Originally Posted by nograveconcern
You can wire the dvc's in parallel (4 ohm speaker) and then wire the 4 speakers in series/parallel (two pairs of speakers wired in series and then the pairs are wired to each other in parallel) and end up with a 4 ohm load. Bridge the amp for this.
or
You can wire the dvc's coils in series (16 ohm speaker) and then wire the 4 speakers in parallel for a 4 ohm load to the bridged amplifer.
or
You can wire the dvc's coils in parallel (4 ohm speaker) and wire up 2 pairs of speakers in parallel (2 x 2ohm pairs) and run each pair off one channel of the amp in "biamp".
Clear?
Pick one. They are all equivalent.
The crutchfield diagram above is wrong. That's 4ohm/coil you have 8ohm/coil. The bottom diagram is the 3rd configuration I listed, though it would be hard to wire like the drawing with 4 separate boxes. You want to wire the speakers in parallel w/ 2 jumpers and then you can wire one box to another in parallel an then each pair to a tap on the amp.
or
or
Clear?
Pick one. They are all equivalent.The crutchfield diagram above is wrong. That's 4ohm/coil you have 8ohm/coil. The bottom diagram is the 3rd configuration I listed, though it would be hard to wire like the drawing with 4 separate boxes. You want to wire the speakers in parallel w/ 2 jumpers and then you can wire one box to another in parallel an then each pair to a tap on the amp.
Okay, I think I got it... I will probably throw together a diagram and make sure I do before I proceed, but you have been a huge help as always..
One more question.. Speaker terminals. I have four of these:
Will this work for #1 or #2 options above (I am leaning towards #1 above "wire the dvc's coils in series (16 ohm speaker) and then wire the 4 speakers in parallel for a 4 ohm load to the bridged amplifier.")
Otherwise, I am curious would would be a good alternative. I am going to start assembling boxes now...
