Excellent work. Yes, that is 33uF. The comma is used for the decimal marker in Europe.
I don't know if Duratex will stick to the PVC. You should definitely sand the pvc first. It might require some plastic specfic primer like this http://www.rustoleum.com/CBGProduct.asp?pid=119.
