TX-NR1010
Special Features
Product Specifications
Amplifier
# Channels 7.2
Power Watts/ch -
Power (8ohms 20-20kHz 0.05%) /Ch 140W (8ohms 20-20kHz, 0.05%, 2 Channels Driven, FTC)
THX Certified Ultra2 Plus
Continuous 6ohms Rated
Certified 4ohms performance
All Discrete Circuitry
3-Stage Inverted Darlington Circuitry
PUSH-PULL Design
Independent Block Construction (Amp/Preprocessor)
Toroidal Transformer -
Independent Power Supply -
Bi-amp Capability For Front
BTL Capability For Front -
Digital Crossover Processing Network
Processing
DOLBY Decoder True HD, DD Plus, PLIIz
DTS Decoder DTS-HD Master Audio, DTS-HD Express
DTS Neo:X
Dolby PLIIz
ONKYO GAME Surround Modes
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Audyssey Dynamic Volume
Direct/Pure Mode /
Music Optimizer (Advanced)
192K/24 Bit DACs (Burr-Brown)
VLSC
isf Certified Calibration Control
Connectivity
Audio I/O 8 / 1
Phono Input
Digital Audio IN (OPT/COAX) 3 / 3
Digital Audio OUT (OPT/COAX) -
Composite I/O 5 / 1
S-Video I/O - / -
Component Video I/O 2 / 1
Front-Panel A/V V / R / L
Front-Panel Optical
USB Input Front (made for iPod/iPhone) and Rear
HDMI I/O 9 (7 + 1)/ 2
HDMI Support 3D video, Audio Return Channel, DeepColor, x.v.Color, LipSync, CEC
Component Video Upconversion -
Analog To HDMI Upconversion
1080p Upscaling (HQV Vida)
4K (up to 4096 x 2160) Upscaling (Marvell Qdeo)
Multi-Channel Input -
Analog Pre-Outs 9.2
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 2 Video Out (Composite, HDMI)
Zone 3 Line Out
U-Port -
iPod Ready (direct USB input)
HD Radio
Internet Radio Capable (vTuner, Pandora, Spotify, Rhapsody, Sirius/XM iRadio, Slacker, LastFM iRadio, Aupeo, MP3tunes)
Streaming Audio From PC
Streaming Audio From USB memory
Wireless Network Ready via USB (optional UWF-1)
Bluetooth Ready via USB (Optional UBT-1)
PC Input (15 pin D-sub)
Integration Access
RS-232
IR Input
Ethernet
ONKYO-RI System Control
12V Trigger (zone 2/3)
Miscellaneous
Pre-Pro/Learning Remote /
Back-Lit Remote -
On Screen Remote Programming
Bi-directional Remote Setup via GUI
Activity Based Remote
Color-Coded Speaker Terminals
Auto Speaker Calibration W/Mic. (Audyssey MultiEQXT32)
OSD Out (advanced "Home" GUI)
Solid Aluminum Front
Warranty 2 YEARS
Amplifier Section
Power Output -
All Channels 140 W (8 ohms, 20 Hz-20 kHz,
0.05%, 2 channels driven, FTC)
Front L/R 140 W (8 ohms, 20 Hz-20 kHz,
170 W + 170 W (6 ohms, 1 kHz, 0.1%,
Center 140 W (8 ohms, 20 Hz-20 kHz,
Surround L/R 140 W (8 ohms, 20 Hz-20 kHz,
Surround Back L/R 140 W (8 ohms, 20 Hz-20 kHz,
Dynamic Power 320 W (3 ohms, 1 ch)
270 W (4 ohms, 1 ch)
160 W (8 ohms, 1 ch)
THD+N (Total Harmonic Distortion + Noise) 0.05% (20 Hz-20 kHz, Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
Maximum RCA Output Level and Impedance 5.5 V/470 ohms (Pre out)
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz-100 kHz/+1 dB, -3 dB (Direct Mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
80 dB (Phono MM, IHF-A)
Speaker Impedance 4 Ohms–16 Ohms or 6 Ohms–16 Ohms
Video Section
Input Sensitivity/Output Level and Impedance -
Video 1 Vp-p/75 ohms (Component)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response 5 Hz–100 MHz, -3dB
Tuner Section
Tuning Frequency Range -
FM 87.5 MHz–107.9 MHz
AM 530 kHz–1,710 kHz
FM/AM Preset Memory 40 stations
General
Power Supply AC 120 V, 60 Hz
Power Consumption 8.6A
Standby Power Consumption 0.1W
Dimensions (W x H x D) 17 1/8" x 7 13/16" x 18 1/4" (435 x 198.5 x 463.5 mm)
Weight 50.7 lbs (23.0 kg)
_________________________________________________________________________
TX-NR3010
Special Features
Amplifier
# Channels 9.2
Power Watts/ch -
PUSH-PULL Design
Independent Power Supply (4 Transformers)
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
VLSC
Connectivity
Audio I/O 8 / 1
Phono Input
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel Optical
HDMI I/O 9 (7 + 1) / 2
Analog Pre-Outs 11.4
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
HD Radio
Integration Access
RS-232
IR Input
Ethernet
12V Trigger (Zone 2/3)
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section -
Power Output -
Video Section -
Tuner Section -
General -
Power Consumption 11.0A
Weight 55.1 lbs (25.0 kg)
TX-NR5010
Special Features
Amplifier
# Channels 9.2
Power Watts/ch 145 x 9
Power (8ohms 20-20kHz 0.05%) /Ch 145W (8ohms 20-20kHz, 0.05%, 2 Channels Driven, FTC)
PUSH-PULL Design
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
192K/32 Bit DACs (Burr-Brown)
VLSC
Connectivity
Audio I/O 7 / 1
Phono Input
Digital Audio IN (OPT/COAX) 4 / 3
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel A/V Analog L+R + Optical / Composite
Front-Panel Optical
HDMI I/O 9 (8 + 1) / 2
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
iPod Ready (Direct USB input)
HD Radio
Integration Access
RS-232
IR Input
Ethernet
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section
Power Output -
All Channels 145 W (8 ohms, 20 Hz-20 kHz,
Front L/R 145 W (8 ohms, 20 Hz-20 kHz,
175 W + 175 W (6 ohms, 1 kHz, 0.1%,
Center 145 W (8 ohms, 20 Hz-20 kHz,
Surround L/R 145 W (8 ohms, 20 Hz-20 kHz,
Surround Back L/R 145 W (8 ohms, 20 Hz-20 kHz,
Dynamic Power 400 W (3 ohms, 1 ch)
300 W (4 ohms, 1 ch)
180 W (8 ohms, 1 ch)
Video Section
Tuner Section
General
Power Consumption 12.4A
Special Features
- 9in/2out HDMI Support for 3D Video and Audio Return Channel
- THX Ultra2 Plus Certified
- Network Capability Delivers Internet Radio and Network Streaming
- Dual Core Video Engine w/ HQV Vida and Marvell Qdeo™ Processing
- MHL™ (Mobile High-Definition Link) for Smart Phone Content on HDTV
- Picture-in-Picture Input Source Preview with InstaPrevue™ Technology
- Zone 2 HDMI Output for HD Video in a Second Zone
- Digital Crossover Processing Network to Cancel Crossover Interference
- Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
- Onkyo Remote App for iPod/iPhone
- DTS Neo:X, Dolby® Pro Logic® IIz and Audyssey DSX Add New Dimensions to Surround Sound
- Hybrid Standby Function to Reduce Power Consumption
Amplifier
# Channels 7.2
Power Watts/ch -
PUSH-PULL Design
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
VLSC
Connectivity
Audio I/O 8 / 1
Phono Input
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel Optical
Analog Pre-Outs 9.2
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
HD Radio
Integration Access
RS-232
IR Input
Ethernet
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section
Power Output -
Video Section
Tuner Section
General
TX-NR3010
Special Features
- 9in/2out HDMI Support for 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
- Multi-Transformer for Audio, Video, and Digital Processing
- 11.4 Multichannel Pre-Outs
Amplifier
# Channels 9.2
Power Watts/ch -
PUSH-PULL Design
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
VLSC
Connectivity
Audio I/O 8 / 1
Phono Input
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel Optical
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
HD Radio
Integration Access
RS-232
IR Input
Ethernet
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section -
Power Output -
Video Section -
Tuner Section -
General -
TX-NR5010
Special Features
- Massive Toroidal Transformer and Two Separate Transformers for Audio and Video Processing
Amplifier
# Channels 9.2
PUSH-PULL Design
Processing
DTS Neo:X
Dolby PLIIz
THX Processing Mode
Audyssey DSX
Audyssey Dynamic EQ
Direct/Pure Mode /
VLSC
Connectivity
Audio I/O 7 / 1
Phono Input
Composite I/O 5 / 1
S-Video I/O - / -
Front-Panel Optical
Speaker A/+B -
Powered Zone2
Powered Zone3
Zone 2 Line Out
Zone 3 Line Out
U-Port -
HD Radio
Integration Access
RS-232
IR Input
Ethernet
Miscellaneous
Back-Lit Remote -
Warranty 2 YEARS
Amplifier Section
Power Output -
Video Section
Tuner Section
General
