HI
I'm looking to buy a video camera that is able to capture my baseball swing so that I can analyze different components of my swing. I've done quite a bit of research and initially I heard that 60fps at 720p should do the trick, however now I'm hearing that at 60fps I might get significant blur with the bat. What I want is a camera that will give me high quality slow-motion video without any lagging or blur. I would like to be able to use Twixtor and slow it down even further later. I don't really want to spend over $300. After some research I was thinking about getting the Go Pro Hero 3, White Edition which runs for $200 and has 1080p 30fps, 720p 60fps and is small and durable. However now I'm thinking I might need a camera that shoots at a higher fps rate.
Here is kind of what I'm trying to do, without the smoke and multiple camera angles. Basically I'm trying to get a slow-motion video at a high quality that I can use Twixtor on without the bat blurring.
http://vimeo.com/25037488
Jordan
Jordan
