So I am about to mount 2 LG PA70Gs on my ceiling for a dual screen setup. I want to run both in 4:3 (side by side). My wall is 162" wide, so if my math is right, each screen/projector will be 81"W by 60.75"H (since I want to stretch the entire length of the wall). Now I have 3ft tall floor speakers that will be under the screen, so the screen\image should fit PERFECTLY (stretching to the corners/ceiling of the room), although im worried it might be a tad high, hopefully people will be sitting far back enough not to hurt their necks...
Anyway, given the above dimensions, how do I calculate where to install my ceiling mounts? I imagine I could get ok results by just eyeballing it, but I would rather be perfect. Also, will I lose much clarity/resolution the more I 'tilt' the projector? In other words - is it ok if the projector is HIGHER than the center of the screen? I mean it cant hang too low, or people would bang their head on it, but just curious...
