AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-105 Owner's Thread
Official OPPO BDP-105 Owner's Thread - Page 286
post #8551 of 10180
Originally Posted by DanF8500 View PostHave you tried using the 105's dedicated stereo outputs in place of its multi-ch Front L/R outputs to utilize its dedicated stereo dac? That would give you a slightly higher fidelity from your front speakers. If you do that, change the "Stereo Signal" setting to "Front L/R" and remove the cables from the front L/R rca outputs.
I have, but then multichannel SACD doesn't work?
post #8552 of 10180
What do you mean? Please give more details...
post #8553 of 10180
Originally Posted by DanF8500 View PostWhat do you mean? Please give more details...
So I plug in XLR cables in for stereo to my pre/pro 7.1 Analog Audio in and don't plug the two RCA cables when playing Multi-channels SACD I get only two channels! Like it's defaulting to Stereo?
http://www.oppodigital.com/blu-ray-bdp-105/images/BDP-105-Back-hr.jpg
post #8554 of 10180
In Setup did you select "Audio Processing" and scroll all the way down to "Stereo Signal" and change it to "Front L&R"?
post #8555 of 10180
^^ WSE, I think you have a pre/pro zoning issue. Are you sure you can run xlr and rca inputs on your pre-pro simultaneously? You need both the multi 7.1 bank and Analog Audio input bank on your pre/pro active at the same time. If you can't set it up that way, then just use the 105's dedicated RCA stereo outs, and attach those to your 7.1 multi inputs on your pre/pro. Seriously, you don't need to run XLR out on your 105, since it looks like your pre/pro is converting all its inputs to balanced outputs..
post #8556 of 10180
Originally Posted by oneartist View PostIn Setup did you select "Audio Processing" and scroll all the way down to "Stereo Signal" and change it to "Front L&R"?
I will take a look, maybe that's what I need to do, I thought I did
post #8557 of 10180
Ok folks while listening to two channel music last night I had sound coming from all 7.1. I have my oppo 105 hooked directly to amps. I am using the dedicated stereo outputs for front left right. I have it set on downmix 7.1. Then down further I tried both downmix stereo and front left/right. Front left/right sounds real compressed. Volume lowers to about half. Downmix stereo sounds much better but is not the right setting. What is going on here? Please help a clueless person.
post #8558 of 10180
Originally Posted by Hamlet00 View Post
I did some a/b comparisons between the hdmi out and analog outs (both stereo outputs and multi l/r) but could not discern any difference at all in sound. I thought the Oppo dac would provide some noticeable difference in sound quality but that was not the case for me.
The outputs went to a Sony avr receiver (their flagship es model about five years old). For source I used both the Oppo with Redbook cds as as well as a squeezebox touch streaming (digital coax to the Oppo mostly, but also tried with it's dac (analog to the Oppo) but no noticeable difference either). Speakers are Ascend ribbon towers.
I might not have a golden ear but I know I am not deaf either as I can easily hear changes to sound when making subtle eq adjustments, subwoofer levels/crossover etc.
Any comments?
I tried my 0ppo BDP95 through a Yamaha 5917 (I think) analog inputs with no processing so olny the vlume worked. It killed the sound, dry flat and lifeless compared to direct connection to a Bryston 3B ST. Tried the same with an Arcam AVR300 and it was much, much better but still not comparable to direct to amp sound. I sold the old Yamaha long ago and the AVR300 has set undused for a couple years now. If you aren't going directly to amps the receiver is colouring the sound despite any bypass buttons or whatnot are claiming.
BTW I have a 105 waiting for me today, upgrading from the 95 just for the hdmi inputs so I can run the PS3 and sattelite receiver into it. I really like the sound of the 95 and am hesitant to change anything now that I have everything sounding great but I really want the hdmi in... I'll eventually post a comparison of the two, hopefully the 105 lives up to the sound of the 95...
post #8559 of 10180
Here is the way I understand it. If you set the two outputs to Front left/right you have the same processed digital signal coming from these outputs as you do from the Front left/right outputs of the 7.1 analog outputs. The ONLY difference is you are using the better dac. So it's the same digital signal as what goes to the front left/right in the 7.1 analog outputs but better digital to analog conversion.
If you set them to downmix stereo you have the entire digital signal weather it be a 5.1, 7.1 or stereo digital signal sent to the better dac as a stereo signal and processed and sent to the left/right analog outputs.
So these outputs either give you the Front left/right digital signal OR the entire digital signal broken into left and right channels.
Correct me if I am wrong please.
post #8560 of 10180
I thought the DACs are the same, both 9018 eight channel. The two channel side also does the the headphones. Assume the two channel side has a better analog section?
post #8561 of 10180
I am still hoping for a 105D...
post #8562 of 10180
Crystal ball says to check back later....
post #8563 of 10180
I bought a Darbee before I got the 105 so now I kind of have A 105d
post #8564 of 10180
Hopefully it will have some of these technologies http://www.oppousa.com/features.html
post #8565 of 10180
Have you tried "Playback Setup -> SACD Priority -> Multi-Channel" in the Oppo menu?
post #8566 of 10180
I installed a 105 in the media room and moved a 95 to the living room so a satellite HD-DVR could use the superior AV processing of the 105. Video from HDMI-1 goes directly to a projector, HDMI-2 to a monitor. Stereo goes to an analog preamp (set at unity gain) that is shared with a phono stage and a Sony 5400ES, surrounds directly to amps, SW to a LF ARC that manages the subs. The result is superb audio and video for music and HT. Audio from the 105 is at least as good as that from 95, possibly a bit better.
db
post #8567 of 10180
Dan,
One problem with your insistence that DLNA is the only answer is media control products like JRiver cannot be utilized fully when a device like the Oppo is the Renderer. For example you will have 0 benefit of JRiver's many DSP functions like Volume Leveling (which is a big issue for me). So to utilize JRiver/J Remote fully the only option is to use the USB Input. By accessing the Oppo DAC this way it makes JRiver the Renderer.
A path I am reluctantly heading towards..........
post #8568 of 10180
Originally Posted by dmusoke View PostHave you tried "Playback Setup -> SACD Priority -> Multi-Channel" in the Oppo menu?
Yes!
post #8569 of 10180
Originally Posted by FMD View Post
Dan,
I disagree totally!! Someone would have to shoot me in the head and torture me to listen to my music with any added DSP from third party software! I didn't grow into appreciating music that way and never will. I want to hear the digital media exactly the way it was produced. I use dlna/upnp media software/apps to simply create/maintain my music database and push my media files "unabated" via my home network to my 105. No laptop/pc or tv is required to be on.......my iPad, NAS, home network (router), 105, amp, and speakers......Life is good!!
Edited by DanF8500 - 1/8/14 at 12:26pm
post #8570 of 10180
I disagree totally!! Someone would have to shoot me in the head before I listen to my music with any added DSP from third party software! I didn't grow into appreciating music that way and never will. I want to hear the digital media exactly the way it was produced. I use dlna/upnp media software/apps to simply create/maintain my music database and push my media files "unabated" via my home network to my 105. No laptop/pc or tv required. Life is good!!
I am not a fan of DSP's either.
But, with USB you can bypass the Windows Mixer. I am not sure if you can with DLNA.
Do you know?
- Rich
post #8571 of 10180
Do you know?
- Rich
AFAIK, the Windows Mixer doesn't come into play unless the content is converted to LPCM on the PC. With DLNA, the files are basically just sent directly without modification (as long as transcoding is disabled).
post #8572 of 10180
WSE
Your pre/pro looks similar to my B&K in that you appear to have one set of multi-channel inputs which are only RCA, and multiple analog stereo inputs one of which is XLR. If true, you will need to use the RCA outputs of the 105 to the RCA inputs of your pre/pro for multi-channel use. Also, if your pre/pro balanced inputs are a different input selection than your multi-channel selection (like CD or stereo input 1 or something), you can connect the XLR outputs of the 105 to those XLR inputs on your pre/pro. However, be sure your XLR inputs are to input a device other than the multi-channel device (be sure you are not trying to connect both the RCA and XLR outputs to the same input). My B&K allows this set up but I'm not certain yours does.
Chuck
post #8573 of 10180
I understand where your coming from. I am happily streaming FLAC's via DLNA to the Oppo bit perfect (and using JRiver/J Remote which are fantastic) BUT the variability in my library makes me want volume leveling at times. I may have to rethink that based on your comments and live with the variation. A NAS is definitely in my future as well.
post #8574 of 10180
I told wse something similar to you, but didn't get a reply back from him...frown.gif
post #8575 of 10180
Volume variability exists throughout my entire media collection.....it's a product of the way each disc/album was recorded by its engineers. I always adjust my volume control, especially when I'm playing random tracks from one disk's tracks to another. The 105's remote or my iPad is always by my side to adjust volume to my liking....
post #8576 of 10180
Well after spending months struggling with the Oppo 105 blu ray player and his erratic behavior with external Hard Drives, I decided to get an LG blu ray player at Wal Mart for $29.99 that claims to play almost all video formats under the sun using its USB input, the player is only twice the size of the 2 tb hard drive itself and a fifth its weight. PROBLEM SOLVED, I can watch all video on my hard drives, big and small without a hitch.
How come a players as solidly built as the Oppo with an amazing array of features, beautiful picture and sound, can be so buggy playing hard drives? Does Oppo have this feature as an afterthought or is it just plain incompetence? The LG player cost $29.99 to the customer after everybody on earth has already made money on it and it performs this particular function flawlessly. Why my $1,200 investment, the Oppo 105 is incapable of performing this simple task is beyond my comprehension.
post #8577 of 10180
I don't remember what all your issues were with using hard drives with the Oppo, but do keep in mind that there are quite a few things the Oppo can do that the $29.99 LG player can't.
post #8578 of 10180
I've lost track of your problem. Did you ask OPPO for help? I play a lot of media files from hard drive, optical disc and USB stick and have no issues.
-Bill
post #8579 of 10180
Originally Posted by DanF8500 View Post^^ I told wse something similar to you, but didn't get a reply back from him...frown.gif
Thank you
post #8580 of 10180
Originally Posted by luismanrara View PostWell after spending months struggling with the Oppo 105 blu ray player and his erratic behavior with external Hard Drives, I decided to get an LG blu ray player at Wal Mart for $29.99 that claims to play almost all video formats under the sun using its USB input, the player is only twice the size of the 2 tb hard drive itself and a fifth its weight. PROBLEM SOLVED, I can watch all video on my hard drives, big and small without a hitch.
Send an email to OPPO with the LG model they will taking apart and hopefully learn
