AVS › AVS Forum › Display Devices › Rear Projection Units › Mitsubishi Service Centers replacing bulbs only
post #1 of 3
Today, on my quest to find a bulb for my dlp, I called several Mits service centers locally because I want the lamp now.
Almost all the service centers I called replace the bulb within the housing.
I asked "how long does that housing last" and they all explain that unless it melts basically forever.
post #2 of 3
It basically can last forever but it can crack, get brittle and collect dust, it's plastic. They're probably not OEM lamps. The benefit of a new housing is, it's new, ease of installation and you don't touch the lamp.
If I needed or wanted a lamp ASAP I would have no problem using the old housing. If Mits has your lamp it doesn't take long to get, I get mine in 2 days.
post #3 of 3
They are replacing with osram bulbs
  Back to Forum: Rear Projection Units
