Ok i've been reading and reading and reading and taking notes literally all day but i need some clarification and expert backing here. I'm getting can lights put in my ceiling Tuesday and I need to tell the electrician how low to put them.
For my ceiling, from what i've read 2 layers of 5/8 drywall with GG in between is the way to go. However I don't have the tallest ceiling in my basement and was wondering if anyone knew the dimensions of sound clip and furring channel pieces. Also would it be advisable to JUST use the sound clips and not the channel?
Also, did i read correctly in that for walls going 24" instead of the standard 16" for studs is the way to go? If so how would i best stuff the batt insulation in those stud cavities?
Would it also be really worth it to insult the ceiling joists with batts and if so unfaced or faced toward the basement floor?
