AVS › AVS Forum › Video Components › Home Theater Computers › nVidia Driver update?
post #1 of 14
Windows Update is asking to install the following:
Code:
nVidia - Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Other hardware - NVIDIA GeForce GT 430
Download size: 171.6 MB
You may need to restart your computer for this update to take effect.
Update type: Important
nVidia Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Other hardware software update released in October, 2012
More information:
http://sysdev.microsoft.com/support/default.aspx
Help and Support:
http://support.microsoft.com/select/?target=hub
I am currently on WHQL 301.42. I notice on the GeForce website that the current WHQL driver is 306.97. Are these the same as the 306.97 driver release date is October 10, 2012.
I also looked at the change log and it looks as if this driver is mostly updates for better performance for gaming. Is anybody using this driver? What, if any, improvements are you seeing for HTPC use? Does it fix the 29/59 bug? I have two channels infected with this that play beautifully with my Echo extender but are un-watchable using my HTPC, less I want to either be put into an hypnotic trance or barf on my carpet.
Thanks..
post #2 of 14
Sammy I'm using the 306.97 driver without any problems. I moved up because I couldn't get my 'custom res for 23.976' to stick with any of the previous releases - no other benefits, increased performance that I can see since upgrading. Sorry can't help with the 29/59 bug - don't use those refresh rates.
post #3 of 14
Do you have to re-configure the custom refresh rates? Mine's already at 23.9758 and that's good enough for me. If I have to do it all over again and there's no other performance increase for me then it isn't worth it to me to update it as everything is working fine right now.
post #4 of 14
Yes I believe each upgrade requires a further stab at the custom resolution - If it hadn't been for the issue I had with my custom resolutions not sticking with the previous drivers I doubt I would have upgraded. Did it more out of necessity and desperation.
post #5 of 14
When installing a new driver, there is an option: Custom mode > "Perform a clean install". If you select this, all the previous settings for the graphics card will be lost. Otherwise they will be kept.
post #6 of 14
Thanks Renethx that will save a lot of hassle in the future I'm sure
post #7 of 14
Yes, I had to reset my settings, but the good news was nVidia finally made it so that you can actually see the sliders for the vertical and horizontal adjustment for screen size now, so it is easier now to get things set up again.
I don't update video drivers very often, so I don't know how long ago they made that change.
post #8 of 14
Not if the update is through Windows Update, which is how mine arrived.
post #9 of 14
That said, is there any reason to install this update? It seems to be geared more towards gaming and 6xx cards. I have a GT 430 in an HTPC that sees absolutely no gaming and has real smooth playback already. If it ain't broken, fix it until it is? Or does this help with the 29/59 bug?
post #10 of 14
This is exactly why I'm asking here. I have Windows Update set to let me decide rather than just doing stuff I maybe do not want it to do. If I do the update, it will be from nVidia's website.
post #11 of 14
That is a Windows issue.
post #12 of 14
post #13 of 14
It's not fixed it just isn't as noticeable.
post #14 of 14
Code:
More information:
Help and Support:
Sammy2, I believe I have the exact same graphics card as you, and I too am getting the same update prompt on my system (Win7 x64). The DL size is a little bigger in my case, something like 220MB. Don't know why this one is classified as an "Important" update by MS, but at the moment I am hesitant to apply this update... simply because everything is working just fine right now. I'll be watching this thread.
