AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › How long should the Skip 079 HDD Format take? Philips DVDR3575H/37
post #1 of 6
I just did this on my unit after I was starting to get more system errors on my Philips DVDR3575H/37 (bought a refurb from Philips in approx. 2008). I also upgraded the FE Firmwear to _016.
When I did the Skip 079 to format the HDD, after I pressed Enter the unit stayed on for a few secs. then just shut off. I would think a format of the drive would take a few minutes like a desktop PC. The clock was reset to the default time etc... so I assume something happened but was just wondering if the drive was even formatted .
post #2 of 6
SKIP 079 is not a "format" as we think about it with a computer. These DVDRs do an "Initialzie" which ID's the HDD and loses all content so it can start over from sector 1. It's a "blip on the screen" compared to a "HDD format."
Skip 013 is more a format that SKIP 079 since it "checks" or works on all sectors/bits.
post #3 of 6
Thanks for this info, did not see the Skip 013 mentioned.
Just finished the scan/format and all is "OK" except for the HDD Head Check which says "NG :E27"
so the Result also states "NG" which I assume is NOT GOOD (?).
Is this anything to start worrying about or should I get a new Magnavox unit? Maybe a new HDD?
Thanks again for the insight.
post #4 of 6
NO!
My story with a totally "NG" (No Good) HDD:
I got a refurb'd 3575 from another member that had a "glitch" or two on its HDD. It would freeze playback of the first three titles, NEVER completed a SKIP 079, NEVER did a SKIP 013 without finding everything "NG," and was slower than normal on startup and slightly noisier than normal when on.
At first, I just left the first three titles in place to avoid playback problems. Then, I decided to make sure I used ALL the bits on the HDD (after reading expert articles that said it would help prevent "bit fade" if done every year or two), so I just kept recording a 3-hr nightime timer program (talk shows) at HQ until the HDD filled up. I then used HDD Menu > Delete All Titles and did the fill-up again.
After a couple or three fill-ups, the HDD repaired itself to the extent that it was still slow and noisy, but NO playback problem and SKIP 079 and SKIP 013 OK.
All that was about 2 years ago and its still going strong today!
So, I'd advise trying a few "fill-ups" if it's convenient (as it was for me) and see if your HDD will repair itself? Our HDDs have lots of extra sectors just for that purpose.
Edited by wajo - 11/16/12 at 1:23pm
post #5 of 6
Wow, great info and I never have tried to keep more than a few titles on my HDD at any one time.
I usually record a few shows from network tv and a few movies during the week on HBO, Show etc... and have never had more than 5 or 10 saved at any one time. Always thought it was better just to get rid of them when I was done viewing.
Will give this idea a shot!
post #6 of 6
**UPDATE**
After filling-up the HD in HQ mode and then deleteing the titles a couple of times, NO MORE disk errors or issues so far!!
Thanks for the great help!
  Back to Forum: DVD Recorders (Standard Def)
