AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Mede8er MED600X3D new 3D version to 2013
Mede8er MED600X3D new 3D version to 2013 - Page 6
post #151 of 626
ScoHo
my wife was pretty much fed up with it from the "down" and "up" buttons going down or up two lines instead of one
Pls explain when this happens as I have never personally seen this in the Media Library or the Jukebox . Maybe you can post a video so that I can fully understand what is happening.
Mede8er1
post #152 of 626
Hi all. I am trying to setup NFS on my Win 7 PC so I can stream 2D blurays to my 600X device. Can someone point me to an online guide which can help me with this? I installed the NFS server in Windows 7 under add/remove windows components, but I wasn't sure what to do from there. So I read the 600X user guide and on pg 39 it mentions to download HanWin server, which I did. I also followed and setup the UDP Server Threads to 32 and Max NFS transfer to 32768. On the 'Server' tab of HanWin I checked 'Allow mount of remote devices' and the 'Convert Windows drive letters to lower case' was already checked. On the 'Exports' tab, I edited the notepad and added a drive say 'g:\Movies - public -readonly' and when I saved the file I see it in the Exports window, but when I check the 'Mounts' tab, I do not see that location. The default 'c:\public' shows up though. I played around and checked on the 'Server' tab the 'Windows ANSI character set' and then the UTF8 character set options under 'Convert Windows drive letters to lower case' to see if it would do anything, but it didn't. I changed the exports file by adding the -name attribute and range attribute, but that didn't help either. I am assuming there is something silly I am doing.
I turn on the 600X and go to NFS and do see all of the locations, but when I click on the g:\Movies location, it says 'failed'. This happens on this location and the other 3 default C: drive locations. I started the NFS service and the SunPRC PortMap Daemon apps as well. I did follow part of this thread I found and allowed the HanWin 3 apps thru the Windows Firewall: http://www.mede8erforum.com/index.php?action=printpage;topic=185.0
Can someone please help me troubleshoot this issue? Sorry, I am a noob when it comes to sharing files and folders over a local network. Also for the g:\Movies folder I right-clicked the folder and shared it to the homegroup, not sure what that does.
Thanks in advance!
post #153 of 626
@kikkoman
reboot the x3 and try again, put read and write in options
ive used hanewin with good results
post #154 of 626
Originally Posted by mede8er1 View Post
ScoHo
Mede8er1
Basically, whenever you push a button on the remote, it runs the command twice, or sometimes even 3 times. Sometimes you can get it to only run the command once, but you really have to press the button gingerly. I thought maybe it had something to do with my learning remote (URC MX810), but I tried the included remote with the same issue and some others have reported the same problem.
post #155 of 626
Yep. I've pushed the enter button on the remote to get the info for a movie, and watched it go from the box cover on the jukebox screen, through the info screen, to start the movie.
post #156 of 626
I have not seen this and cannot reproduce this. Could it be placement related of the MED600X3D? Interference from other equipment ? - Plasma Display / Fluorescent / CFL lights or something.
Mede8er1
post #157 of 626
This is normal behavior if the button is pressed for too long. I can ask the engineers if its possible to add a longer ignore period to this specific area.
Mede8er1
post #158 of 626
Originally Posted by canton160 View Post
@kikkoman
Thx canton160! I did unplug my 600x and plug it back in and it sees the movies via NFS now. Sweet....I was able to test some 2D mkvs and they work great. I may try to stream 3D iso's via NFS this week. But for now local attached 3D iso's are fine.
Finally got it a media streamer that does what I need. Woot woot! Now I need to run Y2M for the 2D movies. I already did it for the 3D iso's so those are good. It took a few tries name wise for a few movies to be found though.
Is there a way to show the 3D box in the jukebox or does Y2M only show regular and bluray boxes? I have the bluray boxes already with the naming structure 'movie.year.bluray'. I tested 'movie.year.bluray.3dbd' but it does not show the 3D box art. Not sure if Yamj does this but if not no biggie. I just recall doing a couple via XBMC.
post #159 of 626
Mede8er1
It can happen on a quick tap as well, a second or less. It's not normal for any other remote I've used.
post #160 of 626
Did you try it at a farther distance from the unit? I've been finding that when I'm about 10 feet away this happens frequently but at 20 feet it rarely happens (1000X3D)
post #161 of 626
This hasn't happened to me yet with the mede8er remote. I will soon set up my Harmony 700, so hopefully this doesn't occur with it...
post #162 of 626
Not really an optimal solution is it?
post #163 of 626
I wasn't implying it was a solution. It's narrowing down where the problem lies, hardware or otherwise.
post #164 of 626
Have you investigate this ?
Mede8er1
post #165 of 626
Mede8er1
Shouldn't most buttons be setup not to repeat at all if you hold the button down? Other than maybe an up/down/left/right situation, none of the remotes for other equipment I have would repeat the action if I hold down the button.
post #166 of 626
I also have exact same issue.
Using a harmony link.
Very touchy.....
If I press button it will jump 2-3 items..
I have to press button super quick to get it to move only 1 item..
Sent from my SGH-I747M using Tapatalk 2
post #167 of 626
Using 3rd party equipment to control the Mede8er is a completely different discussion and I would think you need to fine tune some parameters in the device you use. I have a Harmony one and I dont have this problem.
Mede8er1
post #168 of 626
Mede8er1
Very true.LOL
Weird thing is that using the harmony link with my other 4 devices don't have this issue.
Maybe mede8er is little more sensitive?
Thanks regardless...
post #169 of 626
Mede8er1
Very true.LOL
Same for me. I have a Harmony 1100 and only the mede8er repeat my command twice or more. Strange and very annoying... I try to config every possible setting with the remote, delay, repeat, ect. Notting solve the problem.
Mede8er1, can something be done on your side to correct that behavior?
post #170 of 626
Mede8er1
So the player will repeat the command if the push of the button is maintain? It is possible to make that behavior optional? (via the setup menu -> Repeat on Hold -> Yes/No)
I think that will solve my problem with my Harmony.
... Or if possible, let us decide the delay in ms before repeating
post #171 of 626
The default should be to not repeat the command when the button is held in. No remote works that way except special cases (like volume).
post #172 of 626
and channels up- down
and navigation left -right- up- down
post #173 of 626
I don't know...on my Directv receiver, when I go up/down the menu, I have to hit the button for each time I go up/down. And with the Mede8er, part of my issue is when I go up/down in the menus, it jumps 2 or 3 "lines" even when I tap it pretty quickly.
post #174 of 626
I suggest you read this tip is you have the multiple jumping while navigation using a Logitech Universal Remote
http://www.mede8erforum.com/index.php/topic,9843.0.html
For other brands of Universal Remotes or other solutions such as Ipad / Android remotes I suggest you read the manufacturer's documentation.
Mede8er1
post #175 of 626
Mede8er1
thanks for this tip.
Will give it a try.
You rock!!!!
post #176 of 626
Mede8er1
Will give it a try.
You rock!!!!
I already try that (many times). I try every possible setting on the Harmony including the one suggested and I still have the same problem. The strange thing is my other 8 av gear work well with my harmony...
post #177 of 626
This works perfectly with my Harmony one. If if does not work with your Logitech model then you need request some fix from Logitech.
Mede8er1
Edited by mede8er1 - 12/24/12 at 6:07am
post #178 of 626
Mede8er1
I'm sorry, but I don't think this is on a third party remote company to fix. The problem occurs with the Mede8er remote as well, which has been reported by several people on here. Not sure why it apparently doesn't happen for everyone - could there be different versions of the remote out there? But I do know a button press hold should not continue to repeatedly issue the command (except in certain cases like volume).
post #179 of 626
Mede8er1
I perfecly understand it is not Mede8er fault. But was hoping you can help us because Logitech for sure will ignore us mad.gif
So if I read between the line it's too much complicated (and time consuming) to do a optional reapeat on hold option in the setup menu?
post #180 of 626
Will discuss with our engineers and see if we can add some some options for V2 firmware
Mede8er1
