AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Mede8er MED600X3D new 3D version to 2013
Mede8er MED600X3D new 3D version to 2013 - Page 16
post #451 of 618
The Media Center PC codes don't work for me. Could you double check your Harmony settings and let me know specifically what you used?
post #452 of 618
Originally Posted by Joseph Clark View Post
You mean as a Media Center PC? That's great! I already have that programmed in from when I used a HTPC in the room. I'll just change the input and I should be good to go. Thanks. I'll create some custom buttons.
My HTPC remote device on my harmony doesn't work. You can find MEDE8ER in the logitech database under the Media Center PC catagory, then add the model number.
post #453 of 618
That did it. Many thanks.
post #454 of 618
The MED600X3D was awarded by consumers with honorary title for product with best reviews collect by Kieskeurig.nl (dutch website )
source: kieskeurig.nl
post #455 of 618
They could of won a Medal of Honor for all I care. Let us know when they decide to create a decent jukebox that supports TV Shows.
post #456 of 618
X3D can't re-position the ISO's internal or external subtitle?
post #457 of 618
The latest v2.0 BETA firmware release on March partially fix the 1:1 pixel mapping issue. Now only the right side cut off one pixel. The bottom missing pixel had been fixed.
Update:
The above test is run on Panasonic 65ST50. I try the test again on Optoma HD8300 projector and it show all pixel correctly. Need to reinvestigate again on the plasma tv.
Edited by rjyap - 3/8/13 at 7:29am
post #458 of 618
I currently have an old WD Live with the B-rad firmware on it and am looking to upgrade to something that does 3D and can send TrueHD audio to my receiver and won't downmix it. I will be streaming everything from my HP Mediasmart WHS.
Is the 600X3D the best option right now?
post #459 of 618
WDTV Live does play True HD, it doesn't play DTS-MA. Mede8er is probably the best option at the moment since it has been out longer.
post #460 of 618
Update:
Might be the Orbiter on the plasma.
Sent from my GT-I9100 using Tapatalk 2
post #461 of 618
Orbiter is set to Auto. Also check from HTPC using the same test pattern and it is missing one pixel from the right too. So the issue is not from Mede8er.
post #462 of 618
Current BETA v2.0 March firmware is stable for 2D and 3D playback. Tested out with 2D/3D ISO and MKV file stream from network using NFS and so far no issue on stuttering and audio dropout. I would recommend Mede8er for someone looking for trouble free 2D and 3D media (no Cinavia and region free). Only cons now is no Full BD menu which is due to licensing issue. Will tryout the jukebox soon and current API development should encourage more third party jukebox soon.
post #463 of 618
new beta firmware 11 march
Install X3D_Series_V2BETA_11March2013
Install using the Emergency Procedure
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2013/X3D_Series_V2BETA_11March2013.zip
Changelog V2.0.0 - 11March 2013
1. Fixed - Thumbgen XML plot not showing.
2. Fixed - If 'Watched Indicator' is 'off' in Setup Menu then watched icons still showing on Thumbnails.
3. Fixed - 'Mark as Unwatched' on folder not working.
4. Fixed - Thumbnail watched indicator icon not working on file.
5. Fixed - Removed 'N/A' when focused on watched movie file.
6. Fixed - Preview background not updated when browsing files in media library.
7. Fixed - After Restore Default you get Init Screen and then press 'Return' and you get a crash.
9. Fixed - Lip sync settings to respecting on/off in Setup Menu
10. Fixed - Memory leaks when loading srt subtitle files.
11. Added label of HDD/CARD for sharename of samba.
12. Update NFS Thumbnail images .
13. Remove the 95% scale to the window used for movie preview.
14. Added Compound Filtering in Movie JukeBox
15. Updated French localization
16. New functionality - support external subtitle in BDMV structure. ie subtitle naming 'foldername.ext' and place in the same folder as the BDMV (not in the BDMV folder)
17. Fixed - Screen size adjustment - Setup Menu
post #464 of 618
Impressive work! Done in a week after I raised this issue.
post #465 of 618
Here's an interesting development. Over the weekend, I migrated my Unraid hard drives to a new Supermicro 24-bay server. I've found the new server faster in every way than the old one (which I built). The Supermicro unit is a business class server that I got from TAMSolutions in Utah for a ridiculously cheap price. There's an AVS thread on it. Anyway, with this new server, the problem with Blu-ray 3D/DTS HD MA playback via my regular network seems to be gone. I'm still not using NFS, but playback doesn't stutter and audio does not drop out. I've tried playback from a local hard drive attached to the MED600X, and there doesn't appear to be any difference now between that and normal network playback of the same Blu-ray 3D titles. Most play just fine. Some Disney titles, like Tangled, still exhibit some minor breakup at transitions, but that happens from the hard drive or the network. It's not severe, but hopefully it will be solved with a firmware upgrade down the line. Ice Age Dawn of the Dinosaurs was unwatchable via the network before - it stuttered badly. It plays fine after the server change, too. I still have a lot to do to complete my setup, but overall I really like this little device.
I think I"ll get another 600X for my dedicated home theater room. It's that much more convenient than using the HTPC for most movie playback. I'd like it if it supported TV series, too, but hopefully that's coming some day down the line. My HTPC handles those discs well enough for now.
post #466 of 618
glad you sorting things, if you going to 3D route, make sure you using NFS for completly shutter free video + hd audio
also i read in mede8er forums that nfs v4.0 is not supported, just v3, it will mount v4 but revert to v2.
see here
http://www.mede8erforum.com/index.php/topic,10657.msg69260.html#msg69260
post #467 of 618
Right. I plan to do that. No sooner do I post about my success with 3D and Samba than I have an audio dropout with a 2D title with DTS HD MA. This may take a little longer for me, because Unraid apparently has broken NFS support in the latest release candidate.
post #468 of 618
FWIW, I am using the 600 with a Synology Rackstation. (I used to be an unraid guy, btw) With Samba 2D is flawless. As had been said use NFS to get good 3D. Disney ISOs at branching hiccup, but that is it. Gonna' try ripping them to 3D mkv since the BD menus are inoperable anyway. I love this thing.
post #469 of 618
New firmware.... expect launch to be on 15 march with aggregate jukebox in GUI
post #470 of 618
Great solution for organizing xml and artwork for TV Series on the Mede8er
Demo
https://www.youtube.com/watch?v=r2OJVte_Fo8
Download
http://www.mede8erforum.com/index.php/topic,10729.0.html
Mede8er1
post #471 of 618
What is the status of an iPAD app for a music jukebox for this?
I was looking at a used Logitech Squeezebox touch but they are ridiculously expensive and not supported any longer. All i need is something that will read basically all digital music formats, output it digitally to my preamp, and allow me to see cover art and make selections with a nice IPAD gui interface.
post #472 of 618
Demo
Download
Mede8er1
This is great, but we still need the following:
Forced sub detection in MKV files.
Boxset support.
post #473 of 618
Boxset support.
Agreed. The TV Show support is a nice step, but still not quite where I would consider it proper support. Really hoping it gets to the point where TV and Movies are all one jukebox instead of having to juggle multiple processes
post #474 of 618
I agree. I posted somewhat of the same comment on the other thread. If you own a Mede8er already this is a nice option, but if you are spoiled like me using Zappiti then it isn't worth it.
post #475 of 618
NET API V0.3 is fully functional in our latest X3D Beta and supports Mede8er Movie and Music JukeBox and IP Control Commands. So our work is complete on the API and its now up to external developers. We already Alpha testing iPad based Movie JukeBox Apps but it will take some time till these are ready for the mass market. I expect most will complete the Movie JukeBox and then start the Music JukeBox. I also want this completed asap but we need to be a little patient.
Mede8er1
post #476 of 618
Boxset support.
These points are on our list.
Mede8er1
post #477 of 618
Mede8er1
We know, and please don't think I'm knocking your players, nor your efforts. I think I can speak for most everyone here when I say that the efforts and improvements we see in the code from your dev team, along with the public presence they have on your forums beats any other player hands down.
post #478 of 618
It beats the Dune in support and customer service. It doesn't beat it in what my family and I use the most full jukebox support for movie and TV shows.
post #479 of 618
Mede8er1
Thanks! I think I may go ahead and pick one of these up to test and play around with. If I am convinced that the video output quality is as "bit perfect" as my Oppo 93 it will probably take over as the everyday player. Having something I can connect all of my music too with an IPAD app plus a full featured, jukebox enabled high quality Blu ray rip playing device would be very nice. Right now I get the high quality playback through the Oppo, but have a very pedestrian folder based file selection method.
post #480 of 618
I'm using the 1000X3d solely for HD music. I've got two jukeboxes set uo, one for my Blu-ray and DVD video discs (individual tracks) and the other for hi res audio albums, primarily DVD-A but also bluray video ripped as audio only. Works beautifully. No problems with DTS 5.1, DTS-HDMA 5.1, Dolby TrueHD 5.1 audio streams.
This is really a great way to manage your hi def music. I've just moved my hi def audio collection to the media server and now so easy to listen to everything.
Just wish I could get my SACDs ripped. I know one day the discs will die, aka laser rot...
