:
Stereo Signal: To select the audio source that will be processed and sent out through the STEREO
AUDIO OUT and the XLR BALANCED STEREO AUDIO OUT terminals. The available options are:
Down-mixed Stereo – The stereo or down-mixed stereo signals are processed and sent
out from the dedicated stereo output terminals.
Front Left/Right – The original Front Left (FL) and Front Right (FR) signals are sent out
from the dedicated stereo output terminals. The purpose is to fully utilize the better DAC
hardware originally assigned to the dedicated stereo outputs for customers who prefer
multi-channel speakers and do not need the dedicated stereo output or zone 2 output.
When this option is selected, the dedicated stereo output ports should be used as the Front
outputs of the 7.1ch / 5.1ch / Stereo Audio group. The original FL/FR RCA connectors
should not be connected.
The same feature is included on the 105.
post #843 of 5982
never set it up right, I will now. This will save me a pair of RCAs for F/L...
post #844 of 5982
burn in _
could some on explain the best way to burn in the oppo bdp-105 ?
thanks
paul
post #845 of 5982
Originally Posted by JazzGuyy
Why does he need shielded speakers? Unless his display is CRT-based there is no need for the center speaker to be shielded. Plasma and LCD displays are unaffected by unshielded speakers.
Originally Posted by jimshowalter View Post
Don't know. He started out by saying he wanted a shielded speaker.
Yup. "big tube" was my euphemism for CRT. I've got a Sony KV-34XBR910 (http://www.soundandvisionmag.com/article/sony-kv-34xbr910-34-inch-hdtv-monitor) and it's still looking too good to put out to pasture. Thanks for the shielded center speaker suggestion. I'll look into it.
post #846 of 5982
I am an extremely happy 105 customer now:
1. The beta firmware fixed my lip sync issue
2. Kinsky app on my iPad has enabled me to use my iMac with Plex Media Server and control content wirelessly streamed to the Oppo (easier than navigating the network menus)
post #847 of 5982
Originally Posted by p.dow View Post
burn in _
thanks
paul
There is no special burn-in procedure (it's not like you will have image retention as on a plasma display). Some people swear that after 20 or so hours, the AQ sounds better than right out of the box. Other people think this is nonsense and that there is no such thing as burn-in for electronics. No matter which camp you're in, all you have to do is use it normally (and maybe be less critical of AQ over the first few weeks).
post #848 of 5982
Regarding the 1205B Public Beta Firmware
My personal opinion is that everyone active in this thread should update to the 1205B Public Beta firmware.
It has important bug fixes, and no significant new gotchas that are not also present in the current Official firmware.
Be advised that using a Beta firmware means you will have to do a USB (or, if you really must, a burned-disc) install BOTH WAYS. That is, if you are currently running the Official firmware you'll need to do a USB install now to get the Public Beta firmware. And you'll ALSO need to do a USB install later to get the next Official firmware whenever it is released. Network update only applies when going from Official to newer Official or from Public Beta to newer Public Beta.
But doing a USB install is no big hassle, and if you've never done it before now's a fine time to learn how. The instructions are on the OPPO support page for the 1205B Public Beta firmware.
--Bob
post #849 of 5982
In the US, Crutchfield has now posted their Product Research for the BDP-105
http://www.crutchfield.com/p_768BDP105/Oppo-BDP-105.html?tp=171#details-tab
Select the DETAILS tab on that page, if it doesn't open to that tab automatically.
Crutchfield is unusual in that they don't simply regurgitate the manufacturer provided write ups on products, but instead actually try to use the products themselves and write up what they've found -- based on the manufacturer's stuff as a starting point of course.
Crutchfield has just posted that for the BDP-105 -- based on the Official 1018 firmware. I don't think there's anything in there which will come as a surprise to folks following this thread, but of course it is formatted differently, so you may find some nuggets in there that you've missed.
If you spot any MISTAKES in the Crutchfield write up, please do post them here, and we'll see what OPPO can do to get them corrected.
Note that their Features and Specs chart makes no mention of the player's digital inputs. Evidently Crutchfield's spec list for players still is not quite ready to handle the concept of a player with inputs! biggrin.gif
The inputs ARE mentioned in the Product Reasearch write up. The HDMI Inputs are mentioned in the Video section. The other Digital Audio Inputs are mentioned in the Audio section, with the ARC input via the HDMI outputs listed separately from the other Inputs.
--Bob
Edited by Bob Pariseau - 12/8/12 at 9:23am
post #850 of 5982
Can I get the Oppo warranty if I order the unit elsewhere (somewhere closer to home as I am 5 days from Calif via standard shipping)?
post #851 of 5982
Of course. Any "return policy" on the new purchase would be up to whoever you buy from, though. If you buy from the OPPO Digital web site they offer a 30-day easy return policy (all you risk is the shipping).
Also if you buy a modified player -- e.g., the seller has opened up the player and added something, such as a 3rd party, Region-free mod -- then obviously you'll need to deal with them for problems with that.
--Bob
post #852 of 5982
--Bob
Thanks Bob! I forgot about the 30 risk free so will go with Oppo direct as I did on my 83.
post #853 of 5982
^ By the by, just in case you haven't noticed, the OPPO Digital Warranty on the BDP-105 (and BDP-103) is now a full 2 years! smile.gif
--Bob
post #854 of 5982
OPPO BDP-105EU test: a marvel! (translated hdfever.fr)
Published December 8, 2012 by Nicolas Bécuwe
A very extensive review with a ton of images.
Original URL
post #855 of 5982
Originally Posted by edwardkim View Post
I cancelled my order with Solutions AV who has been less than professional, and placed my order with Only the Best Rated who will ship my 105 tomorrow ...
Out of fairness, I should clarify that WE cancelled this order, and not the other way around.
I'm not going to start a whole big controversial discussion in this thread, but as a business owner I refuse to service customers who come onto my premises and throw around personal insults, as well as making demands of us that are outside of our policies, becoming argumentative with us in front of other customers, while we try to calmly and patiently resolve the situation.
We strive to provide excellent service. Sometimes though, this just can't happen no matter how hard we try.
As for the other post referenced by Edward, we received our inventory on Wednesday late in the afternoon (a day later than expected), and worked ferociously with our warehouse staff to get the vast majority of our backlog cleared up without any further delay. I have been very apologetic to customers who have contacted us for the delay. I do understand the eagerness to get products as soon as they're released, and we do try to make logistical decisions to bring stuff to our customers as quickly as possible.
Please note this is not intended to be a commercial message to solicit business. I just want to clear the air on these posts and let posters and readers here know that we're not another faceless company as these posts might suggest.
post #856 of 5982
Original URL
Nice review! I'm looking forward to trying the 105 very soon:D
post #857 of 5982
I had a 103 and no lip sync issues, I sold the 103 to a friend and bought the 105 for improved audio feed to my dedeicated two channel audio system.
With the dedicated audio outputs the timing is way off, not as bad when I use the FR FL downmixed outputs. I would like to use the dedicated audio outputs for watching Directv as well but with the lip sync issue I can't
So my question to anyone , how do I implement the firmware fix? I have a computer but only dial-up (slow) internet and not very computer savy, any help would be greatly appreciated. smile.gif
post #858 of 5982
--Bob
Since this is my first Oppo player I was nervous of bricking it somehow. However I just downloaded the 1205B Public Beta firmware to my computer and then was automatically prompted to burn the iso file onto a CD. Inserted the burned CD disc into the Oppo BDP-105 and it uploaded sucessfully. The only out of sequence event was that I had to eject the disc since the player shut off after updating as it is supposed to do.Then had to power cycle it and reset to factory defaults. It was very easy and relatively quick. Next trip to BB buy a USB thumb drive.
Edited by Sharp1080 - 12/8/12 at 12:51pm
post #859 of 5982
Originally Posted by Sharp1080 View Post
Since this is my first Oppo player I just downloaded it to my computer and then it then automatically prompted me to burn the iso file onto a CD. Inserted disc into the Oppo BDP-105 and it uploaded sucessfully. The only out of sequence event was that I had to eject the disc since the player shut off after updating as it is supposed to do. It was very easy and relatively quick. Next trip to BB buy a USB thumb drive.
Thanks, I guess I will get a thumb drive thingy and see if I can figure it out, I am pretty sure my computer doesn't burn anything to disk, at least I never did such a thing.
post #860 of 5982
**Throw away the Preamp**
The Oppo 105 sounds more transparent without a preamp than with a preamp in my opinion. I've tested a variety of preamps with various topologies (passive, transformer volume types, autoformer volume types, active types, tubes and solid state of varying price ranges).
I could not find a single example where the Oppo sounded better with a preamp. All of the preamps added a veil or slight coloration to the sound, some more so than others. A good preamp should have no sonic signature in my opinion. Some people say the preamp provides nice "warmth". In these cases the preamp is merely being used as a tone control and the listener should perhaps consider altering the source to achieve their desired sound.
It's also difficult for someone who has spent $10k on a preamp to admit that it adds no value. A friend who offered his preamp for comparison was shocked his so called "high end" preamp was virtually redundant in the Oppo setup at least. In fact nobody has so far preferred the sound with a preamp, even the "warmth" fanatics.
I suspect what we are dealing with here is power supply. Oppo is able to provide sufficient body to the music and throw a wide and deep soundstage probably because of its robust power supply. Couple this with a beautifully designed volume control and you have a recipe for great sound.
What I've found over the years is CD players and/or dacs with puny power supplies generally need "more help" from the preamp to convey a live performance. The BAT VK-5SE is a good example. Most CD players when plugged into a PS audio P 300 drew 10 -50 watts. Compared to the old BAT which drew over 250 watts and threw a magnificent but natural sound stage. Unfortunately the BAT was far less transparent than the 105.
Does it have enough gain?
I tried a number of different amplifiers with varying input impedances from 10k - 100k with no problems. My understanding is the 105 output impedance is 100 ohms, and BDP 95 is 390 ohms (someone correct me if I'm wrong). I did have a few problems with the 95 and some of these amps but no problems with the BDP 105. The general rule of the thumb I've traditionally used is the input impedance of the amp should be 20+ times the output impedance of the preamp. So I'm not sure why I had problems with the 95 as even the 10k amp fits within these guidelines.
In any case, I'd say there would be enough gain for 95%+ of users. Personally, I'd prefer a little more gain as my setup is fairly unique running 4 way active which results in attenuation sensitivities/differences between the drivers and amplifiers. I'm currently running the volume at 80-90% which is fairly loud and 100% for very loud or very quiet recordings. What I'd like to see is a gain mode similar to the most transparent preamp I've heard irrespective of price, my out of production autoformer based Bent Audio TAP-X. This preamp automatically engages gain mode as volume increases above unity gain. So on the Oppo some sort of unity gain would be useful that kicks in say above 95%.
As a final note, I think the next version say the BDP 115? should include analogue inputs so the vinyl, analogue tuner and reel to reel guys can plug into the Oppo for a complete audiophile solution.
Edited by djkiwi - 12/8/12 at 4:31pm
post #861 of 5982
djkiwi, I agree with your assessment of ditching the pre-amp and running audio direct to the amplifier for better sound. My experience was quite revelatory. Problem is that many of us use our pre-pros for things other than the Oppo and in my case, having a dedicated system solely for the enjoyment of music is impractical. It did sound darned nice though....... so much so that I had to revert back to using the pre-pro or risk getting addicted.eek.gif
post #862 of 5982
Originally Posted by djkiwi View Post
... As a final note, I think the next version say the BDP 205 should include analogue inputs so the vinyl guys can plug in their phono preamps for a complete audiophile solution.
Or for other things like my Sony tuner that only has analog outs. I have a small standalone ADC on the way hoping that it will work OK to solve the problem of no analog ins on the 105.
post #863 of 5982
A question regarding the volume shown on the units display: Seems I read somewhere that the volume is now indicated on the display (is not on the 95), how visible is it from the listening position say 7 to 8 feet away? Is it a progress bar or just the numerical value? Thanks
post #864 of 5982
It is numerical on the display 0-100. I'm 12 feet back and can see it clearly.....
post #865 of 5982
--Bob
Yes I had noticed that Bob. So nice to get more than just one year, if that!
post #866 of 5982
Everyone,
For what it's worth, my BDP-105 that I pre-ordered from Solutions AV, was shipped on 5 December 2012, and should have been delivered the next day but Canada Post didn't get it to me until the 7th. This is the second Oppo unit I have ordered from Solutions AV and I would have no hesitation on ordering from them again. And I have no personal or professional affiliation with the company in any way shape or form.
Cheers.
post #867 of 5982
You probably have a fast internet site you can go to. I used to use the public library or a coffee shop.
The instructions on OPPO's web pages are pretty complete.
Else contact them and ask them to send you a firmware disc. Specify you want the latest public beta.
-Bill
post #868 of 5982
I certainly won't throw my preamp away. Selling it on Audiogon would fetch me enough to buy 4 BDP-105s.
As far as the BDP-115 I think what it needs more than analog inputs is more attention to the ergonomics of having it serve as a preamp.
post #869 of 5982
Thanks for letting us know your side of the story as it clears up things a bit. Edwardkim's version of the story just seemed a bit off to me as no company would be in business for long if it operated the way he indicated yours did...
Edited by dmusoke - 12/9/12 at 11:18am
post #870 of 5982
Nope ... both 95 and 103/105 have output impedances stated at 97 ohms(well within the margin of error for a +/- 5% 100 ohm resistor). The headphone output of the 105 has a 10 ohm output impedance. Something else about the 95 or something in your system made the 95 sound unpleasant to your ears.
