Originally Posted by JimWilson
Honestly, I'm not sure the PB1000 or SB1000 would be a good choice given your circumstances.
You have Maggies, which aren't the easiest speakers in the world to seamlessly integrate with a subwoofer. As good as the new 1000 series are they're still budget subs at heart. To get a smooth blend you'll probably need something a little better. And then there's your room...
Assuming just an 8 foot ceiling height you're over 3100 cubic feet, which is not all that small. You should strongly consider duals, like a pair of SB12-NSD's. If you would rather have a single unit perhaps an SB13-Ultra might be more to your liking.
If you're set on the 1000 series then a pair of SB's would probably be the best option. I think they stand a better chance of integrating with the Maggies.
Thank you very much for your response. I do have a couple of questions though. Are you recommending the SB-1000 instead of the PB-1000 because I want to use it primarily for music, or because I have MMGs? I really wanted to spend $600-700, but I guess I am going to have to spend more.
What do you think if I buy one SB-1000 now and save to buy the other one later? I don't want to be completely unsatisfied with one while I save more $$.
Thanks again,
Victor
