I am working on speaker layout in a theater that is about 10.5' x 22'. I want to put speaker wire drops in for height and width speakers in the front for future expansion.
I don't plan to use them right away, but who knows?
The first row ears will be about 9.5'-10.5' back from the screen. I will give angles from this location.
I am designing the room so that I can convert to an acoustically transparent setup if I want in the future, but for now I am not going to do that.
My left and right main channels I am planning to put about 5" in from the sides on the front wall. These will be as close to the screen as I can get them.
So this is what I have so far:
Main left/right: about 26 degrees from center of listener, about 3 feet off the ground.
Wide left/right: about 55 degrees from center of listener, 3 feet off the ground. These will be on the side walls, so will be quite a bit closer to the listener.
Height left right: right above main left and right at about 6.5 feet.
Side surrounds: on sides between 1st/2nd row. Planning dipole/bipoles
Rear surrounds: on back wall about 1' in from corners
The big concern here is that the wide L/R are about 5-6' from the listener, since they are on the side walls, and the main L/R are about 10.5' from the listener. This would be more pronounced for anyone sitting off center on the first row.
I would assume that with a good receiver I could adjust the delay/relative volume accordingly for the wides and it would be more or less okay? But I want to know if there are any other thoughts on it.
it's just that all this also applies to my own HT project.
of course. There aren't really easy answers on this stuff I've been noticing. Right now I'm focusing on just having enough drop points to not have wires strewn around, and ideally be able to put the speakers on the drop boxes for no wires.
