AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Need a wall mount for my Panasonic 55VT50...
post #1 of 2
I need a wall mount for my Panasonic 55VT50. I prefer something that tilts/telescopes a bit. I went to Newegg but there are so many brands/options it's mind boggling. I don't want to spend a fortune, Best Buy had a few in the 400 to 600 dollar range which seems positively nuts to me. Hoping to find a good option for 250 or less...
I'm looking for recommendations on brand or specific models...hopefully we can include some links since it's not actual TV's I'm asking about?
post #2 of 2
My particular mount of choice is the Peerless PLA60 and Amazon has some vendors selling it below your budget. I have the smaller PLA50 version and it's fantastic.
But Monoprice has several inexpensive articulated wall mounts for well under a hundred bucks that will work just fine in most situations. Their wall mounts are very popular around here.
http://www.monoprice.com/products/subdepartment.asp?c_id=108&cp_id=10828&cs_id=1082806
