Ok- here's the problem.
I went to turn on my projector last night and discovered that my Infocus 7200 was dead.
All the other components work. I tried to switch power cords and outlets with no luck getting the Infocus to power up.
No lights, no fans, no power, no nothing.
After doing some research, it sounds like it could be a power supply problem.
Do these units have a power fuse that might have blown?
Do you know where I can get the infocus 7200 checked out and repaired?
Thanks for your help.
Tim
Tim
