AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Mede8er MED600X3D new 3D version to 2013
Mede8er MED600X3D new 3D version to 2013 - Page 25
post #721 of 840
So am I right in thinking there is still an issue with forced subtitles and .m2ts rips and 3d isos? No simple plug and play solution?
post #722 of 840
I had a problem (stuttering audio) with 3D ISO's, but it was not the Mede8er's fault. I learned on the Mede8er forum that someone else with my model NAS streamed them just fine. As noted above, MKV's worked for me instead. Probably the cascaded switches in my network causing the issues.
Mark
post #723 of 840
Any issue with forced subtitles?
post #724 of 840
I don't have any titles with that issue yet. From what I understand, all media players have issues with forced subtitles, but perhaps others will chime in.
post #725 of 840
The Dune and PCH players will show forced subs in MKV files only. They need to be marked as forced in order for this to work.
None of the players will handle forced subs in ISO or m2ts files.
post #726 of 840
I could easily be wrong. I have a Micca ep600 player that, if my memory serves me right, plays forced subtitles from BD .iso files that I have ripped using DVDFab. I will double check that fact tonight.
Anyways, I was about to buy a med600 but I am not waiting for a fix or something else if forced subtitles won't be displayed with BD .iso files.
(and sorry if I am not understanding something. I know just enough about streaming devices and ripping to be dangerous, not an expert.) smile.gif
post #727 of 840
No, none of the Realtek 1185/1186 players recognize forced subtitles which includes the Micca.
post #728 of 840
Ahhh, I see the errors of my ways now. Several of the movies I have watched do have subtitles and only when there is a non-english language spoken. but it appears they are hard coded, not 'forced'. I didn't realize there are all different types of subtitles with .iso files. Sorry for my added confusion! cool.gif
post #729 of 840
No worries, it's confusing for everyone.
post #730 of 840
I'm just going to ask this anyway even though I am pretty sure the answer is NO. Is there going to be a possibility for Mede8er to support Plex like Popcorn Hour has?
post #731 of 840
they have no plans to. I asked on there forum. you can use the web browser on the mede8er to access the plex html portal and play videos that way though. but its not easy to operate
post #732 of 840
Oh well then, that removes the Mede8er from my list of possible media players to buy. I like the Mede8er support and features, but my wife, kids and I just hate the jukebox completely.
post #733 of 840
Let me first apologize if my would be question has already been asked.
Although not care too much for 3D movie, I am really like this Mede8er 600x3d and thinking about to buy one to replace my aging SageTV300. My movie collection contains only DVD and 2D BlueRay that in their native format, folder structure. Most of the posts here are only discussing 3D movie in ISO or MKV file and have not seen in depth discussion of 2D in folder format. Will 600x3d plays the folder structure as greate as ISO files or do i have to convert the movies to iso or mkv? Thank you.
post #734 of 840
600x3D will play the 2D BR ISOs fine. The only exceptions would be no forced sub or seamless branch support (I can't remember if the SageTV supported either of these, was a real long time ago that I used the TV300)
post #735 of 840
So what does it do, actually, if it doesn't support seamless branching. Does it just go into the BDMV\STREAM folder and play the largest .m2ts file?
Does it open a playlist at all -- i.e. does it at least support chapter skip points in a BD.iso.
post #736 of 840
I believe it grabs the longest playlist and uses that. The movie will play in its normal sequence, but you will see some jumping as you go from one m2ts to the next.,
post #737 of 840
Thank you dbone. when you say not supporting force subtitle and seamless branching, are you refer only to 3d or both of 2d and 3d on Medde8er? I am currently using hd300 for all 2d dvd and blueray. Some of the dvd and blueray I do notice microsecond pause when it change to next scene, kind of annoyance tho. About the force subtitle, I play the Avatar DVD with subtitle turn on and do see the sub for alien language. The same goes with the BR Star Trek when Klingon speaking foreign tongue. If the Mede8er can display force sub when the subtitle feature is turned on, I am good with that.
I saw the v3 firmware is release. Will the new firmware be factory install or is it still on the v1.x? I am also big on movie wall and convenience of not having to mess with 3rd party app for the movie wall. Thanks again for your answer.
post #738 of 840
I see, thank you. So this jumping is obviously the complaint I'm reading about with regard to seamless branching.
post #739 of 840
I am talking about both 2D and 3D Blu rays. For Blu Rays the only way the Mede8er will display the forced subtitle when turned on is if the forced subtitle track is the default track (i.e. the Mede8er will automatically load the default subtitle track). Otherwise you will have to cycle through the subtitle tracks to figure out which one is the forced sub track.
Yes, the jumping seems to be more obvious in some blu ray titles versus others for whatever reason.
post #740 of 840
How difficult is it to find the forced subtitle track on the disk when ripping in order to make it the default subtitle track? It must not be apparent because people post about this a lot. How do you know which is the forced subtitle track before you rip the movie?. Is there an application that can help find it?
What about after you rip a movie without making forced subtitle the default - how to you find/use it during movie playback - by trying every subtitle track for your language via the Mede8er remote's subtitle button?
post #741 of 840
http://www.avsforum.com/t/1176923/movies-with-forced-subtitles/0_50
post #742 of 840
Forced subs are tricky because they are not always flagged as forced subs (I am assuming the disc authors/studios may do this to further confuse). A tool like MakeMKV looks for forced subtitles, and if founds sets as the default sub in an mkv. I use Clown_BD (the tools behind it being eac3to and bdsup2sub) which will extract the forced subtitles for you (once again, not 100%).
As far as after you rip there is no easy way. First, you need to know ahead of time that the movie even has forced subs. After that, it is just a matter of guessing by cycling through the available subtitles (even then this is not easy since the forced subs will only appear in a few scenes you need to know what scenes to even be sure you turned them on)
Edited by dbone1026 - 10/21/13 at 9:20am
post #743 of 840
Thank you robnix and dbone. This is a bit of a mess. Either you do the work at the time of the rip or you interrupt watching the movie when you realize you need a subtitle and have to go searching. You would think someone would have written an app to view the subtitles on the sidk before ripping to more easily determine the forced subtitle to add to your rip.
post #744 of 840
Yeah I was going to start ripping to MKV for playback on a new 600x3d but all of this became too time consuming. I will just stick to ISO and my Oppo with Iso playback until somehow playing back forced subs is resolved in an easier manner.
post #745 of 840
You sire are going to be waiting for a very long time for proper support of forced subtitles. Specially for Mede8er since it appears to be a hardware issue. I switched everything to MKV and flagged the subtitle tracks, and by using the Dune patch, it will play the forced subs correctly. I've been testing Plex with forced subs for Avatar and The Avengers, and it played the forced subs also. I haven't had time to test other movies yet. With Plex you need to flag the subtitle track as well. Plex can also download the subtitle tracks if need it, but I haven't tested that yet.
post #746 of 840
Yeah I probably will be waiting quite a while. Oh well. From what I read it just looked incredibly time consuming and a lot of time wasted in "trail and error" to effectively rip to MKV while keeping proper forced subs intact. Maybe its one of those things that would become quick and second nature once I started doing it, who knows.
I really would like to, as clicking a movie and having it start immediately with no menus like my discs or rips would be very nice. I would watch small favorite parts of movies way more often like that.
post #747 of 840
Well here's an odd notion and one that works well for me...I don't even mess with ripping discs with foreign or alien languages that might be difficult to rip the subtitles. Avatar and Die Hard 4 come to mind in the last year or so for me. I just pop the disc in the Blu-ray player and voila, perfect subtitles. wink.giftongue.gif
post #748 of 840
I don't have issues with Forced subs with MKV + Dune Smart Series + Subtitle Patch = It Works.biggrin.gif
post #749 of 840
The issue of handling forced subs with media players has been beat to death several times in the Ripping Blu Rays II thread.
post #750 of 840
Did I mentioned that Mede8er should look into supporting Plex. Plex so far recognizes the forced sub flagged from my Avatar and The Avengers. Further, the Plex Jukebox is better since it supports both movies and TV shows biggrin.gif
