AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Best setting for bic v1220
post #1 of 6
To any bic v1220 owners. What are your setting for your sub. Trying to figure out what phase 0-180 does.And whats best. And if setting it to dolby digital or 5.1,6.1,7.1 digital.
post #2 of 6
I have the same unit. I have the phase set to 0 and the receiver toggle set to 5.1, 6.1, 7.1. I think the receiver toggle sure turns on/off the subs crossover filter. As far as I know, my receiver is handling the crossover for me. What is your experience with your settings at this point?
post #3 of 6
I have everything set up just like yours. My volume is set at 5. And my denon 1613 takes care of the rest.
post #4 of 6
From what I've read, once you set it to 5.1 6.1 7.1 then the receiver controls the sub and the settings on the unit itself don't matter, but I do have my volume set at 7.
post #5 of 6
I beleive you want to turn off the crossover or max it out on the sub itself then run your correction software.
post #6 of 6
What is best will depend on how you have the sub set up in your environment. Typically, if you have the sub up front, 0 may work better, but not always. Switch it back and forth and see which one sounds better / produces more bass.
