AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Mede8er MED600X3D new 3D version to 2013
Mede8er MED600X3D new 3D version to 2013 - Page 9
post #241 of 626
Originally Posted by Ein View Post
I'm running into an audio drops problem with all the Blu-ray folders made from MakeMKV on a Mac and stream from a Windows Media server. The audio drops are always on the same scenes/spots on all the movies I have played. Some movies have more drops than others. The connection is from the box to receiver using HDMI.
But if I convert the same movie to MKV formate. I have no issue with the audio drop streaming from the same server. I put the Blu-ray folder on a USB drive and has the same issue. So that rules out a network issue.
Perplexed.
Thanks for any help suggestion.
Is it possible that the Blu Rays movies are seamless branch?
post #242 of 626
Originally Posted by canton160 View Post
@jaymayla
1)dont things so, mede8er has is firmware locked up to avoid piracy.
2) that feature has being request dont no if is possible.
3) mac version is still behind Windows version 4.0.5 i already test the metadata to mede8er, works perfect , you can download the w7 version from Mymovies
All is nedeed is upgrade The my movies app And x3 firmware .
Hmm, so, you need to scan the bar code or type in the sku for each & every movie?
post #243 of 626
Y2m searc itAlian metadata?
post #244 of 626
mymovies or any other program can scan hard drives
post #245 of 626
can you be more specific you post is confused
1-you rip with makemkv (mac version) you will end with mkv file correct ?
2.- than you convert to mkv again ? what program ?
what file has issues and what dont have issue ?
Sorry for the confusion, I can rip to Blu-ray folder or to MKV with MakeMKV. All my movies are in folder format right now. I can also use MakeMKV to convert the folders to MKV.
The movies in the folder format all have audio drop issue. But If I use MakeMKV to convert the content of the same Blu-ray folder movie to MKV. I have no audio drop issue.
MakeMKV cannot output to ISO format.
post #246 of 626
i guess you have a few seamless branched titles in iso format.
post #247 of 626
Yes, after more researches. I think that is problem. I hope future firmware can address that issue.
Now , I have to figured how get cover arts for my movies.
post #248 of 626
Originally Posted by dbone1026 View Post
It supports DTSHD. With HDMI you can either pass thru the DTSHD to your AVR (untouched) or you can downmix to 2ch stereo
What if I use the optical output, will it output the DTS 5.1ch core? (downmix to 2ch is not desirable)
post #249 of 626
Originally Posted by obveron View Post
I'm curious (before I decide to buy) when playing simple Half Side-By-Side 3d video. Is there an option to tell the Player that the TV is in Side-by-Side mode, so that the on screen display and subtitles display properly (mirrors OSD and subtitles on both sides)? The only player I've found that handles this properly is the built-in USB player in my Samsung 3dtv.
Originally Posted by digitalanalogue View Post
Yes with my projector the mede8er sends a frame packed 3D signal which triggers the Projector to switch to 3D mode. The OSD is still usable. If you change the file names to have *.sbs.mkv the mede8er will automatically switch to the correct mode, otherwise you'll have to select 3d sbs yourself in the menu.
OK framepacked 3d isn't what I had in mind. In the case of hSbS files, I'd like to output "2D" HDMI 1.3 to my AVR then to my TV, manually put my TV in Side-by-Side mode (all this works with any player), but also tell the player to mirror the OSD so that it looks right when the TV is in SbS mode.
From what I gather the OSD will look right with framepacked output, but not if i just output the HSBS in "2d" and force my TV into SbS. Framepacked 3d on this player apparently has a 23.976/24.000hz glitch in some situations, and the framepacked stream can't be passed through by many "old" HDMI 1.3 AVRs.
Since HSbS files will not get a resolution benefit being converted to a framepacked output, it makes the most sense just to output them in 2d and use the SbS feature of my TV. The problem is I can't find a player that will adapt it's OSD for a TV that's forced into SbS mode.
Does anyone get what I'm saying?
I'm still lost on finding a player can adapt it's OSD for a TV in SbS mode. Anyone have any advice?
post #250 of 626
I believe with optical you will get the DTS 5.1 core (hopefully someone else can confirm this). I think the downmix to 2ch stereo is specific to HDMI
post #251 of 626
if you are mention the 2D sbs files , well i tried one with 1.0.5 and previous versions and works fine, but you have to manually switch to 3D in player.
during the 2.0.0 beta it failed to play it, dont no the cause.
post #252 of 626
Image Re-sizing Struggle?
I am struggling Filling my VT50 Plasma screen with a Bluray ISO playing on the 600 via external usb hard drive?
The image appears like a has 2" black borders left and right which is acceptable, but top and bottom 4-6" borders on my 65" diag. screen. seems rather large
MED600X3D settings;
16:9
screen size menu adj- I moved the red box lines in and out both vertically and horizontally, little effect....
Panasonic VT50 TV settings-
16:9 (option for 16:10?)
*Note- TV you can select full, justify, zoom, only when cable tv is playing
I select "Zoom" once you play a BD ISO on the 600 you cannot change modes.
Do I have to live with those large borders or is there a way to tweak most of them out?
Thanks Vince
post #253 of 626
@vince32827
whats the movies aspect ratio 1:78 or 2:40 ?
put the tv settings in 1:1 pixel mapping , no zoom etc
if you adjust the red lines in video setting put them on default, go to system put default
post #254 of 626
MED600X3D settings;
16:9
Thanks Vince
Look at the thread on Med1000X3D. It cut of the pixel on right and bottom. Don't adjust the red box lines. That would compress the image. For the TV, make sure overscan is turn off. You wouldn't see 4" border. Also, make sure pixel orbitor is OFF or AUTO. I own a ST50 and loss around 1 pixel on the right and bottom.
post #255 of 626
MED600X3D settings;
16:9
Thanks Vince
I'm uncertain from your post but did you try the Zoom feature on the Mede8er? You can zoom to width, zoom to height, or zoom x,y independently.
post #256 of 626
Canton160. rjyap,djc1369-
Now I'm all messed up!
now I have 2 foot black borders around whole ISO image! to get out of this- If I choose "ZOOM" on the TV, I can use ZOOM feature on the 600 to stretch Promethius 3D to 134% vertical 100% horizontal. But 600 GUI skewed off the screen, cannot leave this way!
Since I messed with the red lines, is there a way to restore the 600 to red line default, or the 600 to default (not preferred)?
rjyap- TV settings overscan/ pixel orbiter set to enabled or disabled only choices, enabled by default....
Panasonic VT50 TV allows you to pick from the following aspects Ratios for 1080p material: full/justify/H-Fill/4:3/zoom (weird thing is 4:3 is used in the description for all of them in the manual, the Panasonic 211 page manual mentions the word 16:9 only once for cable TV input box only.
I need to re-scale red-lines of the 600 since the GUI menus are skewed off the screen, I have to scroll left or right to see the icons now.
thanks for the help so far....
Vince
post #257 of 626
You need to disable overscan and pixel orbiting in order to get 1:1 pixel mapping. Don't use any zoom feature on TV or Med600X3D. Try to reset your Mede8er to default seting and don't adjust the red line. There is a bug in the unit where it will cut off the pixel from bottom and right most pixel.
post #258 of 626
I recycled power on the 600, and the red lines appeared very small box, moved them back to full 65" diag size, and put the TV in "full" or "full justify", now 600 GUI menus look normal, and Promethious 3D fills whole screen with 134%/100% ratio
thanks guys for guidance
Vince
post #259 of 626
rjyap-
VT50 TV is smart enough to disable pixel orbiter on its own.
TV aspect ratio = Full
If I dont use the ZOOM feature on the 600, and keep x/y values 100%/100%, my black bars on top and bottom are like 4-5 inches!
Horizontal I'm good right to edge of screen!
Movies tested Promethius 3D and IP man 1 (both 45GB bluray ISO no compression)
Vince
Edited by vince32837 - 1/8/13 at 5:57pm
post #260 of 626
If that's wide screen movie, it's correct to have black bars on top and bottom. The orbiter turn on does cut off some pixel from time to time when it "shift" the pixel. It's been tested on HTPC HDMI output. Maybe you are looking to stretch a 2:40 movie to 16:9 format? I think in this case, use 600X3D zoom function.
post #261 of 626
****... eek.gif Is there any way of bringing the red line back to default setting without resetting the entire device to default setting?.. I have made lots of changes to other settings, and it would be a pain to have to redo all these just because I was stupid/curious enough to tweak the red line/screen size setting. I really want 1:1 pixel mapping since I have spent so much money on my TV... mad.gif
post #262 of 626
Rjyap-
you are right, the movie was 2.40 aspect ratio...for 16:9 movies I should not need zoom function..
thanks for the help
Vince
post #263 of 626
Anybody having issues playing BD rips using clownBD?
My movie file pauses around 15-16 minutes into the movie. Doing a next chaper get its back to life again and then I need to rewind back to where it froze. This is not networking related because it occurs when I play the movie through USB too.
Also my popcorn hour A-300 plays these movies flawlessly over the network.
post #264 of 626
Just about all my BD rips are made with CLown_BD and I don't recall encountering this issue with the 1000X3D
post #265 of 626
Strange. Are your files having the iso extension? It could be that my unit is defective.
post #266 of 626
No, I keep as a folder rip. The only time I use ISOs is for 3D Blu Rays (which then I obviously don't use Clown_BD for), Would be interested to hear if others using Clown_BD created ISOs are having the same issue (possibly a mounting issue)?
Can you take one of your ISOs and convert it into a folder rip, and see if you encounter the same issue?
post #267 of 626
How does one convert an iso to a folder rip?
post #268 of 626
Mount it with a virtual drive, like Slysoft's Virtual Clonedrive, and then drag the BD folder to where you want (it copies it). I've experienced a few issues with BD ISO on the 1000X3D with DTS MA sound track, occasional video stutters and momentary audio drops. They were created by folder rip from DVDFab and then Imgburn to create the ISO. MKV seems much more reliable so far. In case your interested I'm mounting the ISO and then using MKVmerge to create the MKV. A little faster than starting from disc again.
post #269 of 626
Thanks! I will try converting the iso to a folder rip and give it a shot.
post #270 of 626
Oops, I meant MakeMKV and not MKVmerge although I've done it that way also.
