AVS › AVS Forum › Video Components › Home Theater Computers › Are mounting brackets necessary for a 2.5" SSD?
post #1 of 19
I'm planning on installing an SSD in my HTPC and I'm wondering if there's any need to bother with mounting brackets. Since SSD's don't have moving parts, it shouldn't be an issue to just toss it into a 3.5 inch bay without brackets, right? I never move the computer around, so it should stay put. Will this work, or should I just go with brackets to be on the safe side?
post #2 of 19
Most good SSD models come with a 2.5" to 3.5" adapter so just check the model you buy.
Often better level SSDs come with this while cheaper ones do not. Example Vertex3 OCZ does but some agility3 doesn't.
What SSD are you looking at?
Most SSD are 2.5" and most case bays are 3.5" so if it doesn't come with it just buy the adapter separate. They are cheap and easily available.
post #3 of 19
Or just spend $2 for some Velcro and call it a day
post #4 of 19
i personally would make sure it doesnt move at least. vibration from other components can affect it. i might even use velrco or padded double sided tape at least. :P
post #5 of 19
Mine is held in place with 2 wire ties. I have some closed cell packing foam between the bracket and the ssd.
post #6 of 19
Two sides tape would work just fine but honestly an adapter costs couple bucks so just do it right .
post #7 of 19
Not quite the same thing, but back with whatever the last version of Windows was where the install program did not recognize CD drives, I kept a floppy drive in the base of a tower computer, just in case I needed to do a clean install. It was not hooked up to anything, or tied down in any way. It never caused an issue. Gravity is a wonderful tool.
post #8 of 19
I'd just get an SSD that came with adapter.
Vertex3 SSD 120GB is on sale Black Friday for $49 and comes with adapter.
There's no reason to be cheap and do it half assed IMO
post #9 of 19
post #10 of 19
But that's the thing. There is no need for an adapter if you have some 3m tape laying around. You won't even see the hard drive with the side cover on so what does it matter? I had mine taped for a year or so, then I took it out to move it and it was stuck on there so well it look a few minutes to carefully peel it off. It's not going anywhere. smile.gif
I didn't even bother re-taping it into the new pc. It's just sitting inside and it's not going anywhere since I never move it.
post #11 of 19
Right now I have an SSD in an adapter bracket mounted in the 3.5" external bay on my HTPC. I'm thinking of adding a card reader to that hole and if it means I have to move the SSD to do it I guess I'll be going all half assed on you and sticking it down with a bit of Velcro...Wanna buy a slightly used bracket? tongue.gif
post #12 of 19
Lol...
I've done it.
I've actually not mounted HDDs too...
Gravity does most if the work .
But if you know upfront my point is its easy enought to do it right.
My hhlalf ass attempts are usually cause I don't have what it takes to do it right.
I can't beat anyone up too much since I do it too.
post #13 of 19
How much for the used bracket? And is shipping included or extra? biggrin.gif
It was more out of laziness than cheapness that I asked, but I guess if the SSD I buy comes with one I'll use it. Thanks for all the tips smile.gif
post #14 of 19
If you have a 3.5" bay just mount one side of the SSD. They're light and rigid enough that it shouldn't be a problem.
post #15 of 19
Huh? We are talking about SSDs and not HDDs, right?
post #16 of 19
I'd like to know where. TigerDirect website has it for $109.99 and Newegg's already sold out. *sigh* Dunno how I missed the deal. I kept checking Newegg throughout the day.
Edit:
Great. Just refreshed my browser and it's down to $49.99 but looks like TigerDirect's servers are getting hit heavily. I'm getting a server error trying to check out.
Edited by ilovejedd - 11/22/12 at 9:15pm
post #17 of 19
Edit:
Yup.
I tried about 15 times before it took my order.
I checked with my Credit Card statement and it appears pending.. so I think I got one.
post #18 of 19
post #19 of 19
That's all I do. Run 1 screw through a hole into the drive. Bend and formed the cables so they weren't going to stress the connectors (which I do anyways with the SATA ones) and plugged them in. There really is no need for the bracket unless you want to be able to throw the PC around.
