Hello, i am new to this and need urgent help in setting up dual projector passive 3d setup for my home. I have read many articals about the dual projector setup and decided to make one for my home theater room
I bought - 2 dlp projectors - benq ms660
circular polarized lens
circular poalrized glasses
Silver screen
and got the dual stand made for projectors.
First step, i downloaded the stereoscopic player
Now i have window xp installed with nvidea 560 card with dual output
I connect one output with hdmi and second with dvi to hdmi cabel
after i run windows, i run nvidea setup and run dual ( extended screens) and both left and right view start coming on screen
my problem is when i run side by side ( any 3d movie ), i am getting the double image and when i wear the glasses, image looks single and clear to me, But my only problem is, it looks Plain 2d image and not 3d image. No pop out effects are also visible.
I read on many forums that results are very good in polarized 3d but my image is looking plain 2d image.
Can anyone help me and advice me where i am doing the mistake, which part needed to be corrected here.
Thanks in advance
