I am starting a thread on what's the best Amps, Receivers to pair with the JTR Speakers range.
As you all know, the JTRs are extremely powerful (can take up to 1600 watts) and extremely efficient speakers that sounds fantastic for the Hometheater and loses nothing in Music...
So, some people have gone the route of using separates to power them so as to bring out the maximum shine of these speakers. Here, please add your setups with the JTRs and your reviews of them so that future JTR buyers can make a more informed decision on what to use with their own budget in mind.....
This is not truly a showdown of Amps, but rather a discussion on what's everyone's using and how they find them with their JTRs...
Here's what I am considering right now with the following Options (feel free to suggest others). I am a bit budget conscious to speak the least:
1. 3 Crowns XLS 1500 ($379 each). Each bridged mono will deliver 1550 watts to my LCRs (JTR Noesis). The rest will run off my receiver (either onkyo 3010 or 3009). Cost : $1160
2. Maybe just 2 Crown XLS 1500 for LR, but use the Emotiva XPA-100 which delivers 400 watts into the Center ($379). Why this setup? Because I can then compare to see if the Emotiva is better or the Crown on a side by side showdown. As per specs, the Emotiva will have a slightly better noise to signal ratio but lack the 1550 watts. But the Center may not need all the 1550 watts. 400 watts of clean power may be all that's required for dialoque. Cost $1160 (same as above).
3. I also briefly looked at the Behringer EP 4000 which after some searching, found some disappointing reviews so am not considering it now.
4. Cheaper options would be: The Emotiva XPA-5 which will give you 5x300 watts for a total of $769 (but then this would not much more power than my Onkyo can deliver.. i think it can easily deliver 160-200 watts per channel at 4 ohms in a 240v outlet.
5. More expensive option would be the Emotiva XPR-5, which delivers a whopping 5x600watts for a total of $1699 (quite a bit more than the first two options).
Note: all the Watts are calculated for 4 ohm speakers.
ICEPower Options
I have also looked at the highly recommended ICEPower Class D amps like the Wyred 4 Sound and the D-Sonics. Most of the reasons given were because these run cool and silent. As for sound quality, unless someone have actually compared the Crowns vs these, I am gong to assume they are the same, with the Crown giving more power. They are both class Ds.... Also, from some reviewers on the Crowns, they too run pretty silent and the fans hardly turns on so it's really a non-issue with the noise as well.
Can someone also tell us more about what THD, SNRs, etc mean in the AMP and what's the ratings that is desirable for the JTR Speakers? I mean, for instance, an amp may say SNR at 1 watt > 93, full power >117, what does that mean and at what levels will you start to get annoying hissing sounds from the JTRs?? And what about THDs??? 0.1%? 0.05%, do they make much difference in real life hearing? Reason I asked is because the JTRs are hightly sensitive and at some point some amps with not as good SNR may not be suitable
Feel free to discuss other things needed for JTRs like, what sort of AMP sockets needed for the gears, do we need 20A power points with certain setups? for instance, the Orbit Shifters puts out 7200 wats peak.. do we need to run that off a separate 20 or even 30A power point???? And if you're using a lot of Amplification for all speakers??
Edited by coolgeek - 11/17/12 at 11:52pm
ICEPower Options
