Originally Posted by
jbrew5000
Not sure if anyone is still monitoring this thread but I have the exact same set up that I am about to hook up. And while I want the best sound I can get: Isn't the soundbar in question only 2 channels to begin with? Is the sound quality of 5.1 better if is going thought just 2 channels? Are there other quality factors that contribute to better sound other than the # of channels that will not come through over HDMI from the TV?
Same question for the optical hook up if the HDMI/ARC does not work.
Yes, the E450 is a 2 ch. soundbar. How much difference you will hear when the bar receives a 5.1 signal vs. a 2 ch. signal depends on a lot of things including how the bar applies "surround" processing, room acoustics, your own hearing, etc. The assumption is that if a soundbar receives 5.1 audio it has more information to work with as it mixes five channels into two. Whether that is what happens inside the bar is something of a guess. When I was using a soundbar, I could definitely hear a difference between feeding it 5.1 and PCM of the same source material.
jbrew5000
Also, what is the reasoning for the TV and the sound bar inputs to function this way? Is it a price point thing that don't always allow them to act as just "speakers" while your TV acts as the "receiver"
Sorry, but I don't follow what you're asking here.
